3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The $70 IKEA Mini Server Rack
Make a $350-$550 mini server rack for $70!
Let's say you have some rack-mountable servers in your house. For example, you might have a web server for your corporate website, a file server for your terabyte of (un)pirated media, and sundry networking equipment. Let's say all of this gear totals 8U, or about 14" of vertical height.
If you're like my housemates and me, then the obvious thing to do would be to purchase a hulking, steel 42U (over 6' tall) server rack and put it in the the entryway of your house.
After a few years of cohabiting with the 42U monstrosity, we decided that it should be replaced with a smaller, 12U server rack. Ben decided to price this out and found this one ($565) and this one ($341). We looked at these racks, then at their price tags, then back at the racks, and then realized that we were about to drop hundreds of dollars on a glorified end-table.
So, why not just use actual end tables?
Hence, this Instructable. In a nutshell: epoxy together two of IKEA's CORRAS bedside tables. Two are needed because each is only about 15" deep, and most rack-mount servers are 20"-30" deep. The project is pretty simple because these end tables just happen to have exactly the right inside width to fit servers. They even come with handy shelves to set the servers on.
A few photos of the finished product are below (apologies for the crappy mobile phone photos, throughout; it's all we had on hand at the time):
Step 1Figuring out how to get a strong bond
Like many pieces of IKEA furniture, these CORRAS bedside tables are made of a composite material. It's basically a paper core with thin panels of wood laminated to the outsides. The images below were excerpted from this paper, whch studied the strength of this material and its usefulness in furniture construction.
As the paper notes, it is strong and inexpensive. The manufacturing difficulty, however, is in devising a way to attach the panels together. IKEA's stuff, for example, has connection hardware integrated into special parts of the board to make joints that can handle the loads.
We go into all this detail for a reason. The face-to-face attachment that we want between these end tables requires joining the boards together in a way they weren't designed for. Imagine the end of the board in the picture below being the front or back of the bedside table. The cutaway part would just be covered with "cap" of wood, laminated on. Unlike solid wood or MDF, we can't just drill holes in the ends of each one, plug in dowels and glue, and push the surfaces together. There is no wood inside to drill into, and the veneer will just peel away from the paper under stress.
Instead, we take advantage of the large surface area of the top and bottom panels, epoxying metal rails to them to distribute the load on the joint across the entire panel. The next few steps in this Instructable detail how to do this.
34 comments
Feb 2, 2010. 12:20 AMhintss says:
the ikea lack table
google lackrack
Jun 28, 2010. 7:45 AMSyx says:
Sweet, thanks for that!
Jan 30, 2010. 5:09 PMcloudbook1994 says:
what is the internal width of the eina table?
Jan 26, 2010. 11:06 PMinchman says:
Great 'ible!!  I want to comment on your awesome style of being informative AND entertaining.  I have to remember to make my next one more fun.
You came up with a great solution to a problem I've been thinking about for some time.  Thanks again!
Jan 2, 2010. 7:57 AMmattccc says:
what is the specs of  your server?
Oct 9, 2009. 11:16 AMethosrot says:
Absolutely beautiful.
A few friends and I are looking at putting together a 16U rack from scratch for some projects we have, and I was curious if anybody had already done it on here. Unfortunately, there is no IKEA near here, so this is not really feasible for me. Great instructable though!
Back to Home Depot for me :D
Sep 28, 2009. 1:42 AMesben2k says:
Cool
Feb 13, 2009. 12:47 PMWAFexpert says:
This is a pretty cool project but, I can't help but think about how deafeningly loud those rackmount servers would be in my living room. Especially with hardwood floors. What can you do to quiet this system down? Can it be inclosed instead of left open? Can you add sound deadening foam?
Feb 13, 2009. 9:14 PMWAFexpert says:
Well, for $50 or so, you can pickup some sound deadening sheets to stick to the insides of the cases or perhaps inside the enclosure and some sound deadening foam blocks to stuff stuff inside the empty 3.5 and 5.5 inch drive bays. Which in some ways and increase airflow and improve cooling but, I don't know how effective it would be. All of the know alternatives are incredibly expensive. Pretty much starting at $600 and going up to and beyond $3,000 (depending upon the size of the enclosure (6U to 42U). I'd be really curious to see what could be accomplished for under $150 (or twice the cost of the original enclosure; or less).
Dec 12, 2008. 9:11 AMServer_Rack_Guy says:
Cool server rack, I guess I will be out of a job soon then...how can my enclosure cabinets compete ;)
Oct 30, 2008. 4:57 PMSanclous says:
Wow in that picture of your friend standing on the rack he looks just like Nicholas Brendon
Oct 14, 2008. 7:33 PMalex-sharetskiy says:
Cool!
Aug 5, 2008. 9:15 AMbustedit says:
Nice. Are PC servers the same dimension as most rack mount audio equipment, 19 inch? I would like a more furniture like rack for my sampler collection.
Aug 5, 2008. 10:54 AMbustedit says:
thanks. i sent that ? before i read the final step. IYO is that faux wood strong enough to hold heavy equipmnt if only secured to a metal rack that is epoxied to the cabinet? im worried about torsion stress, as most kit is only supported by 4 screws at the front.
Jan 18, 2008. 9:26 PMgenenius says:
Great writeup! I just got myself a Dell server and was looking for a rack for my home... Nothing 42U big, just something to keep it from being stored on a table or on the floor. After seeing that even for an 8U rack it costs almost $500 (rounding); I found this... can't wait try it out! I'm going to take that idea also to drill some vent holes on the shelf as well as maybe on the sides. For a couple of servers, I can see this as very cost effective. You can even go as far as putting some fans in at the top to vent air out that way too.
Dec 1, 2007. 11:31 AMdanlocks says:
As long as you're using epoxy, you could common trick used to repair delamination in boat hulls: drill your holes through the veneers. put tape over the bottom hole. mix up some epoxy (the thin runny boat kind works best) and fill the cavity. Now drain most of the epoxy out. Doesn't matter too much if you drain all or a little, you were just trying to coat the inside of the cavity with the thin stuff. Thicken the epoxy with something (sawdust, We$t Marine Filler #50456098..., flour??). Cover the bottom hole with tape again. Fill the cavity with the thickened epoxy and wait for it to set, say, overnight. Re-drill your holes and you have a strong surface for the bolts to bind against w/out crushing the paper or twisting the veneer.
Aug 16, 2007. 12:19 PMBauer says:
Nice one.
Apr 24, 2007. 7:20 PMsrwoodruff says:
Hi there, I'm about to build one of these and I was just wondering how it was holding up for you heat/vent-wise.
Apr 5, 2007. 2:10 AMmdmoose29 says:
wow.. ya.. token rings... that was the most pointless thing i learned in my networking class i took. besides everything else around the same time. wait a seconds... that whole class was about obsolete networking.... i want my money back.. damn online expert....
Apr 6, 2007. 1:44 AMwestfw says:
Token ring networks were all the rage among computer scientists. FDDI even got pretty far in the market before they got heavily trampled by the engineering behind real networks and ethernet implementations. "with a gaussian distribution of packet sizes a 4 Mbit token ring should out-preform 10Mbit ethernet." "But my packet sizes don't have a gaussian distribution of sizes and my ethernet card was 1/10th the price of your token ring card!" "Oh."
Apr 5, 2007. 6:07 PMMyself says:
It's not useless if it wins you a prize in Anything but Ethernet! ;) Seriously, there's still a lot of legacy Token Ring hardware out there, especially in legacy IBM shops, and there's no harm in knowing how it works, and especially how it fails. Kick the MAU!
The Token Ring is just that much funnier because it's inches away from a GigE switch. It's gratifying to know I'm not the only one with a hardware collection like that.
Apr 4, 2007. 11:00 PMwestfw says:
A token ring concentrator? Even the cisco labs, bastions of ancient technology that they are, have been throwing those away for years now!
Apr 4, 2007. 11:13 PMtheRIAA says:
$70? i guess it looks pretty, but would could have gone way lower
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:nagutron
I'm the former Frontend Engineer for Instructables. Problems with the site? It may have been my fault... Like what you see? Sing my praises!
