Have you ever wanted to vacuum-seal leftovers to keep them fresh? Looking for a way to keep your popcorn or coffee beans fresh for longer? Want to vacuum pack dry goods for long term storage? If you answer "YES" but don't want to lay out $100 or more dollars for one of the commercial vacuum sealer machines, then do what I did - assemble your own for $30 from readily available parts! Using a $20 brake bleeder and a mason jar sealer, you can vacuum seal anything you can fit into a mason jar. I call this "the Alvin" vacuum sealer, after my late pop, who always taught me to do more with less and set aside the extra for later.
PLEASE NOTE: This IS NOT a substitute for wet-pack canning using a pressure canner. This technique will not prevent botulism or spoilage in wet-pack foods (meat, fresh fruits/vegetables). This technique is ONLY appropriate to prolong the shelf life of dry goods to be stored at room temperature ( dry means <10% moisture such as popcorn, wheat, coffee, beans, dehydrated meat, fruits & vegetables) OR moist foods stored in the refrigerator / freezer.
Step 1: Acquire the necessary tools.
You'll need:
1) A brake bleeder/vacuum pump from Harbor Freight (cost=$19.99).
2) A Tila FoodSaver mason jar adapter (I bought mine from Bass Pro Shop for $9.99).
3) A clean empty mason jar with a new lid. You can get these from WalMart or some grocery or hardware stores. Or ask your grandmother for one.
Juliettesromeo says: Jun 8, 2013. 5:08 PM
Video said it is private, how do I view this?
crash893 says: Jul 21, 2008. 7:09 PM
kill-a-watt in reply to crash893Oct 10, 2009. 5:40 PM
Won't work, sorry.
This tool need compressed air to create a vacuum for sucking moisture out of an AC system.
You could probably  take the compresser that you need for that 4.2 CFM @ 90 PSI and use the inlet of that to get you your vacuum.
If you want cheap and easy, there's plans out there to hack a bicyle pump to save seeds with.
http://www.redwoods.quik.com/webteck/george/seedsaverlinks.html
escapefromyonkers in reply to kill-a-wattJan 25, 2013. 8:52 AM
i have been reading this and wondering why a bicycle pump wasn't mentioned until now. I know i have seen a able on converting bicycle pump to a vacuum pump pretty easy. My pumps easily inflate to 100 psi, i think that is 33 bars, not sure what vacuum that is but they go higher , one i have goes to 130lbs. i onlt use the small hand bicycle pumps on the road, since they dont compare . However the one i have has a fold out foot peg ,so you use it as a floor pump and can get 100 psi out, A regular hand bicycle pump, it is extremely grueling to get 60psi, i have a collection of hand held pumps that looked great in the bike show, but were horrible on the road. What is the comparison of psi to vacuum? i since both items bicycle tube and bags are pretty small in cubic inches, it should work. I now have an interest in vacuum sealing.
Also will vacuum sealing kill any flour moths or the typical grain larvae that will hatch if you do not consume it for a long time? . Since i had a flour bug infestation due to a box of flour i hadn't touched in ten years(pre divorce food), i now freeze everything that is grain or bread mix, for a week to kill any larvae. and try and keep everything in plastic, since the work of cleaning everything, plus a second outbreak, I sealed the tiny gap around the kitchen cabinets, since some hideaways were in there preparing for the second assault. Larvae are normal, there is no way they can keep them out of foood unless they nuke it, i will stick to freezing and now vacuum seems good also.
Eric Forman (author) in reply to escapefromyonkersJan 25, 2013. 11:44 AM
I've seen the bicycle pump hack but haven't done it (since I only have one and use it for its intended purpose). In general, we're not talking about producing very high vacuum levels...so I don't see why it wouldn't work. If you try it I'd like to know how well it works.
