loading
(''Hooray! It's finally done. It's a bit late into the contest but we hope it is good!'')
This project is what we're entering for the Go Green contest. It's a cool solar powered mini-fan. The idea is that if you had a fan you would use the air conditioning less. And it's solar powered so that it has 0 emissions. Finally, this is the first of many collaborations between c3j1r0 and I.
As always, feedback is greatly appreciated. It's the sharing of ideas that keeps an open source community together. Also, ask any questions you have! We're always glad to help. Thanks in advance. And hopefully, enjoy!
Oh, and before we forget! A big thank you goes to PacTec Enclosures for the project boxes.
NOTE: Neither of our video cameras are working. :-(. Maybe we'll get a video up soon! I hope so.
Step 1: The Concept
When we were taking apart an old computer (fun stuff!) we discovered a lot of very cool parts that we could use to make stuff. One of the cooler ones (sorry, very lame pun) was a 12V cooling fan. With the "Green Science Fair" contest running on Instructables we decided upon making a solar powered fan out of it. It's really pretty basic. We took a battery holder (2 AA batteries) and wired it into a 1.5V to 12V step up circuit. Now that we had it outputting 12V we hooked it into the fan. Finally (and this is what makes it "green"), we hooked a PV cell into the circuit so that it would charge the batteries. We knew how much energy air conditioning takes up, so we thought this would be a good way to get people to use less of it.
Step 2: Finding the Tools
"Finally," you say. "They've stopped talking and started on the actual project!"
Well, you are correct. We're done rambling for now. The project is actually starting.
Here are the tools you are going to need to build this (NOTE- Components are on the next step) (Also, you can download the checklist, it's the open office file. It would probably suffice just to read it, but if you had any questions you'd want to check out the stuff below.):
A Soldering Iron (And soldering station)
Wire Strippers (Or you could use this method. Trust me, the wire strippers are way faster!)
Wire Cutters (Mine were built in with the wire strippers)
*Optional* Pliers (The thinner the better, it makes it easy to grab things on your board without knocking other things loose)
*Optional* Third Hand Tool (Or a bench vise or something. There's a great instructable on how to make a third hand tool here)
*Maybe* A Dremel (You don't absolutely need this but you'd be surprised how much easier it is)
*Maybe* A Drill (You might be able to use your Dremel or find another way)
*Also* Various Drill Bits if you are planning on using the drill.
Once you have all of that it's on to the components!
Step 3: The Components
These are relatively easy to find. The checklist for these is on the tools page. You could use that, or just read the info below. These can all be easily ordered from Digikey or bought from RadioShack. The only thing we had trouble with was the PV cell, which we took from a solar lawn light.
(1) Schottky Diode - Digikey Part # 1N5818-T
(1) 47 uF Electrolytic Capacitor - Digikey Part # P902-ND
(1) Linear Technology DC/DC Converter Chip - Digikey Part # LT1073CN8-ND
(1) 2 AA Battery Holder
(2) AA Rechargeable 1.2V Batteries - (These will come with your solar powered lawn light if that's the path you choose to follow)
(1) 8-Pin Socket - Digikey Part # 3M5461-ND
(1) 120 uH Inductor - Digikey Part # M10078-ND
(1) 12V, .15A Fan
(1) PV Cell - (Note: I would get this from a lawn light. See Step 4 for the details on getting this.
(1) PC Board -What ever size works for you.
A Project Box - Once again, any size. Probably something you could fit the fan on top of. (Thank you PacTec)
(Some) Wire - You'll probably want some that is threaded and some that is solid core. (More threaded! Solid breaks a lot!)
Step 4: The Solar Light
One of the hardest parts to find for the project was the PV (Photovoltaic [Solar]) Cell. What we ended up doing was biking (not driving!) to the local hardware store and buying a solar lawn light. So here's how we got the parts we needed.
1. Get the light. They sell these at most hardware stores.
2. Take it out from the box.
3. The parts you're looking for are the PV (Solar) Cell and any rechargeable batteries that are in there. Try doing most of it by hand. That way you probably won't damage the parts. The picture below is of us doing it... not by hand. Haha. If it comes to that, oh well. Any way will work!
4. The battery should probably just pop out.
5. You can desolder the Solar Cell, or just cut the wires. Either way.
So now you have all the parts you need.
Step 5: Check the Schematic
Now before you run off and start soldering everything together, you should print out your schematic. I would suggest keeping it with you while you solder.
