Step 19Trim the Case
If you want a simpler looking case, you don't even have to do any more to it, but I think it looks nice to add something as a protective border around the window. This is a part from a purse strap I found at a thrift shop, but it could be anything you like. On the Ambience Enhancer, I used a rectangle of brass I found in the notions at Joann's, also intended for purse building. If you have a circular window, maybe try an old watch case front or a key ring. If you're not sure what you want, you can always skip this step and add on something later if you find it.
I also added another grommet to the center of the buttons on the front of the Sansa. Again, this will change depending on the object and your personal taste.
If you want to add rivets or any other kind of trim, now might be the best time. Remember to leave a space for the straps to be added on the sides of the case.
Add Comment