Producing vacuum is different than producing pressure. Standard atmospheric pressure (at sea level) is 14.7 PSI (or 29.9 "Hg). When producing a vacuum you're moving air out of a container into the atmosphere, so a perfect vacuum would be 14.7 PSI outside the container and 0 PSI in the container. It's tempting to think "my bicycle pump can achieve 60 PSI, so 14.7 PSI won't be any problem"...but it doesn't work like that. When pumping air into a container, you're essentially packing more air molecules into the container from a limitless supply of molecules outside the container (the atmosphere). When trying to draw a vacuum you're trying to pump a very limited supply of molecules (in the jar) out. That's more difficult because molecules tend to spread out to fill the volume of the jar and pump in a somewhat uniform fashion. So the first dozen pumps are relatively easy...you're moving a large number of molecules. As you continue to pump, the "fill" stroke on the pump gets filled with fewer and fewer molecules each time. Common piston pumps (like the brake bleeder or bicycle pump) have a relatively low mechanical limit. A more expensive commercially available compressor pump has a higher limit, but still can't achieve ultra-high vacuum levels for the same reason (UHV requires other pumping technology).
Fortunately, to preserve foodstuffs in this way doesn't require ultra high vacuum levels. You just need to remove enough air to suffocate the ever present critters and minimize any oxidation. FYI 23 "Hg vacuum means about 77% of the air has been removed. That's about the pressure of the atmosphere at 45,000 feet (1.5x higher than Mt. Everest...well into the stratosphere). In my experience that's been plenty enough to keep larvae at bay.
Hope this helps.
pineapplenewton says: Mar 8, 2009. 2:19 PM
dose any one know of a way to hand pump a vacuum out of (or is it into) a bag like toughs space bags on TV it has to be light weight small and human powered
escapefromyonkers in reply to pineapplenewtonJan 25, 2013. 9:05 AM
you mean the ones that call for a vacuum cleaner? I believe a cheap inflatable raft pump , low pressure high volume, as opposed to a bike pump high pressure low volume, would work. There are instrucables on changing the washers on a bike pump to make them a vacuum pump, i am sure the same could be done with a raft pump. you would have to fabricate a connector to match the vacuum hose. There is a tape called rescue tape, can be found on amzon or auto stores for $10 and under , it is silicone and fuses to itself, you don't need much and it works great for making airtight connecotrs.
catnip4all says: May 28, 2011. 9:05 PM
The harbor freight pump disappointingly got about 20-22"hg after lots of sweating. Mityvac Bleeder pump decently made about 23-24"hg. Very tiring. If you want a real hand pump get the pumnseal, but it's probably already discontinued. It's rated for 28"hg. If 12V doesn't bother you then a $5-$7 pump will probably go up to 23"hg without a sweat. In the end of the world scenario, 12V supply will likely be available.
thanangell in reply to catnip4allJul 5, 2012. 2:43 PM
the pump-n-seal is still available, it seems:
http://www.pump-n-seal.com
Indigno says: Aug 14, 2011. 11:43 AM
This sounds interesting, but I'm wondering if vacuum sealing uncooked corn could possibly lead to it popping inside the mason jar...
Eric Forman (author) in reply to IndignoAug 14, 2011. 10:58 PM
No. Heat is required to pop popcorn.
snowluck2345 in reply to Eric FormanNov 3, 2011. 7:10 PM
no it isn't, popcorn pops because of the water inside it boiling, which can happen at room temperature if you pull enough of a vacuum.
Eric Forman (author) in reply to snowluck2345Nov 3, 2011. 11:26 PM
I should learn not to answer so quick. You're right, of course, but I doubt that the little hand pump here would achieve that level of vacuum.
But now you've got me thinking...I have access to extremely powerful turbo vacuum pumps at work that can get down to ~.00001 atm. I should try that.
whocares123 says: Oct 25, 2011. 9:50 PM
I really like the idea, but what a bunch of d-bags... Really, when shtf? I personally have exactly 730 days of sealed food to last when shtf...come on.
esemjay says: Aug 28, 2011. 11:57 AM
Why use your hands to pump? Your legs are stronger. Just use a longer hose and a simple support for the pump to hold it in place at your feet. Unless the pump handle isn't spring loaded. In that case you put a couple of pieces of para cord on the handle and create a toe strap.
