3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The 1st TRULEY Aerodynamic paper airplane
Every one knows that paper airplanes would not fly if it weren't for lift. So one day while looking through a book of paper airplanes I saw a "twirly bird" you know those little helicopters that are just a crude propeller and a stick down the middle that you rub between your palms so it will fly? And it said to fold a piece of paper in half with a straw in the center, and then to glue the other side shut. This creates a very good airfoil for no trouble at all, and so I thought- Why not use that in a paper air plane? After a series of tests this is what worked best for me, but performance can vary big time with a few errors (don't worry though, I have plenty of fixes you can try).
BTW: I ran the math and this thing has an average 6 to 1 glide ratio, but my best is around 19 to 1
SUPPLIES:
printer paper x1
your run-of-the-mill bendy straw x1
This takes five minutes so please try it out!
The videos are the final product
Step 1THE SUPER EASY STEP!
  • last photo ←
My paper airplane is what most people call the "classic" paper airplane (long, slender, delta wings) so check the picture and if you know how to make it (and you probably do) go ahead and skip to step two.
If you don't know how to make it, just follow the pictures:
VIDEO #2
9 comments
May 23, 2012. 12:16 PMELEMENT777 says:
awesome design and i agree its very aerodynamic
May 8, 2010. 3:15 AMiwancoppa says:
I did a review of this guide, and have two conclusions.
I made 5 paper gliders, and tested them all with and without straws, and then i cambered the wings, and tested again.
My conclusions are:
1. the gliders worked better WITHOUT the straws.
2. if the leading edge of the wing was folded down slightly, or cambered, it increased the performance of all  of the gliders.
hope this helps
Feb 2, 2010. 6:55 PMInventor X says:
Would notebook paper work for this?
Is it sturdy enough?
Please answer.
Aug 3, 2009. 2:03 PMorun ultim says:
added a tailfin but I haven't tested in an open space yet.
Sep 2, 2008. 1:15 PMmattias law says:
i used a pencil instead of a straw and got the same affect. i didnt really see all that much difference. a better glider, one i designed is here.
http://www.instructables.com/id/mattias_super_awesome_glider/
Aug 1, 2009. 3:29 PMorun ultim says:
in theory the empty tube of the straw should be lighter then the pencil. So physics disagrees with you
Mar 17, 2008. 3:05 PMGorillazMiko says:
Nice, but could you embed the video? I will be here if you need any help.
Mar 17, 2008. 3:38 AMgmjhowe says:
I like how the plan has different options at the end. makes it a bit more varied. looks sweet as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:inventor1488
