iImage Information
Hello everyone, This is my lastest gun i have made, The AF7 sidearm! I think this gun will be liked, as it is sturdy and reliable, and doesn't look half bad. The curved handle was thoght up by TheDunki, i just made it smaller. The trigger system was origially for the TDS so it has a broken peice, but easily be replaced by a black and dark grey connector. The gun itself is sturdy, making it capable of holding many rubberbands. Complementing this is the ram, which has a spring on it( not needed) so there is no more need to add tape to your ram( but it does take away a small teeny weeny bit of power) It has accurate plastosites(haha look i made a joke). The mag pusher looks a lot more neat than most, and doesnt spazz out on you when you try and take it out. This gun has never jammed on me, but most of you might wonder why sometimes the rod gets stuck on something, well that's the safety thingymajig which cannot be taken off. You will understand once you will build the gun, it's not that big of an issue. It doesnt use THAT many peices but at the same time still uses a fair bit.
well. um get building my pretties.
Mush.
Step 1The handle
iImage Information
Thanks to TheDunkis.
Well it is symmetrical on the otherside so it should be easy enough to build.
This is only a one-step step
1. Build
also check out ma grenade
http://www.instructables.com/id/Knex_Grenade_19/
pleaz rate
