The $1 Waterbrush / Ink Brushpen
I started fooling around with watercolors recently and read about the waterbrush, which you use with your standard dry paint-cake-in-a-box. Instead of dipping your brush in your clean water jar to wet it to get paint from the paint cake, you squeeze the barrel of the brush. Instead of cleaning your now-dirty brush in your dirty water jar, you squeeze the barrel to get more water to flow out of the brush and scribble on scrap paper until it runs clear. GENIUS!
This is most useful for people who do watercolor painting outside, as you don't have to bring a your jars of water with you. I just like the idea of the waterbrush because I'm lazy.
I was at the art store today and looked for a waterbrush, but they were out. Later I happened to be in Target with my sister and they had some in the kids' art section, 5 for $4. (This is cheaper than the $6ish + shipping I'd have to spend to get one online. I'm also cheap.)
The problem: they were already filled with color!
SPECIAL NOTE: This Instructable is mostly to say "hey, look, cheap alternative" and show pictures of the internal doohickeys of this kind of waterbrush. Here are the steps: 1) take apart; 2) dump out the color and rinse; 3) fill with water. Not intensely challenging.
Step 1Buy, take home
Buy, take home
The brand was Elmer's Paintastics. What a horrible name for a kid item.
Luckily, I noted that there was some kind of spacer in place between the color (which looked like food coloring) and the brush tip. Which meant that the tips were still untouched by the color. A sinister plot was hatched.
(There were also other brands, but these were the cheapest and I didn't know at the time if what I planned was possible.)
These are pretty decent, actually. The waterbrushes are a good size, and you don't have to squeeze superhard to get water flowing. They also don't constantly drool water.
I got 'em home and took 'em apart over the sink.
40 comments
Jun 28, 2011. 7:26 AMkariswg1 says:
I did this a couple of years ago, and they work great!
Jan 24, 2011. 9:22 AMKwartzKitten says:
Good idea, but I don't think they sell that kind of brush anymore. I looked and couldn't find it anywhere. I'll remember this if I ever am able to get my hands on them though :)
Sep 3, 2010. 5:27 AMmncannon says:
i bought a set of these also. i emptied them out and filled one with water, one with bleach and one with blending solution. i kept the black in the other and now have a spare one. i also used a 40% coupon at michaels. they are perfect for my needs. i took most of the guts out and it works well without them. good tutorial!
Sep 6, 2010. 6:16 PMmncannon says:
i use the bleach to change up papers (lines, dots, circles..whatever!) that i use for my mixed media pieces. i also use the blending solutions with my alcohol inks that i also use in my pieces. they are great because they have small tips and do small spaces. i think these pens are the best thing since sliced bread!!
Sep 3, 2010. 5:28 AMmncannon says:
oops..better late then never!!
Jul 2, 2009. 12:09 PMblueheronarts says:
Jul 2, 2009. 12:06 PMblueheronarts says:
It seems there is too much water flow and you have no control. You might want to take a look of this decent "made in China" water brush pens on eBay: http://Stores.eBay.com/blueheronartscom which comes with water pump with an adjustable knob. The cost? As low as 0.99/each.
Jul 2, 2009. 11:58 AMblueheronarts says:
I am a big fan of water brush pens. Thank you for sharing this very interesting idea, but it seems you got no control on the water flow with this kind of pre-filled watercolor pens. I have found something from China that to have a water knob to control precisely the water in and out. Why don't you take a look in my eBay store and you can get a adjustable fountain brush pen at the same price.
Jun 30, 2009. 8:51 PMphoenyxashe says:
I took a quick look at the link... don't bother with these. They look almost exactly like a set I got at a craft store in the scrapbooking section. $5 for three versus $7 for one, I thought was a great deal. The problem is, there's nothing to prevent backflow, which the more expensive brushes have. So I'd be working on a wash.... and find my pigment had been sucked up into my reservoir. Okay for a wash... not so good for the detail work. I'm very interested in trying your method to see how they work.
Apr 9, 2009. 3:54 PMlootsvele says:
this is excellent! I have just started using watercolors for my journal and the waterbrushes are expensive! Thanks for the great instructable! Lotus
Oct 18, 2008. 8:01 AMraygeeknyc says:
Do you really see any reason to rinse out and keep the inner narrow white-capped tube that was holding the colour? It seems that just the blue cap on the lower chamber is all you need.
