loading
Step 10: Final Steps
There are a couple more finishing touches to complete the fan.
1. Test it out! Make sure it works by turning it on and off a couple of times.
2. Next, you're going to want to secure the fan to the top of the box. You can use hot glue or that foamy padded tape stuff.
3. As for the solar panel, you may not want to totally secure it to the box. This way, you can rotate it around so it gets the most sun.
4. Finally, enjoy your fan! Use less air conditioning! Relax in the hot weather!
 just a small tip: i noticed that you have your parts a bit far apart. if you put them closer together you wont need all the messy wire and you can use solder bridges to put everything together :)
I'm needing some help, i saw a YouTube video while back can't find it know, but the man took a fan like this out of computer and hooked it to a solar panel and attached it to chicken run to keep them cool. Just not sure about panel size can someone help. Thanks<br>..
<p>I just watched it - I think you mean this guy :</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/Y5wE2PitPuE" width="500"></iframe></p><p>Colin Keevil from Surestead Homestead ??</p>
<p>Sorry, Stand Sure Homesteading :)</p>
<p>The power of circuit is insufficient as other commentators said. Not only that, the resistor is not necessary, because the chip is tolerant to input voltage in this case.</p>
<p>amazing</p>
Cool...I was looking for something like this :)
You can usually get these at the 99c store, which makes them super cheap.
Quick question: <br /> <br />Lets say I want to do this exact same project but without batteries. I want the fan to just run when its getting power from the solar cell and obviously it would turn off when the sun goes down since there's nothing holding the charge. If you have a 3V solar cell wouldn't everything be exactly the same minus the batteries or is there something hidden in there that would need to be changed as well? <br /> <br />Thanks for any help!!
I dont understand The Schematic!<br /> can yo explain it to me?<br />
the solar board is 1.2v and 300mA. <br>the pc fan needs a voltage of 12V with at least 0.3A, (300mA) to run. <br> <br>this circuit is a voltage doubler that doubles or triples the voltage to make the fan run, but the Power (watts) stays same, even smaller a little. <br> <br>this system he made, makes the fan to run but not as fast as to generate a proper wind to be useful.
I am not the author and i know it is &gt;2 years since your question, but what is it that you do not understand in the schematic? <br>there is a solarcell that charges batteries. The voltage from the batteries and solarcell is led to a chip that makes 12 volt out of 1.5 volt. The 12 volt drives a fan
Actually the next step explains
even with yr parts far apart you could have made some shorter connections :-)
How come in your schematic, you only have a 1.5v battery, yet you are using 2 1.5v batteries, making it 3v. your schematic doesn't line up with the parts you are using.
probably a bit late, but let me do a suggestion: the batteries could be in parallel
how much does it cost<br>
Needless to say this is amazing!<br>well done! ;)<br>how long does it run on batteries?<br><br>I want to make one too, I'm going to camp near the beach in about a week and I want one for my tent as it gets too hot inside! I'm trying to figure a way to make bigger blades, perhaps with paper or carton or something. Otherwise the flow is too concentrated I guess, right?<br>Thanks for the instructable! it's great!
You say to use a 120 uH inductor, but the model number you listed brings up a 120 mH inductor. Which one is it?
As far as I can tell, you're running the 12 V fan from the two rechargeable batteries, which have a combined voltage of 2.4 V in series or 1.2 V in parallel. The batteries are charged by the small solar panel, and you step up from the battery voltage to 12 V.<br><br>So, why do you take apart the solar lawn light? It's already set up to charge the batteries from sunlight, so couldn't you just divert the power from the lawn light's output away from the LEDs to your step-up circuit, and then to the fan? You would need to bypass the light-sensitive switch that shuts off the lawn light during the day, but it would let you leverage the existing case and circuitry.<br><br>Does this set-up need to charge all day before it can power the fan for any appreciable time, or can it run continuously in the sunlight?<br><br>Thanks for a fine instructable. I've been looking for something like this to circulate air through a solar heat collector, obviating the passive thermosiphon effect that's usually employed to move the air around.
Very cool concept.
&nbsp;you need to be very careful when taking the panels out of they will snap
just a thought....remote your solar cell outdoors via a pair of wires.....