The problem with this is that the schematic is rather confusing. The schematic that I used is the one from the LT1073 datasheet (2nd picture). If you just printed that out, you would be in trouble though. The spots where the schematic tells you to connect don't exist on the actual chip.
So... to solve this problem, what you need is another diagram (The first picture). It tells you where the connections that are named in the second diagram are located on the chip.
The third and final picture shows you how to put your entire circuit together. It's pretty straight forward.
Step 6: Resistor!
Here's the final step before you get to the actual construction. Also, I'm putting in a summary so you don't have to read the entire thing if you don't want to.
Summary: Wire a 10 Ohm resistor into the circuit, right out of the battery pack.
We want two batteries to power this so that it will last longer. The problem is that we are using rechargeable batteries, which output 1.2V as opposed to the standard 1.5V. This is a problem because it means that we can't use the 3V to 12V converter. We have to use one lower. So how can we do this without blowing out the circuit?
We need to use a resistor to lower the voltage entering the chip. The reason I'm telling you all of this is so you can adjust this if you make modifications to the project. After all, Instructables is a great community for sharing ideas. Odds are that someone will make modifications to this project. It's easier if they have all of the info. (Also, it's probably good for educational purposes).
The way that we determined what resistor we needed was through Ohm's law, which states V(voltage) = I(current) x R(resistance). We use it in this way...
The forward voltage of our circuit is 1.5V. We then divide that by the amperage, .15A (Amperes! not milliamperes!), and find that we need a 10 Ohm resistor.
Step 7: Start Constructing!
Now that we have everything we need ready you can start soldering the project together. Here are the steps we used to do this.
1. Set up the board in the vice/helping-hands tool.
2. Put all of the components in to see if they fit. (Note: Don't put the LT chip into the socket until the rest of the project is finished.
3. If they don't fit you should get a new board. Otherwise, solder them all to the board. (HINT! It's easy to solder the parts if you bend the leads so that they stay in the board.)
4. Now to start connecting the parts. You can really do this in any order you want. Check the next step for our suggested order.
Step 8: How We Did It.
This step is really just how we connected the parts on the board. You could do this any order that you wanted to. If you haven't done much soldering before then this could be a help. Otherwise, just connect it in whatever order you choose, and skip this step.
1. Cut and strip wires of different lengths. (You can set up a whole bunch now, or between steps when you need it. Whatever works for you.)
2. Using your schematic, figure out which pins on the chip you are going to be using, the connect wires to those. Just leave the other end of the wire open.
3. Now, start connecting the other ends of those wires to where they go in the circuit.
4. Once you've connected all of the wires that run from the chip you should start making the other connections. (Make all of the connections that don't involve the chip)
Now you should have the chip done. All that's left to do is to connect the battery, PV cell, and fan. Then set it up in the box and you're ready to go!
Step 9: Connect the Rest.
IMPORTANT Before you start this step you should remember that you are connecting parts that are going to be inside the box, to parts that will be on the outside of the box. The pictures in this step are just to show you how they connect. Remember to drill the holes in the box, put the wires through, then make the connection.
Now that you have the board with all of the components connected finished you can start connecting the power source and the fan.
The first and most important thing you should do is take out the drill and drill 2-4 holes (depending on the size) in the box.
Next we connected the PV Cell to the battery pack. Thread the wires from the PV cell through the holes, and into the box, then connect it to the battery pack.
(Remember, red (+) to red, and black (-) to black. The colors may not be right but if they aren't (or if you just can't remember), there's probably some sort of marking indicating which is positive and which is negative.)
Now we added the third wires that will go to the switch then the board on the positive side, or that will complete the circuit on the negative side. These will go inside of the box.
After that, connect the third wire on the positive side to the switch. Then connect the switch to the board.
Now you are almost done. Just attach the fan to the board (through the holes in the box) and finish off the circuit at the third wire on the negative side of the battery pack (inside the box).
And there you have it!
Step 10: Final Steps
There are a couple more finishing touches to complete the fan.
1. Test it out! Make sure it works by turning it on and off a couple of times.
2. Next, you're going to want to secure the fan to the top of the box. You can use hot glue or that foamy padded tape stuff.
3. As for the solar panel, you may not want to totally secure it to the box. This way, you can rotate it around so it gets the most sun.
4. Finally, enjoy your fan! Use less air conditioning! Relax in the hot weather!
Step 11: In Conclusion...
In conclusion, you have now completed your fan. Pat yourself on the back! Not only did you finish a fun project, but you also are helping the environment.
Remember, one of the reasons this project is good is because it is a very green project. What I'm getting at is that you shouldn't drive to get all of the parts. Bike or walk as much as possible!
Finally, use it! You're not being environmentally friendly if you make it then proceed to abandon it in the garage. Use it so you don't run your fan in your room as much.
And remember, feedback is always appreciated.
Step 12: Tips and Troubleshooting
This is the last step, we swear! It's really just a collection of tips and ideas that could help if you're having problems.
1 Have a clean workspace. Picture number one is our workbench. A perfect example of what not to do. I think we spent more time looking for parts and tools than actually building the project.
2 Enjoy yourself. You can make it a lot more fun by putting on some music. We hooked up Eric's iPod and played it way too loudly. Then the neighbors complained. Then we played it not so loudly.
Troubleshooting
_
1 Check your work with a multimeter. It would have saved us a lot of time if we had.
2 Make sure you get the right parts. We accidentally ordered our inductor incorrectly. We mixed up micro with nano. Don't do that. =P. It's a lot easier if you have the right parts.
 just a small tip: i noticed that you have your parts a bit far apart. if you put them closer together you wont need all the messy wire and you can use solder bridges to put everything together :)
I'm needing some help, i saw a YouTube video while back can't find it know, but the man took a fan like this out of computer and hooked it to a solar panel and attached it to chicken run to keep them cool. Just not sure about panel size can someone help. Thanks<br>..
<p>I just watched it - I think you mean this guy :</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/Y5wE2PitPuE" width="500"></iframe></p><p>Colin Keevil from Surestead Homestead ??</p>
<p>Sorry, Stand Sure Homesteading :)</p>
<p>The power of circuit is insufficient as other commentators said. Not only that, the resistor is not necessary, because the chip is tolerant to input voltage in this case.</p>
<p>amazing</p>
Cool...I was looking for something like this :)
You can usually get these at the 99c store, which makes them super cheap.
Quick question: <br /> <br />Lets say I want to do this exact same project but without batteries. I want the fan to just run when its getting power from the solar cell and obviously it would turn off when the sun goes down since there's nothing holding the charge. If you have a 3V solar cell wouldn't everything be exactly the same minus the batteries or is there something hidden in there that would need to be changed as well? <br /> <br />Thanks for any help!!
I dont understand The Schematic!<br /> can yo explain it to me?<br />
the solar board is 1.2v and 300mA. <br>the pc fan needs a voltage of 12V with at least 0.3A, (300mA) to run. <br> <br>this circuit is a voltage doubler that doubles or triples the voltage to make the fan run, but the Power (watts) stays same, even smaller a little. <br> <br>this system he made, makes the fan to run but not as fast as to generate a proper wind to be useful.
I am not the author and i know it is &gt;2 years since your question, but what is it that you do not understand in the schematic? <br>there is a solarcell that charges batteries. The voltage from the batteries and solarcell is led to a chip that makes 12 volt out of 1.5 volt. The 12 volt drives a fan
Actually the next step explains
even with yr parts far apart you could have made some shorter connections :-)
How come in your schematic, you only have a 1.5v battery, yet you are using 2 1.5v batteries, making it 3v. your schematic doesn't line up with the parts you are using.
probably a bit late, but let me do a suggestion: the batteries could be in parallel
how much does it cost<br>
Needless to say this is amazing!<br>well done! ;)<br>how long does it run on batteries?<br><br>I want to make one too, I'm going to camp near the beach in about a week and I want one for my tent as it gets too hot inside! I'm trying to figure a way to make bigger blades, perhaps with paper or carton or something. Otherwise the flow is too concentrated I guess, right?<br>Thanks for the instructable! it's great!
You say to use a 120 uH inductor, but the model number you listed brings up a 120 mH inductor. Which one is it?
As far as I can tell, you're running the 12 V fan from the two rechargeable batteries, which have a combined voltage of 2.4 V in series or 1.2 V in parallel. The batteries are charged by the small solar panel, and you step up from the battery voltage to 12 V.<br><br>So, why do you take apart the solar lawn light? It's already set up to charge the batteries from sunlight, so couldn't you just divert the power from the lawn light's output away from the LEDs to your step-up circuit, and then to the fan? You would need to bypass the light-sensitive switch that shuts off the lawn light during the day, but it would let you leverage the existing case and circuitry.<br><br>Does this set-up need to charge all day before it can power the fan for any appreciable time, or can it run continuously in the sunlight?<br><br>Thanks for a fine instructable. I've been looking for something like this to circulate air through a solar heat collector, obviating the passive thermosiphon effect that's usually employed to move the air around.
