3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Accidental Cannon
On and off, I've been working on an all-metal (and hence non-shattering) version of the Jam Jar Jet. My latest version was supposed to be adjustable, but it turned out to be ballistic.
Step 1Do it outdoors!
When I first made this, I made it inside my shed, expecting a vertical jet of flame at most.
Instead, I had a can of burning meths ricocheting around my ears.
Oops.
(Note to self - buy fire extinguisher!)
253 comments
1-40 of 253next »
May 27, 2012. 9:50 PMboom man56 says:
how do you put a hole in the coke can?
May 27, 2012. 2:54 PMboom man56 says:
how do you put a holes in the coke can?
Dec 16, 2011. 5:34 PMAron313 says:
Put a firecracker in the hole and replace the can with 5 gallon bucket and fill bucket 1 or 2 inches with water place can in light cracker and run!!!!!!! It shoots very high you should try it.
Oct 22, 2011. 9:35 AMDream Dragon says:
Mortar or Cannon?
As a Pyrotechnician with some Medieval reenactment experience, my answer is that it's a mortar.
A Cannon is actually only one of a variety of types of gun (see also Culverin, and Bombard), and they all fire predominantly horizontally to attack walls, gates or vertical structures. It generally has a longer barrel, we call it a barrel because the very earliest ones were made in a similar way to the wooden casks that were used to transport all kinds of loose goods, including Gun powder.
A mortar fires mainly Vertically and is used to attack Horizontal area targets, like smashing through the roofs of buildings. Named after the "bowl" part of an early form of food processor called a Mortar and Pestle, a mortar usually has a very short barrel for it's bore.
As a Pyrotechnician I use mortar tubes (sometimes called Guns, in the US) regularly and you definitely wouldn't want one of THOSE to auto ignite.
Oct 25, 2011. 11:42 AMDream Dragon says:
No argument from me on that, it's all cool.
Jul 18, 2011. 7:31 PMSchober says:
I'm assuming the reason it launches is that the thrust of the first ignition is too much for the can to hold back. Why couldn't you JB weld the can and the tin together? Would it explode? Or are you worried about excess alcohols burning in places where they shouldn't be? I've read some of the other comments below and it seems like you could just make the hole a little bigger and avert explosion.
Oct 20, 2011. 7:57 PMSchober says:
Sorry, I didn't realize how frenetic that sounded until you made that comment.
May 4, 2011. 11:28 PMInvolved Observer says:
Kiteman, you rock! I can't wait to give this a try!
Sep 3, 2009. 5:48 PMMatt21497 says:
What if you hot glued the can in the can?
Mar 19, 2011. 5:40 PMilpug says:
That would make a bomb, which, if detonated with the proper safety measures, would be cool, but in this application, DONT DO IT.
Jan 18, 2011. 2:38 PMDumchicken says:
why did your door handle desintigrate?
Dec 1, 2010. 4:08 AMwhoelsebutaelx says:
To take the top off the coke can a can opener works great. ive taken the top of coke cans with can openers before and it works quite well.
Aug 6, 2010. 3:38 AMtfrost1980 says:
My Uncle taught me to make this same cannon except we used multiple cans and lighter fluid, not a new design its been made since at least the 60's.
Jul 15, 2010. 9:57 PMRokko8652 says:
Would denatured Alcohol work? Don't want to have another container of stuff for homemade... Artillery... lying around incase friends don't brush up on local laws and call the police.
Apr 2, 2009. 8:14 AMstefannasehi says:
can i use other stuff besides meth spirits: alcohol, laquer thinner, turpentine (etc) ?
Jun 29, 2009. 3:52 PMMathias Re'eh says:
so charcoal starter?
Nov 4, 2009. 11:54 AMimshanedulong says:
That stuff is barely flammable!
Feb 16, 2010. 11:43 PMMathias Re'eh says:
just get it burning :o
Mar 11, 2010. 8:43 AMimshanedulong says:
Trust me. A acetylene torch won't get that stuff going. I think it only works with charcoal. Even if you light it, It burns slower then wood! If you don't have access to any alchoholic drinks, use isopryl rubbing alchohol.
Nov 4, 2009. 3:13 PMmagickaldan says:
I do something similar except for a fuel I use firecrackers, just make a hole big enough for a firecracker to be snug stick it in as far as it will go and have a 1/2" to 1" of water in the bottom of the bigger can.  Then light and get to safe distance and enjoy.  You can use any size of pot or can for the outer container because the water does all the sealing.
Nov 5, 2009. 4:26 PMgrt57 says:
I grew up doing this as well... be careful though it can lead to taping estes model rocket engines to the tops of old style model cars, and launching them off of ramps into nearby lakes... LOL
Nov 4, 2009. 3:51 PMrvmirror says:
Instead of using pliers or a dremel to open the can, use an ordinary can opener it leaves a nice clean edge.
Sep 20, 2009. 10:31 PMbackyardmunitionist says:
Cool idea man some of the best inventions were discovered by accident. One observation though, it's more of a mortar than a cannon really.
Nov 3, 2009. 6:43 PMZaphod Beeblebrox says:
do u know everthing?
Nov 3, 2009. 9:44 PMkelseymh says:
Yes.  He's a teacher.
Nov 4, 2009. 2:32 PMZaphod Beeblebrox says:
do his students know hes kiteman or is it like a secret alter ego??
Nov 4, 2009. 2:35 PMkelseymh says:
At least one of his students is also an I'bles member.
Nov 4, 2009. 2:43 PMZaphod Beeblebrox says:
what their user name?
Sep 21, 2009. 1:29 PMbackyardmunitionist says:
Correct, that is how modern mortar shells work. However the manner of firing prior to self igniting shells was different. The difference I was referring to was that a cannon generally has a longer barrel for longer range and flatter trajectory as opposed to a mortar using a short barrel for high angle short range and more of a lob type trajectory. Either way keep up the good work man.
Mar 19, 2011. 5:39 PMilpug says:
Kiteman does know everything. You know why? Because he's Mike Rowe!
Nov 4, 2009. 10:18 AMRHSeabrook says:
Methylated Spirits is the same thing as HEET in the yellow can (the red can is ethyl alcohol, not methyl alcohol and is the only difference).  You can find this in most any auto parts store or section of your favorite walmart like watering hole in the chemicals section.  Its used in cars to remove water from gasoline.
1-40 of 253next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
832
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
