This is my Airsoft rocket launcher. I built it out of 4-inch diameter DWV-D drainpipe, held together with nothing but hot glue. It is approximately 4 and a half feet long, and weighs around ten pounds when empty. It fires shrapnel rockets, powered by D-class Estes model rocket engines. The rockets go about 200 feet, and are marginally accurate. I make my rockets out of soda bottles, and when they land, they blast a shower of BBs about fifteen feet in all directions, accompanied with a loud BANG. The rockets have a soft tip, so if they hit someone, they will not cause serious injury, no more than a bruise. I will post an Instructable for the rockets soon enough, once i get some disposable cash to make some more. This launcher is basically a more specialized version of Rwctt's launcher, with a store-bought ignition system and made of different materials. I do not have any construction pictures of the launcher, because at the time of construction, my camera was without a memory card. if you need instructions for something quite like this, go to the link below.
that is a regulation-size soccer ball (football for the rest of the world) for scale.
Rwctt's launcher provided the basic inspiration for this project, and his is just as good as mine.
You can find it here----->
http://www.instructables.com/id/PVC-Rocket-Launcher/I made this in four parts. listed from top to bottom, these are: optional end cap spark arrestor, rear section with shoulder rest, middle coupler with ignition system, and the front section with rotating handle. All that is needed for break down is a small screwdriver or pair of pliers. This launcher is designed to be as tactically viable as possible, so it can be broken down and assembled quickly when the situation demands it.
Just as a question, How do you not have TONS of views??
I personally like your instructables, and only 20,000 views is insulting, seeing what some of the other guys have.
