The __jrP4__ - Junior Portable Pnuematic Projectile Propogator
I have wanted to make something like this for a long time, but couldn't quite figure it out. Thank you to Scott Scriven - http://toykeeper.net/spud/ - for the idea.
Here was my goal:
1) Handheld
2) Air powered (relatively safe)
Enjoy!!!
Step 1Plan and gather parts
Parts list:
A. ~ 2' of 1/2" pvc (schd 40 or 80).
B. ~ 1' of 1 1/2" pvc (schd 40 or 80).
C. Some combination of fittings to go from 1/2" FS (female slip) to 1 1/2" FS. I picked up a few different combination of fittings, each of them producing a little different look. For this gun used a 1/2"FS x 1 1/2"MS and a 1 1/2" FSxFS.
D. 1 1/2" FS x 1 1/2" FT (female threaded).
E. Some combo of pieces to go 1 1/2" MT x 3/4" FT. I found a single fitting for this, but you may have to use multiple.
F. 3/4" MT x 3/4" FT elbow.
G. 3/4" MT end cap.
H. Two tank valves.
I. What they call a "Valve extender". This fits onto the tank valves and has a plunger to release the air. I have some other ideas on what else could replace this, but this is the most straight forward method.
J. Some semi-flexible rubber (or maybe plastic) material for the diaphram. I used some sheet gasket material.
K. Teflon pipe tape (not shown).
L. PVC cement (clear is best, to keep it looking clean).
You will need a drill and a tap set also. To thread for the tank valve, you need a 21/64 drill bit and 1/8-27 NPT tap head.
25 comments
Sep 2, 2009. 8:23 PMimmell_99 says:
what exactly did u use 4ur diaphram?
Dec 28, 2008. 4:30 PMknoxarama says:
yes, yes there are. But there are also funner ways which are incredibly dangerous and reletively idiotic. Either way, cheese wins Except it must first betray wisconsin to stupid cheese heads
Nov 3, 2007. 6:53 PMJoeyJaroz says:
I Got the same computer ITS SO GREAT!!! also good instructable
Aug 14, 2007. 1:46 PMSheenJones says:
i have seen it many times, and still dont get it. what is the PVC ring with the blue ring? what is the blue ring?
Aug 14, 2007. 5:43 PMSheenJones says:
well is that the blue thing? what is teflon tape for? and why is it in that peice of PVC?
Aug 15, 2007. 10:11 AMSheenJones says:
oh, okay. thank you. so you can just get it like at a hardware store? thanks for your help. lol.
Aug 20, 2006. 8:35 PMPattycakes says:
I made something like this but way bigger, took 10 min. to pump up, and could blow babies apart at 20 feet.
Apr 17, 2007. 7:57 PMthingygoboom says:
Babies you say...........
Sep 29, 2006. 3:46 AMgenewitch says:
I made several potato cannons... after reading about them online several years ago we decided that the sprinkler valve model would suit us best. If i can find pictures i'll upload them the thing looked harsh, it was 6 feet of tubing with a U shape, so only three foot total length. the chamber to hold the air was 2.5" by three foot, with the stuff to bring it down to the 1" tubing used by the valve. the valve had a 24 volt solinoid, i think it was supposed to be AC 24V, but we used 4 9V batteries hooked up to be 18V X2 in parallel. the switch was just a dinky pushbutton. the batteries and the pushbutton were mounted inside of a 2" PVC section that was then taped and later glued to the barrel. the barrel was either a 3/4" or 1" 2' long pvc pipe. i can't recall anymore. anyhow the chamber had a threaded bicylce tire nipple on it, and you'd charge it to 120PSI. load your ammunition into the barrel and push it down. SLing it over your shoulder, aim down the chamber and press the button, and FFFFFFFFFFFFWOOOMP, out came your projectile. the only method i've seen that's better for the pneumatic ones is using a diaphragm, but i could never figure out the instructions for those types. My favorite potato gun ever was one we made out of a 2 liter fire extinguiser and a length of exhaust pipe (from a car). We epoxied the two together, them wrapped heavy duty duct tape around the entire thing. drill a hole at the bottom of the fire extinguisher, and pour in your naptha (lighter fluid). spin the thing in the air horizontally to allow the mixture to get more oxygen, load it with an orange or whatever you want, set it on the ground and light it with a BBQ lighter. man that thing is loud, and it sent oranges sailing 2-3 blocks away if you aimed it right. :-D
