The (5 Gallon Bucket) Bag Dispenser/Recycler DIY ~store/reuse/recycle
478
19
Posted in HomeLife-hacks
Introduction: The (5 Gallon Bucket) Bag Dispenser/Recycler DIY ~store/reuse/recycle
About: hi there. on this instructable channel i'll be covering all types of DIY solar power projects (as well as off-grid/survival/green living projects) that are easy to make out of readily available products and ...
in this instructable i'll show you how i made a plastic bag dispenser/recycler. great way to store all those extra plastic bags.
Step 1: Watch the Instructional Video...
Step 2: Read Description...
The "5 Gallon Bucket" Plastic Bag Dispenser/Recycler!. Easy DIY. stores 100's of plastic bags. easy to make and use! simple "thru-the-lid" top-loading design makes it easy to load it up with no hassle. great way to store (and reuse) all those plastic grocery bags. only things needed: a few simple tools and a 5 gallon bucket. tip: paint it or wrap with wallpaper for a custom look.
Step 3: Now... the Build...
first step... pick a bucket. i went with the full 5 gallon bucket
Step 4: Next, Let's Make the Outlet...
flip the bucket over and drill a 2.5" hole near the bottom on the side of bucket
Step 5: Then Sand It...
sand the edge of the hole that you just drilled. (you don't want the bags catching on any rough areas)
Step 6: Next, Let's Make the Inlet...
drill a 1" hole in the center of the lid...
Step 7: Now Cut Slats Outward From That Hole...
cut about 8...
Step 8: Then Smooth the Edges Out...
smooth out the edges with tin snips and or sand paper...
Step 9: Now Add the Bags...
all the bags on the couch fit into the bucket
Step 10: Now Just Pull Them Out As Needed...
holds tons of bags... great way to store, reuse and recycle. i haven't tried, but you might be able to use this dispenser with other items too (shop towels, rags, paper towels). for custom look, paint it or wrap in wallpaper
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    That's a neat storage solution, we have so many of those in the storage closet!
