This video shows The Amazing Magic Flashlight in action. A concealed magnet (taped to the bottom of my hand) is brought close and then pulled away from the flashlight causing the light to turn on and off. In the last step of this instructable is another video that shows how the push button switch appears to have no effect but when switched on and a magnet is near, the light turns on and off.
Remove these ads by
Signing UpStep 1Parts List
- A "normally open" magnetic reed switch. I obtained mine from Jameco Electronics. The switches are part number 171872 and cost $0.85 each. As you can see in the images, these switches are made of glass, so I recommend you buy several just in case you break one.
- 24" of flexible wire. I used speaker wire but you can use whatever you have handy as long as the wire is very flexible.
- Magnets.
- Electrical Tape.
- 6V Flashlight/Lantern.
- Soldering iron and solder.
- Wire cutters.
- Wire stripper.
Just a note though, Step 1, Pic 2, you labelled the reed switch as "Normally Closed", a typo I guess, but could confuse the confusables... :)
