The 3 dollar headphone stand by faileas
A fairly quick, and easy headphone stand design that can be scaled to any size. It actually costs less than 3 dollars - the baton costs about 2 singapore dollars and the MDF base costs about 2 dollars for 6.
These are the basic tools and materials i used, though i seem to have forgotten to have the fairly standard file i used included in here. Shown
Materials
1x baton of wood - i used a 25x25x450mm baton with a trench cut in it - it looks nice, and its slightly easier to work with as you will see later.
screws - at least 1.5 as long as the wood depthwise - since we'll be screwing together the wood. I used 3.5mm x 40 mm screws
pin vise or similar with a 3.0mm  (or slightly smaller than the screws) bit for pilot holes.
1x 10mm x 10mm x 6mm MDF or other wood for the base.
Tools:
Essential - A saw, preferably a good one but you can make do with a slightly crappy one
                    some way to accurately remove a fairly large amount of wood - I use a gourge
                    A file or rasp to smoothen things while working on them
optional but heavily recommended - countersink bit (i didn't use one, i used the gauge, and the chisle bladed hobby knife to do a messy poor man's countersink
Optional
Mitre Box - I didn't use one for my original. they do make a lot more possibilities available
Step 1: Sizing and estimation.
You'll need to cut two pieces out of your baton. The first piece is longer and serves as the vertical basis of the headphone stand, and the second is the crosspiece for the stand. For former cutting the baton as square as possible is good, unless you want the crosspiece as a handle. Aim to have the vertical beam tall enough that without the crosspiece, the headphone can rest on it without touching the base.
Vinsu says: Mar 27, 2011. 1:08 PM
I'm going to use this but as wallmounted, thus little different version. Thanks for the idea:)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
