loading
Picture of The 5$ Karduinoss pad
So, looking at these Kaoss pads and alike hardware, I found that there is hardly any point in this device being so expensive, when you just want to use it as MIDI controller.
Going through my parts bin, I found a Synaptics touchpad from an old laptop and figured this should just work as a replacement.
Ok, when I say 5$, i mean really cheap. Clearly a loose arduino is already 20-25 USD (but you can replace it with just a bare ATMEGA168 chip for ~2 USD) , and this touchpad would probably cost you some money aswell, when you are not able to salvage it from an old laptop.
WARNING: the Kaoss pads and similar hardware all have built-in audio outputs, this project does not ...
Step 1: Find the signals
Picture of Find the signals
After some brief google (and going through the mostly pointless documentation) I found this website that helped me a great deal :
http://sparktronics.blogspot.com/2008/05/synaptics-t1004-based-touchpad-to-ps2.html
This website had the picture you see here. From this I figured out which of the testpoints on the board (wow, many!) where connected to these 3 pins. (see second picture).
I'm not quite sure if the T1001 controller is similar in pin-out to this controller, but the signals shouldn't be too hard to find if you know what to look for.
trogper1 year ago
and photo
https://dl.dropboxusercontent.com/u/4533932/IMGRES/synTP.jpg
trogper1 year ago
I've got Synaptics touchpad prom older HP notebook
I connected it to arduino, loaded your program, but it doesn't do anything
the chip has T22, T11, T10 connected to same pins as your.
old PS/2 mouse worked with some program I found.
reply to trogper@gmail.com
TheLegoDJ4 years ago
Any way this could be implemented without the us of an arduino? As in a Joystick to midi connection setting up an wired xbox controller or any other joystick?
fetchtables4 years ago
Do you think this will work with a touchscreen? I'm thinking of putting an led array under one so it looks like the Kaoss pads.
sukoa4 years ago
I don´t fully understand it, is this a stand alone synth or does it requieres from a computer to work as a synth?
Thanks!
i got the synaptics pad soldered successfully and can use it as ps/2 mouse (Standalone, got none arduino at the moment) - but I want to ask how I can interface the "ready" device (pad + arduino + your code on the arduino) with windows 7 as midi device? is there an windows port for ttymidi or is there another way to attach this thing as midi device in win 7? thanks
buZztiaan (author)  xenomorph1505 years ago
There doesn't seem to be a ttymidi alternative for windows (that I can find ...), but hackaday.com had a link to this application that will let you use a touchpad as a MIDI controller through a normal ps2 connection : http://www.livelab.dk/touchpad2midi.php Also, I'm looking into replacing the arduino with a teensy, to get 'real' usbmidi, which should work without driver in every operating system.
crapflinger5 years ago
isn't this more of a "possible way to hook a laptop touch pad to an arduino" kind of thing? i don't see anything about how to actually use it as a midi controllor or as a kaos pad...
there aren't really any instructions on how to do much of anything here...maybe you should do this as a forum topic to get some suggestions on what you're doing untill you've got enough done to make a full instructible
Agreed - it needs a little more stuffing to be a full instructable per its title.
*I do think this is really neat, never thought before how to interface with one of these...
buZztiaan (author)  frollard5 years ago
and it will, as soon as I have some finished programming to post ;)
well...i guess the deal is that you don't have to press publish on an ible if it's not finished....it doesn't add any benefit to publish something that's unfinished (or at least not mostly finished)...and you end up with a lot of comments like you've gotten so far (i.e. why'd you publish this if it's not finished)
Bongmaster5 years ago
nice :)
i got a whole bunch of touchpads i wanna put to use XD