Jan 28, 2007. 10:40 AMabitslowbuthappy says:
The best and easiest potato cannon I ever put together was just a straight cylinder with about a foot and a half of 6 inch diameter PVC joined to 2 feet of 3 inch. I capped the big end with a screw cap so that it can be removed and inserted a pezioelectric grill ignitor. Sealed all of the joints, wrapped the combustion chamber in duct tape to control shrapnel as these will occassionally explode as you up the anti, and it was done. Jam a potato (an apple is a softer projectile, and a balled sock will just knock the wind out of someone at close range) on the end, use a pole to force it to the beginning of the barrel (at the end of the combustion chamber), and you're almost done. The most important part is the fuel. Anything combustible works. Hairspray, starter fluid, paint, whatever. Airisol is easiest. However, for the potentially dangerously powerful result, you need to generate dry-particle spontanious combustion. Degree brand airasol deoderant works the best for me. Unscrew the end, spray for just a second, definately not as long as two or the fuel mix ratio starts to go, quickly recap, and press the button. I've put a potato through a quarter-inch piece of plywood with this design.
Sep 12, 2006. 12:39 AMmr inventa says:
again see how stupid i am! haha i accidently put "right" instead of "write" lol just gotta take that english class one more time...
Sep 12, 2006. 12:37 AMmr inventa says:
srry guys im new to this! first awsome instructions although why do you need the 2 inch 1/2 foot piece of pipe and sec. how do you load the ammo, third where can i find these valves ive asked evryone!! i even went to lowes & home depot but no one knows what im talking about! i feel so stupid :/ lollololo. ok enough drama but anyways can someone right back explaining atleast one of these ques.?
Sep 11, 2006. 7:20 PMRetroboy4 says:
I made a bigger diaphram valve type model a few years back, this is much more portable and compare faveribly to the biggergun.
Aug 31, 2006. 7:28 AMCamster911 says:
Lol! loving the sound it makes
Aug 3, 2006. 5:25 PMvatik says:
cool project. I made something similar to this a few years back. It wasn't quite as portable as I used a tire valve and a automotive air pump. I put a potatoe halfway through a wheelburrow at about 175 psi..... if anyone tries this modification, make sure to check the pressure ratings on your pvc (i think mine was rated for 250). too much pressure and you could end up with plastic shrapnel in your head. pneumatic guns can be quite powerful at higher pressures.... use caution.
Apr 4, 2006. 4:14 PMwoofo says:
Great project! I tried to do something like this last year using an old pop gun design but modified to fire wine corks. Living in the wine country we got lots of those! Could be fun. I like your design. how's the valve work?
Mar 27, 2006. 11:22 PMmatthewbeckler says:
Awesome project, I've always wanted to build a larger cannon with the diaphram valve...never had a decent air compressor though :- ( Very good write-up, clear instructions, good pictures...Thanks!
Mar 27, 2006. 9:51 PMMoogle says:
Sweet! Now I have something productive to do other than read instructables all evening! BTW, you can make a functional impromptu tap (or die?) for whatever size you need by buying a small length of threaded tube of the appropriate size, cutting several slots perpendicular to the threading, and squeezing the end slightly smaller with a pair of pliers. Then just grip the other end really hard w/ the pliers and use it like a normal tap. My dad demonstrated this when I asked for help with my big potato gun. He didn't have a 1' tap handy in his workshop. I'll make a short project on it if I ever get around to making one of these tater-tot guns. Such a neat firing mechanism!
Mar 27, 2006. 2:28 PMcolin says:
This is awesome. Very clear instructions and great pictures. What are you using for projectiles?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dschwant
Just an old guy, with a bunch of kids, who likes to make things.