Very cool concept.
&nbsp;you need to be very careful when taking the panels out of they will snap
just a thought....remote your solar cell outdoors via a pair of wires.....
Yeah, that'd be good so that I wouldn't have to mount it to the top. The reason I didn't do that was because it was mainly for outdoor use anyway. But hey, if you liked this do you think you could vote for it in the book contest?
hey i liked ur project, but i was wondering if you would mind if i used it for a science fair project, i will give you credit of course. also, if u don't mind (and im asking for the help of all my fellow instructable peers) cound you help me think of a experimentle question you can do with this project? it has to be something you can test any ideas would be great thnx!!!
That would be fine if you used my project. As for testable questions, maybe you could try to find out what voltage of fan, or solar cell (or some other part in the project that could be switched out easily) has the highest energy efficiency.<br />
<p>thnx for the reply, ummm i tried to dowload the checklist for the components, but its a zipped folder so i dont know what to do.....</p>
<p>send me your email in a pm, and I'll email you the actual files. You probably don't have winzip or a simmilar program on your computer or it would have mentioned it.</p>
But first try right clicking and see if it says extract files or not. It would be a good idea to look into a zip program.&nbsp;&nbsp;
also thnx for the sci fair ideas, but how would i go about measuring energy efficiency?
You should have made it out of entirely salvaged parts. The computer would have the wires, diodes and capacitor, and whatever else and you could use old solar garden lights for the solar cell(s).&nbsp;&nbsp;&nbsp;
&nbsp;Hi, &nbsp;I'm pretty new to circuit building and have been trying to construct the 1.5v to 12v portion with no success. &nbsp;I'm including a diagram of what I built for some input. &nbsp;Thanks in advance.<br /> <a href="http://i10.photobucket.com/albums/a125/chadm2005/Circuit001.jpg">i10.photobucket.com/albums/a125/chadm2005/Circuit001.jpg</a><br /> <br />
Thank you.. I think this is exactly wjay i was looking for to install in my 1989 Suburban to remove the heat and the odors that build up from the inside in the hot summer days.. i just need to figure on putting in a temp sensor switch to make it come on at a certian temp...
Concerning the inductor. Is it a millihenry or a microhenry? (micro according to the schematic, milli according to the digikey part numer)
Awesome!<br/><br/>Oh, congrats, its featured. *GASP* by ewilhelm!<br/>
Hey, thanks for commenting. If you liked it do you think you could vote for it in the book contest?
i will how do u vote?
Hey, thanks for your interest, the contest ended though.
Thanks, and I like the cartoon.
This Instructable looks really fun but I'm having troubles hunting down a few of the components.. Mainly, the TL1073 and the 120 uH Inductor Does anyone know of any substitutions that would work in this circuit? I'm pretty green when it comes to electronics so unfortunately, I'm following this guide to a T... I managed to find a place that has 100 uH Inductor or 140 uH Inductor, would either of those work? Also, regarding TL 1073, are there other IC's that will work in its place? I can order the part from DigiKey but the idea of paying $8 shipping on a $5 item drives me crazy... same goes with the inductor... as nice as 1000 of them would be, I really don't need to blow ~$700 on 999 unnecessary components Any help from a more seasoned DIY'er would be really appreciated! Thanks!
Instead of scavenging solar cells from new products, it's cheaper and easier to just buy them- Radio Shack sells them for 5 bucks, part number 276-124. I'm sure there are plenty of other places to get them cheaply from as well.
Hey, thanks for commenting. Do you think you could vote for this in the book contest? If you can't, no problem.
That's true if you only need one. The advantage of scavenging is that we got 2 for $11 bucks and we also got 2 photoresistors, the batteries we needed, and 2 bright white LED's. But your point makes sense. We got our lights at bargain-bin prices. If you can't find them at a great price, buy them elsewhere.
This is a good idea, chances are most people have the materials around their home and if they don't, they could be recycled from older components.
Hey. Do you think you could vote for this in the book contest if you liked it? Thanks for commenting.
Thanks.
good job. but ya know whats dumb?
solar powered flashlights.
an ejector seat in a helicopter.
and a geothermal plane
About This Instructable
298,573views
176favorites
License:
Bio: Music, chemistry, electronics, etc.
More by Gjdj3:Music on Hold Phone System Unlock A Bike Lock Build a DIY Recycled Antenna (To Get Free T.V!)
Add instructable to:
