The 5 minute instant hand warmer!
 by junits15
Everybody has seen them, the instant hand warmers sold during the winter months for insane prices. However In this instructable Im going to show you an easy way to make an instant handwarmer with things that you proably have liying around your house!
Its a little odd for me to be posting this in the middle of summer, but in hopes of another stay warm contest I would like to see your feed back to help improve this instructable.
EDIT: BE SAFE
please avoid direct skin contact with the solution! I am by no means a chemist, I do not know how safe this reaction actually is.  I've heard several people say several different things.  Some people claim this produces hydrochloric acid, but I never got burned from touching it.  Whatever is actually happening doesn't matter, please be safe and do not touch the solution or inhale the fumes! Thank you!
EDIT: Published in Popular Science! :D
http://www.popsci.com/diy/article/2012-02/5-minute-project-hand-warmers
Step 1: Gather the materials
There are only 4 things needed to make the handwarmer, all of them are very easy to aquire, if you dont already have them.
*one large ziploc bag
*one smaller ziploc bag
*some calcium chloride ice melter pellets
*Water
Thats it!
really it is!
shannonlove says: Apr 22, 2011. 6:19 AM
The reaction of Calcium Chloride and water is CaCl2 + H2O--> Ca(HO)2 + 2HCl. Which is calcium hydrate and hydrochloric acid.
I am pretty sure they mix some type of base with the Calcium Chloride to react with the hydrochloric acid to turn it into a common table salt (NaCl) and carbon dioxide (CO2). The CO2 is the gas produced.
Know_CaCl2 in reply to shannonloveJul 18, 2012. 8:12 AM
Please note, this is not correct chemistry. An acid and a base cannot co-exist in the same solution. The CaCl2 reacts with the water and releases heat...an exothermic reaction. Calcium Chloride pellets can be purchased under the trademark brand Presone Driveway Heat or Qik Joe at hardware stores, home improvement/big box stores and the like during pre-season and winter months.
shannonlove in reply to Know_CaCl2Jul 18, 2012. 10:15 AM
It's actually fairly common to find dry combinations of acids and bases. The most commonly known would be baking powder which is a combination of sodium bicarbonate (base) with tartaric acid (acid). They do not react until mixed with water. Then they react and produce CO2 used in lea
In this case, however, I was wrong because I neglected that CaCl2 is an ionic compound. When dissolved it goes CaCls-->Ca(2+)aq + 2Cl(1+)aq. The ionic dissolution creates the heat from the energy stored in the bond.
My chemistry is apparently a bit rusty. Not a lot of call for it in the programming biz.
heathbar64 says: Oct 4, 2009. 7:19 PM
I think I remember that regular old rock salt is calcium chloride. Have you tried using it? I never checked what the little Ice melting pellets are made of, but I know they are way more expensive than regular rock salt.
Know_CaCl2 in reply to heathbar64Jul 18, 2012. 8:14 AM
Rock Salt is sodium chloride NaCl2. Calcium chloride is CaCl2. They are two different chemicals. Calcium chloride pellets are exothermic which provides the heat releasing action when exposed to moisture (ice, water, etc.) Rock salt is not exothermic and will not work in this application.
Fishpail in reply to heathbar64Nov 29, 2009. 12:04 PM
I believe that's SODIUM chloride, friend.
heathbar64 in reply to FishpailJul 2, 2010. 7:07 PM
The way I learned it, table salt is sodium chloride and rock salt is calcium chloride. But then, I'm just a hillbilly.
Bert99 in reply to FishpailJul 2, 2010. 8:50 AM
ur rite it is
junits15 (author) in reply to heathbar64Oct 5, 2009. 1:23 PM
I'm not sure about regulat rock salt, and I havent tested it because I dont have any on hand, but when I get some I might give it a shot
Fitwit says: Feb 26, 2012. 8:42 AM
ZipLoc bags and the like are NOT water-tight. Plan on leaks.
ariearie says: Feb 25, 2012. 8:55 AM
Don't leave those bags in the car, hoping you could use it when your get onto a frozen car... when it is freezing outside, the water in the inner zip bag will be ice and it will not work..
AnaisM says: Nov 4, 2011. 11:47 AM
Is there are specific reason why we should squeeze out the excess of air, or it is just to make it more compact and less likely to burst?
nintwala in reply to AnaisMFeb 24, 2012. 11:54 AM
its probably so that you can break the inside bag instead of the outside cause the air will cause some cushioning.
junits15 (author) in reply to AnaisMFeb 20, 2012. 8:45 AM
Just so it doesn't break when you open it
NatNoBrains says: Dec 17, 2010. 6:48 AM
LOL 5 Minute and instant at the same time!
ducktape.mac says: Dec 3, 2010. 6:21 PM
i like the idea, but the chlorine stuff, where can you get that? if you can tell me where to get it, i plan on making it!
junits15 (author) in reply to ducktape.macDec 4, 2010. 7:00 PM
its ice melter, get it at like lowes or someplace like that but its not the salt kind of ice melter
ducktape.mac in reply to junits15Dec 4, 2010. 7:32 PM
is it cheap?
junits15 (author) in reply to ducktape.macDec 6, 2010. 3:32 PM
kinda, if you get a little jug
ducktape.mac in reply to junits15Dec 7, 2010. 3:09 PM
okay, thanks.
beehard44 says: Nov 18, 2010. 8:04 AM
finally! i am searching ideas for my MRE warmers (i was able to preserve them) and originally thought about 0000 steel wool ground into filings and vinegar.
Mr Cheeseo says: Dec 1, 2009. 4:58 PM
How hod does it get and for ow long?
junits15 (author) in reply to Mr CheeseoDec 3, 2009. 5:42 PM
The heat output and time is determined by the ammount of CaCl2, simply the mor CaCl2 the more heat and the more time, just becareful not to put too much or you could melt the bag!
Mr Cheeseo in reply to junits15Dec 3, 2009. 6:10 PM
A very fine line that deserves some very not so fine experimentation.
END TRANDMISSION
kariswg1 says: Oct 1, 2009. 4:00 PM
WOW, my wife buys the ready made hand warmers during our cold Michigan winters. I just tried this out and I am going to make some up for her to carry in the car. I will check out thicker bags, because they really get very warm. Thanks again.
pyroal in reply to kariswg1Nov 28, 2009. 8:54 PM
i live in michigan to and this will help when i go hunting
junits15 (author) in reply to kariswg1Oct 5, 2009. 1:36 PM
Glad you like it! Try some glad freezer bags they seem to work very well.
futeng says: Aug 6, 2009. 10:20 PM
Where can I get the calcium chloride? Also, to make this better, I would suggest adding something like a needle to make it easier to pop.
junits15 (author) in reply to futengAug 7, 2009. 11:19 AM
its hard to find them off season, but during the winter they are sold at any lowes or home depot, sometime even grocery stores have them I don't lnow if I would really like to have a needle in something like this, it proably best to use focker's idea.
kyro159 says: Aug 6, 2009. 10:38 PM
where could u get the pellets???
junits15 (author) in reply to kyro159Aug 7, 2009. 11:18 AM
Focker says: Aug 7, 2009. 5:44 AM
To pop the small bag, just rub the seal and it should slide itself open.
junits15 (author) in reply to FockerAug 7, 2009. 11:00 AM
oh thats a great idea! i be sure to update it!
turbonegro says: Aug 7, 2009. 5:23 AM
I wouldnt want a needle in my handwarmer
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