Yeah, that'd be good so that I wouldn't have to mount it to the top. The reason I didn't do that was because it was mainly for outdoor use anyway. But hey, if you liked this do you think you could vote for it in the book contest?
hey i liked ur project, but i was wondering if you would mind if i used it for a science fair project, i will give you credit of course. also, if u don't mind (and im asking for the help of all my fellow instructable peers) cound you help me think of a experimentle question you can do with this project? it has to be something you can test any ideas would be great thnx!!!
That would be fine if you used my project. As for testable questions, maybe you could try to find out what voltage of fan, or solar cell (or some other part in the project that could be switched out easily) has the highest energy efficiency.<br />
<p>thnx for the reply, ummm i tried to dowload the checklist for the components, but its a zipped folder so i dont know what to do.....</p>
<p>send me your email in a pm, and I'll email you the actual files. You probably don't have winzip or a simmilar program on your computer or it would have mentioned it.</p>
But first try right clicking and see if it says extract files or not. It would be a good idea to look into a zip program.&nbsp;&nbsp;
also thnx for the sci fair ideas, but how would i go about measuring energy efficiency?
You should have made it out of entirely salvaged parts. The computer would have the wires, diodes and capacitor, and whatever else and you could use old solar garden lights for the solar cell(s).&nbsp;&nbsp;&nbsp;
&nbsp;Hi, &nbsp;I'm pretty new to circuit building and have been trying to construct the 1.5v to 12v portion with no success. &nbsp;I'm including a diagram of what I built for some input. &nbsp;Thanks in advance.<br /> <a href="http://i10.photobucket.com/albums/a125/chadm2005/Circuit001.jpg">i10.photobucket.com/albums/a125/chadm2005/Circuit001.jpg</a><br /> <br />
Thank you.. I think this is exactly wjay i was looking for to install in my 1989 Suburban to remove the heat and the odors that build up from the inside in the hot summer days.. i just need to figure on putting in a temp sensor switch to make it come on at a certian temp...
Concerning the inductor. Is it a millihenry or a microhenry? (micro according to the schematic, milli according to the digikey part numer)
Awesome!<br/><br/>Oh, congrats, its featured. *GASP* by ewilhelm!<br/>
Hey, thanks for commenting. If you liked it do you think you could vote for it in the book contest?
i will how do u vote?
Hey, thanks for your interest, the contest ended though.
Thanks, and I like the cartoon.
This Instructable looks really fun but I'm having troubles hunting down a few of the components.. Mainly, the TL1073 and the 120 uH Inductor Does anyone know of any substitutions that would work in this circuit? I'm pretty green when it comes to electronics so unfortunately, I'm following this guide to a T... I managed to find a place that has 100 uH Inductor or 140 uH Inductor, would either of those work? Also, regarding TL 1073, are there other IC's that will work in its place? I can order the part from DigiKey but the idea of paying $8 shipping on a $5 item drives me crazy... same goes with the inductor... as nice as 1000 of them would be, I really don't need to blow ~$700 on 999 unnecessary components Any help from a more seasoned DIY'er would be really appreciated! Thanks!
Instead of scavenging solar cells from new products, it's cheaper and easier to just buy them- Radio Shack sells them for 5 bucks, part number 276-124. I'm sure there are plenty of other places to get them cheaply from as well.
Hey, thanks for commenting. Do you think you could vote for this in the book contest? If you can't, no problem.
That's true if you only need one. The advantage of scavenging is that we got 2 for $11 bucks and we also got 2 photoresistors, the batteries we needed, and 2 bright white LED's. But your point makes sense. We got our lights at bargain-bin prices. If you can't find them at a great price, buy them elsewhere.
This is a good idea, chances are most people have the materials around their home and if they don't, they could be recycled from older components.
Hey. Do you think you could vote for this in the book contest if you liked it? Thanks for commenting.
Thanks.
good job. but ya know whats dumb?
solar powered flashlights.
an ejector seat in a helicopter.
and a geothermal plane
About This Instructable
298,573views
176favorites
License:
Bio: Music, chemistry, electronics, etc.
More by Gjdj3:Music on Hold Phone System Unlock A Bike Lock Build a DIY Recycled Antenna (To Get Free T.V!)
Add instructable to:
