loading
Step 2: Make the Guts
The guts of the A-Team Egg are made up of only a few electronic parts. The brain is a Picaxe M08 microcontroller wich can be easily programmed to play music. The ability to make sound is already implemented in the chip. It is programmed in an easy BASIC dialect. As you can see in step 3 the code is only 5 lines long.
To make it "sing" you have to add a piezo speaker (it is also possible to add a speaker, but for the bleepy effect i use a piezo). To make it sensible for movements (shaking the egg) I added a tilt switch.
First of all make the Picaxe-08 Proto Board by following the instructions from Revolution Education .
Then add the tilt switch between V (+5V) and Pin 4. You also have to solder the pull down resistor (10k) between Pin 4 and G (ground bus or 0V).
To connect the piezo speaker to Pin 2 I added a small wire between Pin 2 and the conducting path (see image). Then solder the piezo speaker between the path where the wire ends and G. Thats all for soldering. Easy, isnt it? Go to the next step to program the brain.
I had to miss a couple episodes when I went running. And I missed one while I was taking a shower but that's Ok because it had Boy George in it. And instant Netflix doesn't have the last episode
I LOVE THE A-TEAM!!! I've watched almost every episode!
I'd pity the fool!
"I aint' gettin' on that plane!"
I cant tell which is more baddass, that Egg or Mr T himself?
Nice! This will let me use up some AAA battery holders (I accidentally ordered AAA's on fleabay. This might also allow for using a smaller egg shell..)
EGGcellent! :D You should make a Mr. T stencil so you can use spray paint and paint Mr. T on all the eggs! :D
Yes, I had the Idea of making a stencil, but I had not enough time for it
Excellent! :) "Yo Fool!!!" :P
About This Instructable
6,730views
13favorites
License:
Bio: I like to play with electronics and other fun stuff, modify things to make them more useful or just more funny, putting things together that ... More »
More by mischka:Vampire Sock Puppet LED Flowers monoPong
Add instructable to:
