Introduction: The 10min IPhone (or Smart Phone) Tripod Mount for 3.5 Cents
Seeing all the shaky video online rom iPhones and smart phones is getting to me. Although I encourage people to make videos with what they have sometimes a little trick can go a LONG way in improving the quality of the shot.
This ible will show you how to make a iPhone or Smart phone tripod mount in 10 min using basic tools in your shop. With this you can attach the phone to a tripod. Also i find attaching it to a mini tripod gives you a handle that you can do way better hand held shots that are exponentially more stable and watchable.
Here is the video of the build:
Step 1: Tools and Materials
For this you will need
Tools:
Tools:
- Handsaw i prefer the fancy dancy Japanese saws as they cut really nice in PVC
- Miter box
- Drill
- 13/64 drill bit
- 1/4-20 tap
- coarse file
- Utility knife
- Marker
- Carpenters square
- Vice or clamp to hold the PVC when cutting the slot for the phone
- Really messy bench top (not needed but good for a ible 'Cool factor'
- 3/4 inch PVC preferably thick walled (either plumbing or electrical (the cream color or grey color) PVC will do)
- Mini tripod (you can get these at WallMart or discount store for a couple dollars
Step 2: Miter Box Time
First 2 cuts
- Using the miter box cut one end of the PVC at 30 degrees
- Next estimate 3-4 inches (This high accuracy measurement has a very technical term' SWAG' to it (Scientific Wild Ass Guess)) and cut the other end of the PVC with an apposing 30 degree cut
Step 3: Drill the Tripod Mount Hole
The tripod mounting hole magic...
- On the short side SWAG the center of the tube at the short end of the longitudinal 30 degree cut... Confused by the big technical terms? Then check out the pictures
- Drill a 13/64 Hole
- Then tap it 1/4-20
Clamp the PVC down when doing this but the PVC is soft enough you should be able to hand hold it like I have.
Step 4: Second Two Cuts
Second 2 cuts
- Using the carpenters square rest the PVC in the crotch between the black plastic and the metal ruler this will allow a square line to be drawn along the length of the PVC and mark the longest edge
- Measure the width of the phone and subtract a 1/16" from that number
- mark two more lines on either side of the first line drawn using the first line as the center
- Put the PVC in a vice and snug it up but dont crank down on it. We want it just tight enough to hold the PVC while cutting it and no more
- Cut along the two outside lines
Step 5: Attach to the Tripod and Deburrrrrr
Attach the PVC now to the tripod and using the tripod as a handle deburrrrr rrrr rrr rr all the edges
Then after the deburrrrrr ing do a final clean up with the course file
Step 6: Mount the Camera and Use That Bad Boy for Steady Shots
Place your phone in the holder and take some shots. This is a tight fit FYI and if you have any plastidip <- (click the link if you don't know what plastidip is)coat the clamp areas that touch your phone with it (and let it dry for 4 hours) this will give it a rubbery grip.
Here is the video we did for this build if you want to see one built