Oct 24, 2008. 6:43 PMraygeeknyc says:
I did and I have - I've found that they work great without the inner tube and there's that much more room for water w/o it.
Oct 22, 2008. 5:42 PMCrystalDyes says:
Way to go! This changes things for me. I am a dyer and we can buy some very expensive refillable brushpens that get screwed up fairly quickly. This is a great alternative for using to do some delicate dye painting such as on silk. 2 thumbs up on this idea.
Oct 16, 2008. 6:21 PMdhawktx says:
I use a small flip top bottle to refill my waterbrush in my guerrila painting kit. One of these could easily be filled with ink instead...
Oct 16, 2008. 12:56 PMshwa says:
I'm using this method for liquid flux when soldering.its easier,much more precise and there is no spills.I'm using Pentel brushes which are very good and cost $1.50 in local store.
Oct 10, 2008. 5:08 PMSeamusDubh says:
I wonder if you could use it with regular black ink or even slightly watered down ink and use like a Sumi-e type brush.
Oct 16, 2008. 12:54 PMbettbee says:
Arrgh, Pitt brushpens! Nooooo . . . . . I'm probably ruining you for all time for your Pitt pens here. Go check out Staedtler Mars Graphic 3000 duo. OMG. This is the most flexible and wonderful brush marker that I have found (outside of the real brush pens like these Elmer's ones or the much better Pentel Color Brush, all of which are entirely different from a felt tip brush marker like the Pitt.) The Staedtler Mars ones have many shades of black and grey, as well as a full color palate, so you can really go crazy. Also the back end of 'em has a regular, relatively fine, and fairly firm felt tip on them so they are truly versatile. And if their size indicates anything they hold a fair amount of ink. Actually if anyone has figured out how to refill these Staedtler ones I'd love to experiment with that.
Oct 11, 2008. 1:30 PMSeamusDubh says:
Ok lets try this in order. Cool. Welcome. Thanks. Sweet! I'm glad I could help.
Oct 16, 2008. 12:47 PMbettbee says:
I also discovered these little items when under orders to go buy a Pentel Color Brush by my art teacher. Now I still bought the Pentel one which is awesome and a much better brush, but I like these little guys as well. The EXACT SAME ITEM as these Elmer's ones is on sale at Pearl Paint under a snootier name for several times the price. I think in the mid 20-dollar range. Ridiculous! Another note; you can also buy nice sumi ink and fill the reservoir with that instead of water and have a fairly nice ink brush as well. (But the Pentel one is under 10.00 so you should probably get that because it has a nicer brush, then use the nice sumi ink to refill it instead of buying their refills.)
Oct 16, 2008. 12:37 PMogorir says:
these are nice and pretty cheap for a commercial offering: Aquaflow bushes @DickBlick. I use them filled with 70/30 india ink and water for a gray wash, but they'd work just fine for water.
Oct 12, 2008. 12:27 PMshooby says:
Pretty cool. You can do this with highlighters by the way, and also with prisma color markers, although you'd need rubbing alcohol to clean the prismas initially.
Oct 11, 2008. 11:47 PMredzepeda says:
Awesome, I bought the regular waterbrush for about 6 bucks and all it does is hold water. Your idea is awesome.
Oct 11, 2008. 5:12 PMUncle Kudzu says:
this is great info! i own one of the plastic travel brushes that's basically the same thing but cost more. and yes, i do load mine with black India ink sometimes, and yes, you can dilute the ink with water. with more than one brush, one could get different shades with different dilutions. (i used non-waterproof ink, FWIW.)
Oct 10, 2008. 5:20 PMcanida says:
If you reply to the other commenters directly, they'll receive notification of your response! Sweet project, btw - easy, and a great idea.
Oct 10, 2008. 7:32 PMGorillazMiko says:
Awesome! Great job, looks easy to do, my brother did watercoloring for a while but gave up, maybe if I show him this, he'll get back into it. Thanks! +5/5 stars.
Oct 10, 2008. 11:39 AMaliceownsj00 says:
that is not a bad idea, I work at a craft store and I think the water brushes we sell are ridiculously over priced lol
Oct 10, 2008. 7:28 AMRobotrix says:
Nice work! This is a pretty good idea. How long does each water charge last? also, lol @ paintastics!
Oct 10, 2008. 4:12 AMresidentevil5 says:
Nice idea!......Now I have to find something similar to that pen here in davao.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:El Rey
I like to make pictures.