Eric Forman (author) in reply to esemjayAug 28, 2011. 9:10 PM
LOL! I was about "that close" to making a joke about why my hands are so good at pumping...but I won't since this is a family-friendly website.
Really though, I don't find the pumping action to be very taxing at all, but I don't see any reason why your idea wouldn't work. The handle does have a return spring, btw.
hellaroms says: Aug 2, 2011. 3:36 PM
I really want to get started doing this for when SHTF. About how much more shelf life does this add? weeks, months, years?
Eric Forman (author) in reply to hellaromsAug 2, 2011. 7:42 PM
Good question for which there isn't an exact answer. Consider that the primary causes of deterioration in stored dry food are oxygen, heat, light, and time. Heat and light can be eliminated by storing your goods in a cool, dark place (such as a basement or crawl-space). This technique removes almost all of the oxygen. Commercial canning operations that produce 'survival' type dehydrated foods for long-term storage use chemical oxygen absorbers or nitrogen packing (which displaces the oxygen in the can). This is the same idea. Your vacuum sealed foods (or seeds or whatever) will last longer.
When I first wrote this instructable 3 years ago, I sealed up some gatoraide, popcorn, and a few other items. I just recently opened some of the gatoraide and popped some of the corn. It was still as fresh as the day I bought it :)
Eric Forman (author) says: Jan 16, 2010. 12:05 PM
Some jerk stole my idea and is now selling it for $79.99 at http://www.sustainableseedco.com/vacuum-sealer.html.  If you want to let him know what you think of people that steal the ideas of others, feel free to go to his site and leave a comment.  :)
catnip4all in reply to Eric FormanMay 28, 2011. 9:27 PM
The people at sustainableseedco.com didn't steal your idea. They are within the law to use your idea for sale. I notice they discontinue it because it fail to meet customer's need. Hand pumps are exhausting considering a pump that can probably do 23"hg can be had for as low as $5 minus the power supply. :)
mrkitty says: Nov 18, 2009. 12:33 PM
For $3, you can buy a replacement accessory hose from FoodSaver so you have the right connector for the accessories.  Item T17-0059.
This is a really smart tool, even if you have a vacuum packer because you can reseal food supplies while surviving a major disaster -- even without electricity!
mrkitty in reply to mrkittyOct 6, 2010. 1:00 PM
I have been using this system almost daily for about a year with the food saver hose - I cut an accessory hose in half so I could give the other half to my brother to make his own system. When you use the foodsaver hose it stays connected on its own - no second person required! This means you can use both hands to pump or alternate hands. Since you are already purchasing the lid getting the hose makes good sense. The clear tube will let you know if you are sucking fine foods (like flour) into the pump.
This is the foodsaver wide mouth jar accessory with half of a T17-0059 hose and an Actron Vacuum Pump CP7830.
I use it for coffee, dried herbs, fruits and vegetables. It is good for flour as well. Would also be good for bulk spices.
Note: I also have the regular foodsaver electric pump. I used a T-connector and it seems the Foodsaver usually pulls between 20 and 25 "in. Hg vac", which I assume to mean inches of mercury. I use this as my target pressure when hand-pumping.
blue_yin in reply to mrkittyOct 6, 2010. 9:37 AM
This is a GREAT instructable!
My one issue is that for people with small hands the pumping ( up to 25 inHG) can become very difficult, switching hands would be very useful, but not possible as letting go of the hose will prematurely seal the jar.
I find the easiest way to do it is to have someone else hold the hose tip in the jar sealer while I pump.
Anyone know a better way? Or should i just buy the accessory hose to get the proper connector so i can seal jars myself?
mrkitty in reply to blue_yinOct 6, 2010. 1:00 PM
see my expanded post above...
Laral says: Jun 18, 2010. 10:24 AM
It looks like Harbor Freight sells a better vacuum pump for only $8 more. The Mityvac Vacuum Pump (http://www.harborfreight.com/mityvac-vacuum-pump-39522.html ). It is made of polycarbonate which is an inert very strong durable material. The othe HF pump is brass which contains lead according to the manual: "WARNING! The brass components of this product contain lead, a chemical known to the State of California to cause cancer and birth defects (or other reproductive harm). (California Health & Safety Code § 25249, et seq.)." This looks like a discontinued Mityvac model because the new models are PVC, a less durable, weaker material (http://www.mityvac.com/pages/products_hvp.asp ). The finger-grip handle looks brutal compared to the new smooth handle but I'd much prefer the polycarbonate material. You can wrap the handle with foam insulation for more comfort. I'd also prefer the well-known brand name to the generic HF "U.S. General" brand name. Does anyone have experience with this pump?
Laral in reply to LaralJul 12, 2010. 2:09 PM
Update I went to Harbor Freight and bought the Mityvac: http://www.harborfreight.com/mityvac-vacuum-pump-39522.html Of note, it was the newer model that is PVC, not polycarbonate like in the HF listing. I bought it because it is a well-known brand and because the guy in the store told me they had "never had one returned". OK I could always bring it back if not satisfied. It is actually the MV8000 Automotive Tune-up and Brake Bleeding Kit: http://www.mityvac.com/pages/products_hvpk.asp#MV8000 I tried it and it worked well at pumping down a 1 pint mason jar with the FoodSaver mason jar adapter which I bought at Cabela's. It is comfortable in the hand but when you pass about 15" Hg it gets really hard to pump. The empty 1 pt. jar took me 85 strokes to get to 20" Hg! My hand was aching after that but it's a great workout. :) The same jar filled with coffee beans took me 45 strokes. After using it just 3 times I noticed a fairly loud squeaking sound coming from the pin that holds the piston rod to the handle. Here is a video of what it sounds like: Here's a closer view of the offending pin: And a close-up image of same: http://img819.imageshack.us/img819/4517/dscf001.jpg Notice how the metal pin is at an angle and not square with the handle. Also note how it has already started to dig into the plastic. I fear that after a short time, since it will get a lot of use, it will wear right through the plastic and be totally useless. Needless to say I returned it. I replaced it, not with the HF metal pump, but with the brand name pump that the HF pump is a copy of, the Actron CP7830: http://www.actron.com/product_detail.php?pid=16177 It cost me the same on eBay, $25. It has a 1 year warranty and you can get a rebuild kit for $2.50 + shipping: http://www.actron.com/product_detail.php?pid=16244 So it should last for years. No noises other than the exhaust valve opening on the pull stroke. A very nice pump.
snoyes says: Jul 5, 2008. 12:08 PM
Harbor Freight also carries a manual pump designed for this very purpose at 1/3 the price.
Laral in reply to snoyesJun 19, 2010. 9:44 AM
This one looks like a POS but I would try it to store paint and varnish. It might be OK for that. But for the current purpose, no way.
Eric Forman (author) in reply to snoyesJul 6, 2008. 10:21 AM
I looked at that one, however it looks like you need the "special" lids that come with the kit, rather than the regular 12 for a dollar Ball jar lids. Also the brake bleeder can pull over 25 inHg vacuum. The other one...well who knows? There's no gauge so how do you really know what kind of vacuum you're pulling?
kill-a-watt in reply to Eric FormanOct 10, 2009. 5:48 PM
that one looks like a cheap knockoff of the "pump and seal"
http://www.pump-n-seal.com/
The glasses at Harbor Freight look exactly like widemouth can and freeze jars. They're glass, but made such that frozen food can expand upward instead of breaking the jar. I have a ton around her to freeze chili/soup/stew/taco meat in single serving portions.
It does, however look like that you need to use their four supplied lids for their pump
Suatainable in reply to kill-a-wattFeb 14, 2010. 11:05 AM
Hi!
I've been using the manual hand pumped brake bleeder from Harbor Freight  for over a year now. It works great! It comes with several attachments and one of them works perfectly. It seals my quart seed  and milk jars so well that I have to pry them open with a can opener and usually damage the lids.
The only thing is you have to watch out for the screw on the handle rolling of on you after a while. It works it's way off after about 6 months of heavy usage. I just check it occasionally and tighten it up. I love this system, and wouldn't be without it. I love the fact that no electricity is needed, which is a plus for when the SHTF.
Oh yea, Harbor Freight had me waiting for delivery for 2 months! I didn't like that!
kill-a-watt in reply to SuatainableMar 7, 2010. 7:42 AM
take a spoon, flip it over, and press the edge into the screw thread of the jar. slide the spoon around the thread until it contacts the lid. press a little harder. The vacuum should break and you should be able to save the jar for reuse.
I have the zinc die cast version of what Harbor Freight designed a copy of. Works great.
CypherPack in reply to snoyesJul 6, 2008. 8:11 AM
One problem may be the level of vacuum, the brake bleeder seems like it will get a good enough vacuum for sure.
johnny3h in reply to CypherPackMay 1, 2011. 3:14 PM
This comment is a "little" late, but I've had the plastic vacuum pump/break bleeder for about 20 years, and when new it pulled as much as 27" Hg. Now with age, it does good to make 25" Hg, which is still good as far as I'm concerned.
I have only used it for "testing" automotive vacuum components and for bleeding/replacing automotive brake system brake fluid. Works great for one who works alone.
dasadler in reply to snoyesJul 5, 2008. 12:34 PM
Here is a link to the one referenced in the article:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92474
I think this is a link to the one mentioned by Snoyes:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96414
Laral says: Jun 18, 2010. 9:00 AM
This is a really great idea, a complete system. Are you using regular or wide-mouth jars? I would prefer wide-mouth since they are more versatile. Is there any reason not to use wide-mouth jars? It looks like the thief is using them in his video. BTW I tried to leave a comment on his site but the captcha script is broken so I couldn't. Figures.
friedenmeister says: Feb 20, 2010. 8:50 AM
 So would this work for freeze drying. Lets say i was to put some vegetables or meat in a mason jar and freeze it. Then once it's good and frozen i could come along and hook the alvin up to the mason jar and start putting it under vacuum. It seems the water should sublimate straight from ice to vapor.
Has anyone tried this? I think it might be worth it just to give it a shot.
Suatainable says: Feb 14, 2010. 10:51 AM
I found another great use for the Alvin-Vacuum-Sealer last year!
I posted last year about saving my rare heirloom veggie seeds using the vacuum sealer. It's been a great success! I now have a huge home seed bank and after recent testing found the germination rates are still very high this year.
I also raise and breed dairy goats for the milk and I used the vacuum sealer to seal my milk before freezing. I cannot describe to you the difference in the flavor of the milk after thawing. It has a fresh, and refreshing flavor that is out of this world! The milk was good before, but NOTHING like it is now after being vacuum sealed. It's kind of like comparing 2% milk with the flavor of heavy cream. It has a much richer flavor.
Thanks again Alvin! :)
Peter Mckee says: Jan 15, 2010. 10:28 PM
Do you need any special jars or are there vacuum sealing lids you need?
Eric Forman (author) in reply to Peter MckeeJan 16, 2010. 11:38 AM
No special lids needed - just the regular canning jars and lids.
mkinthegarden says: Oct 10, 2009. 6:14 PM
Just to make sure... you can remove the Food Saver top and leave only the Kerr or Ball lid, correct? The reason I don't like the Food Saver vacuum system for dry goods, besides the price and a machine that can wear out and break is that you have to buy a special lid for each jar. ( I could be mistaken)
phaedon in reply to mkinthegardenJan 9, 2010. 5:23 PM
 That's right.  Here's a YouTube video of a seed company using one to vacuum seal some seeds for storage.
darcham says: Dec 13, 2008. 7:09 PM
I love this instructible and will try it out for our dr goods. I was hoping this method could be used for wet foods as well. I first got the notion it could be done because everything on the store shelf that's wet-packed in a plastic jar appears to have been vacuum sealed. I can only guess that these food manufacturers use "preservatives" to prevent botulism. Too bad, because I was hoping to save time in our canning process.
hv3333 in reply to darchamJun 19, 2009. 4:57 PM
Anything that was hot when it was wet-packed often creates its own vaccum as it cools. I've been told that, when bottling homemade marmalade & jam (jelly) for example, you should either seal jars when the food is cold or when it's hot - never when it is warm, as that is most likely to encourage bacteria to settle & develop.
I tend to run my jars & bottles through the dishwasher (filling a load & timing setting it off to finish at the right time, I don't just stick half a dozen jars in on theor own) just before the jars are needed, so they are hot too. Alternatively, heat them in the oven. Be careful with plastics, as not all can cope with the heat & may deform - test them in the oven or dishwasher beforehand.
Unless you don't recycle (or recycle *very* little, under 10%) or your food has to travel a huge distance, glass is more environmentally friendly anyway.
fratermus2 says: Mar 8, 2009. 12:50 PM
I went and got the HB brake pump and noticed it had a little suction cup adapter in it.
I stuck the suction cup adapter on the cone fitting you show and it will pull suction. So I made some PumpNSeal clone tape valve strips and it works fine on normal jars. The valves are effectively free, which means you can save an additional $10-20 buying the mason jar sealer(s) by piercing the lids and using the valve strips, a la PumpNSeal.
The idea for making free PumpNSeal valves came from this page, in the Valves section.
The author refers to the valves as being like a plaster (ie, look like a band-aid when completed).
Suatainable says: Jan 30, 2009. 11:31 PM
I found the Tila FoodSaver mason jar sealer for $7.50 at TotalVac.com. Thanks for the great idea. I'm an heirloom seed saver, and was going to make one out of a bike tire pump by reversing the rubbers, but this is a much nicer way and inexpensive. Thanks again! Sustainable...
Eric Forman (author) in reply to SuatainableFeb 1, 2009. 2:22 PM
heirloom seeds...good idea!!! I'm still new at gardening but I've been thinking of laying a supply of non-hybrid heirloom seeds in case times get tough. Thanks for the idea.
Suatainable in reply to Eric FormanFeb 1, 2009. 10:54 PM
Don't forget to pop a dessicant pack into the jar of seeds, and put them in the freezer if your storing them long term. Temperature fluctuations cause the seed to lose it's viability sooner. Everyone should save some Non-GMO organic seed, as they're locking the OP seed up in vaults in Norway. One vault is on a remote island and the other is built into the side of a mountain. Monsanto and Biotech are buying up as many seed companies as they can, and replacing the natural open pollinated seed with GMO seed and thousands of heirlooms are becoming extinct! Good Luck!
nate71173 says: Jul 26, 2008. 8:43 PM
crash893, you need a air compressor to power that device.
cccgipson says: Jul 6, 2008. 6:47 AM
What's necessary for food preservation as far as vacuum is concerned? 15", 25", etc. . I own a vacuum pump and would be able to pull a 29" vacuum on the jar with little effort but is that necessary? Also, does anyone know if the jars will hold up under 29" of vacuum (equivalent to approx. 15# of external pressure)? Thanks for the instructable, it's cool.
kill-a-watt in reply to cccgipsonJul 21, 2008. 5:56 PM
you want to have a high enough vacuum to
  • keep the lid on
  • kill any weevels or other critters
  • remove as much O2 as possible
more is better, but even just enough to keep the lid on should help. If you are really worried about the weevils and such, you could just pop the whole thing in the freezer. I do this with every bulk bag of flour, rice, etc that comes in to the house.
TheBestJohn in reply to kill-a-wattJul 26, 2008. 7:12 PM
Also this would be great for Marinating... Opening up the pores of meat to let the juices in. Once the vacuum is released the pores should seal in the marinade... Can you say fast marinaded Beef jerky...
TheBestJohn in reply to TheBestJohnJul 26, 2008. 7:16 PM
Speaking of which... This would be excellent for making molds for ring making or any type of casting really... It would get a lot of the air bubbles out of the casting medium (I know commercial places have vacuum pumps but this would be for the DIY-er)
frollard in reply to cccgipsonJul 6, 2008. 8:33 PM
You probably wouldn't want to raise too high a vacuum with wet foods - you know that feeling when your hand is in a vacuum, or when you suck too hard in your mouth? That can become cellular damage, and for some foods can cause fresh food to perish sooner.
cccgipson in reply to frollardJul 7, 2008. 7:40 AM
You are right - At low pressures, the water will start to boil out of "wet foods" until it reaches equilibrium with the ambient temperature and pressure inside the jar. My biggest concern would be the jars being crushed by the outside pressure if they aren't designed to withstand it. I have used a vacuum pump to crush old 55 gallon drums at work for fun.
Eric Forman (author) in reply to cccgipsonJul 6, 2008. 10:24 AM
Oxygen, heat and light are the enemy of stored food, so the more air you eliminate (i.e. higher vacuum) the better.
qz9090 says: Jul 7, 2008. 3:19 PM
Are there any concerns related to botulism with this technique? It is my understanding the botulism (one teaspoon-worth is sufficient to kill 100,000 people) grows in environments with minimal oxygen and moisture. If I were to use this technique, I would use it with great care. Botulism is deadly!!! People that do home-canning should always take great care in sterilizing their jars, utensils, etc.
Eric Forman (author) in reply to qz9090Jul 7, 2008. 6:43 PM
You are correct. This technique is ONLY appropriate for shelf-storage of dry goods which contain less than 10% moisture. Moist foods which are vacuum sealed still need to go in the refrigerator (for up to a week) or freezer. This technique will not replace wet-pack canning with a pressure canner.
qz9090 in reply to Eric FormanJul 7, 2008. 7:02 PM
Eric, Thanks for the clarification. I have always had a curiosity about those "food saver" devices and botulism. I think your technique is good for things like coffee beans, seeds, and maybe things like popcorn (I'm not very imaginative). There are probably a multitude of applications for both food and non-food items. You Instructable is very well written and makes applying the technique very clear.
kill-a-watt in reply to qz9090Jul 21, 2008. 5:50 PM
Crackers, peanuts, dried beans, cornmeal, flour, sugar, teabags, non-fat dried milk etc.
I use it for the storage of any dried bulk goods. Things like seeds and nuts will store better because there isn't any (or very little) O2 left in the jars to make the fats in the food go rancid.
whca in reply to qz9090Jul 7, 2008. 5:38 PM
This is NOT a substitute for canning. It only extends the life of shelf-stable foods. There is therefore no botulism concern, if used only on appropriate items. IF you are sealing a food that needs refrigeration, this will help it keep longer IN THE REFRIGERATOR. It doesn't change WHERE you store the food, but just how LONG it will keep.
crash893 says: Jul 18, 2008. 8:43 AM
Could you use this to marinate steaks and other foods?
kill-a-watt in reply to crash893Jul 21, 2008. 5:44 PM
I don't see any reason why not, (subject to the limitations of the jar, you aint gonna fit a turkey in there). Just remember to put it in the fridge, like you would any maranate.
armylifer says: Jul 6, 2008. 8:22 PM
Good short term idea is a vacuume cleaner with a gatoraide lid on the end of the hose and a 1/8 inch hole with a 8 inch long 1/8 inch tube attached and use ziploc bags. Seal the bag except for enough space for the tube. Remove the air and VERY QUICKLY remove the tube and press the ziploc shut. 30 days and fish is still looking good in the freezer. Greeen beans going on a 5 days in the fridge.
