3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The A1.2 Mini Lego Assault Crossbow
This is the second modification of the A1, and probably the most significant one. This new crossbow can be disassembled into 5 pieces, and then reassembled into the crossbow in under 30 seconds (my record is 27 seconds anyway). It also features a new type of trigger: a modified gear trigger, which instead of having the interlocking gears inside the gun, the interlocking gears are to the side of the crossbow (this saves on space). The length of the crossbow has also been slightly shortened, and a new sight added. The gun fires a 2x4 (F) brick (F means with a flat piece on top). It has a range of 35+ feet (depending on rbs) and it is very powerful and accurate.
Improvements over A1.1:
-Can be disassembled into 5 pieces, then field assembled in under 30 seconds
-A new, reliable gear trigger
-Slightly shorter in length.
-Better sight
My Website: http://sites.google.com/site/bblegobrickworks/Home
Step 1Bottom Connector Piece
This is a very simple piece which is used to connect the bottom pieces of the crossbow when you assemble it.
12 comments
Feb 18, 2012. 4:19 PMSlurpee801 says:
Just pointing this out but... None of these are really crossbows. =\. The definition of a crossbow is: A weapon consisting of a bow fixed crosswise on a wooden stock, with grooves on the stock to direct the projectile. These look like crossbows, but you don't really have a bow on there. Bow - a weapon for shooting arrows, composed of a curved piece of resilient wood with a taut cord to propel the arrow. So my point is... These are crossbow shaped slingshots. Not crossbows. Just sayin'.
Dec 27, 2011. 10:13 AMmeaner6788 says:
where are the wheel things that you put the rbs on
Dec 23, 2010. 9:29 AMkristianm3 says:
I can't find the two 2x1 in picture 4 with two holes in each one. Is there possible to use ones with one hole by any means?
Feb 1, 2011. 12:11 PMking kolton9 says:
use a 1x4 with holes (i think, if not, then yes use what you said)
Feb 20, 2010. 2:42 PMking kolton9 says:
does the blue thing have a circle hole?
Feb 19, 2010. 7:36 PMking kolton9 says:
y do you need the counter weight rubber bands because on ure site u said u wouldnt need them tobe stronger?
Jan 23, 2010. 12:59 PMnatebug1997 says:
better then my old semi but simpler that is awsom!!!!!!!! :D
Nov 25, 2009. 9:23 AMxraptor777 says:
 Do you think you could make a semi-auto pistol that shoots rbs? not bricks? cuz my parents think its a little dangerous. And i was just about make the C3.3...
Nov 24, 2009. 4:03 PMxraptor777 says:
 THAT IS SO AWESOME!!!!! good job!
Jul 31, 2009. 3:07 PMsmilee says:
Made!
Jul 19, 2009. 4:27 PMmini grant says:
Cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Bitterberry9
