...Which is pretty awesome, because people in less privileged areas would be able to use this, as mentioned in that article. So, my friend and I decided to give this a shot...and where else better to do it than on instructables!
The only part that really cost anything for us was the glass, because we didn't have it on hand. This was bought at Home Depot and a sheet of 12"x36" was bought, which cost a grand total of $10. We only used half, so it technically only costs $5.
All the other materials are from around the office and around the house, which cost us nothing, as it was really just trash.
It's great for cooking cookies, among other things. As you will see, the glass and extra weight provides added pressure, plus the heat which aides in the cooking of the food. As always, we recommend using a food thermometer before you eat the food to ensure the proper temperature of the food that you eat to prevent food poisoning.
**Disclaimer: We do not assume any responsibility for the quality of the food nor the quality of how cooked it is. By using this cooker, you assume that all food is safe to eat and do not hold the author of this Instructable, his affiliates, Instructables.com & their affiliates responsible for any of your misactions.
Remove these ads by
Signing UpStep 1Step 1: Gather Materials
- 2 Cardboard Boxes at different sizes
- Scrap Paper
- Black Spray Paint
- Glass Panel
- Duct Tape
- Aluminum Foil
Tools Needed:
- X-acto Knife
- Scissors
- Glass Cutter
- Paper Shredder (Optional)
- Bricks or Canned Food
- Food Thermometer
I would like to correct one aspect of your engineering: I did a quick calc, and the weight of the glass isn't holding in any significant pressure. I estimate the glass weighs about 5 lbs and has an area of ~200 sq in. That's 0.025 psi. Even if you add 15 lbs of bricks, that's only 0.1psi.
Yes, I'm an engineer and I understand the gas law inside and out. PV=nRT
Excellent instructable though.
Did pretty good insulation. (spent a lot of money and time as well)
Maximum recorded temperature is 215 Fahrenheit - 101 Celsius
I want to move it up to 250 Fahrenheit.
I think my glass window is not air tight.
How can you air tight a solar oven?
Any idea???
--regards--
Hope this helps! Please let me know how it turns out!
Try something like such: http://www.acehardwareoutlet.com/productdetails.aspx?sku=998033846&source=GoogleBase
What does a WinBoard look like? Could it be also that your container is materially porous?
Another suggestion is to have a finishing grade sanding sponge with you. After you are done with your cut, lightly sand the edges of the finished glass to they are unable to cut you (this is also called seaming the glass). This will also protect against stress cracks from a chipped edge.
I have cooked cookies in this box (and forgot to take picture =/ ). On a sunny, Maryland day, around 86 degrees (Fahrenheit), it takes about 20 minutes, although they came out burnt. The cooker was in direct sunlight. Our thermometer didn't record the temperature that high, so we couldn't really read the temperature.
I have to agree with you that, because the glass isn't focusing the sun's rays, the box will not catch on fire.
