Step 8Connect wires
iImage Information
Now all that is left is to connect the wires and resistor and slide the LEDs into place. I have the positive legs on the bottom so the red wire was trimmed to about 1ââ¬Â past the battery and soldered to the resistor which is then soldered to the positive legs of the LEDs. You should do this soldering while the LEDs are OUTSIDE of the holder. Otherwise you risk melting the plastic. After you solder the red and black wires you should have enough room to slide the LEDs back into the holder and push them through the holes. I used a small screw driver to push on the clear plastic casing. DO NOT push on the legs they will bend and you might create a short. Also make sure that your black and red wires are not touching and that the top and bottom legs never touch! You can always use electrical tape to insulate the exposed parts from each other.
