Step 8The Engineering Behind It All
The shreded paper functions as a type of insulation. In its place, straw can be used. The paper and straw actually also holds pockets of air which is heated by the sun. Air is preferred over metal because metal can heat easily being a conductor; likewise, heat can be lost from the metal if the external heat is not constant. The paper acts like an insulator, so once the heat is trapped in the pockets of air within the stuffing, it will not escape as easily.
The foil helps focus the sun's rays down into the box.
The black paint within the box is a demonstration of radiation. Being of black color, there is absorption of the entire spectrum of light. As light is a form of energy which is converted to heat, the food will be able cook.
The glass and bricks keep an even amount of pressure through out the box so that, in addition to the heat, the temperature in the box will also be raised as a result of the pressure applied and that builds up within the box from the sun's rays. This helps the food to cook quicker.
Be forewarned that opening/removing the glass will release all the heat that was building within the box. If checking the temperature of the food, please make sure that you are absolutely sure that it is ready to be checked, otherwise you'll have to wait again for the pressure and heat to build up again.
So, having said that, have fun and get some good food cooking cheaply!
Yes, I'm an engineer and I understand the gas law inside and out. PV=nRT
Excellent instructable though.
I have cooked cookies in this box (and forgot to take picture =/ ). On a sunny, Maryland day, around 86 degrees (Fahrenheit), it takes about 20 minutes, although they came out burnt. The cooker was in direct sunlight. Our thermometer didn't record the temperature that high, so we couldn't really read the temperature.
I have to agree with you that, because the glass isn't focusing the sun's rays, the box will not catch on fire.