CypherPack says: Jul 5, 2008. 7:57 AM
Thanks for posting this, I have been looking for a way to seal Mason jars without buying the full unit for $200. This device could be used to seal other types of storage containers and bags, like Mylar bags for food storage. I also like the fact that it has a gauge so you have a good idea of the quality of seal. I'm surprised only 4 people have rated it including me, if you like it rate it :)
nenik in reply to CypherPackJul 6, 2008. 6:16 AM
Yeah, rate it. This Instructable has been featured on and linked to from Lifehacker.com ! I knew it was good and now it has the lifehacker seal of approval as proof.
CypherPack in reply to CypherPackJul 5, 2008. 7:58 AM
I did find one other vacuum sealer for Mason jars but you have to puncture the lid and put tape over it, I don't like that idea at all for long term food storage.
nolte919 says: Jul 1, 2008. 5:46 AM
This is a great Instructable. Well done. I have a question. I'm not an expert about vacuums but 25 inHg seems like a pretty strong vacuum seeing as around 30 inHg is a perfect vacuum. So is it hard to open these jars back up? Is it possible to open them without harming the lid so the lid could be reused? Or are these lids so cheap they're considered disposable? Thanks.
nenik in reply to nolte919Jul 3, 2008. 8:02 AM
Open the jar with the edge of a spoon or such and just kinda flip it up and let it fly like with a champagne cork. [Don't hold the lid down with your free hand while opening the jar.] Yes, it can be reused [only in sealing the DRY goods].If you chip the jar while opening it, you may not be able to get a seal on it. Yes, the lids are relatively cheap, for now. These jar sealer adapters come in a large and regular size. I have both size jars, so I have both adapters. I'm sealing at between 22 and 25inHg.
nenik in reply to nenikJul 6, 2008. 6:12 AM
"hold the lid down with your free hand while opening the jar. " TYPO- I meant, "DO NOT hold down the lid..." Let it fly! Then there will be less chance of it bending.
Eric Forman (author) in reply to nolte919Jul 1, 2008. 6:46 AM
25inHg is a strong vacuum and it is a little difficult to pry the lids off. And, honestly, I pulled the 25inHg out of thin air. After a dozen jars, I started going to just 20 because those last 5 require a lot of pumping. There's a gauge on the pump, so you can really use any level of vacuum you want. As far as lids go, I've gone up to 25, carefully removed the lid, resealed it, and repeated 5 or 6 times on the same lid and gotten a good seal every time. You just have to be mindful not to bend the lid or damage the sealing surface while opening.
dasadler says: Jul 5, 2008. 12:32 PM
Sorry but I don't get it. How does it create a vacuum inside the jar if the lid is tight against the rim and the pump has no access to inside the jar to create the vacuum? It seems like this would create a vacuum on top of the lid. What am I missing?
blaisepascal in reply to dasadlerJul 5, 2008. 1:27 PM
The lid is not tight against the rim when the pressure in the jar is greater than the pressure outside. So when you are pumping (and therefore, as you put it, "creating a vacuum on top of the lid"), the lid is lifting slightly to equalize the pressure inside and out. Think of the lid as acting like a valve, letting air out but not in.
got2go4hike says: Jul 5, 2008. 11:50 AM
Fantastic
nenik says: Jul 3, 2008. 7:44 AM
Pro: Dude! This works great! I have found a lot of uses for it. I'm going to try it on mylar bags, too. I like that you don't use electricity. ; ) Good, clear pix. Con: I used up all my jars and had to go to Big Lots and stock up.
max142 says: Jul 1, 2008. 3:37 AM
Works very well. sealed a bunch of jars. Cheap and works gotta love it. Good advice from your pop.
pyro222 says: Jul 1, 2008. 3:22 AM
Nice Instructable. This would be great for camping situations.
alvincredible says: Jun 30, 2008. 1:05 PM
Aww man I was about to get all excited that there was an instructable named after me...then I read the line 'bout your "pop" :-) Your dad has a great name.
=SMART= says: Jun 30, 2008. 10:37 AM
so you have to buy the pump and the jar lid? Anyways good instructions :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
