Step 3Build barrel and diaphram
2) Cut the diaphram to just barely fit into the inside of (D) (1 1/2" FT). It should fit freely, but not have a lot of room to slide side-to-side.
3) This is the most critical step in the process. Take the time to understand how the gun works. The inside end of the barrel must be flush with where the diaphram sits on the 1 1/2" FT end of (E). To do this, set the diaphram on the end of (E), holding it upright, and screw it into the chamber until it is snug, then back it off a little. Still holding it upright, slide the barrel in until it sits on top of the diaphram. This is where you want it cemented. Mark the location where barrel enters (E). Remove (E) and the diaphram and then cement the barrel in, making sure to keep the end centered in the chambe where it will meet the diaphram.
comments
Add Comment
Add Comment
![[blog 2006-04-15] Instructables Project Contest - March 2006 - Results!](/static/defaultIMG/default.SQUARE.gif)
