loading
loading
Picture of The Anti-Gravity Jumper
Remember those great baby contraptions, your parents would hook up to the door frame, and you'd bounce around for hours? Johnny jumpers! Well I made the big boy version today...it's johnny jumpers--all grown up. Ever want the feeling of being nearly weightless...or be able to have an extra long hang time? Read on...
Step 1: What you'll need
-two five gallon buckets (edit:was using five gallon buckets and found they aren't strong enough, a bucket like the red one we used is better)
-about 100 feet of rope
-a trampoline (optional)
-a harness of some sort (we have a deer stand harness we used)
-weights (like weightlifting weights)
-chain, or a little extra rope
-two pulleys
We had this rigged up in the barn before, both are fun, the barn you get more vertical action and less floaty feeling, over the trampoline it's more of a floaty feel. Both are plenty of fun you'l just have to see what works best for you.
Step 2: Find a Spot
Picture of Find a Spot
First things first, you'll need to find a good spot to build yours. Like I mentioned before I first built this in the barn, and it worked well, but then I wanted to try this version so I moved from the barn to woods. You'll need to find two trees with overhanging branches at least 4 inches in diameter. I've outlined where the tree branches are to give you an idea. Once you've done that keep on movin...
Step 3: Set up the Ladder and Attach the Pulleys
Picture of Set up the Ladder and Attach the Pulleys
Now set your ladder up against the limb, closer to the tree is better, rather than way out on the limb. Then chain the pulley around the limb. After you've finished it on the first limb do it on the second. On the second limb I attached the pulley with rope, wrap it around the limb three or four times tie it, and attach the second pulley.
Step 4: Thread the rope through the pulleys
Picture of Thread the rope through the pulleys
Now tie both ropes to their buckets, and thread the other end through the pulley. Do it to both buckets and both pulleys.
Step 5: Move the Trampoline
Picture of Move the Trampoline
If you plan on using a trampoline (which I recommend) underneath you move it now. Position it between the two pulley systems.
Cyberdalek1 month ago
this is awesome!!!!
slalevee11 months ago
i have an idea for one with a bungee cord and a homeade harness hope it works
foobear1 year ago
vid plz
ventifact3 years ago
Sorry to be a Grinch but I worry that a bucket handle will yank off and jerk the jumper sideways off the trampoline.
machoturtle (author)  ventifact3 years ago
very good thought...actually that happened to the five gallon bucket, it didn't hurt anybody just gave em a good tug.
you could pour quick-crete in the bucket then once it sets drill an i-hook into the top so you don't have to worry about the handle
How 'bout just a duffel bag or other strong bag holding rocks? It's only 45-100 pounds, should be able to find something to hold it.
machoturtle (author)  omalachowski3 years ago
yep thats how i made my first version and it worked good!
noahw ventifact3 years ago
This project is awesome!
ventifact - I share your concern, but it can be solved with a simple modification of the system - positioning the pulleys directly above the jumper would be safer so that at worst, you simply fall back down to the trampoline.
machoturtle - great idea and execution on this project. I used to love to Jolly Jumper as a kid, I will now make this as an adult. If only I was small enough to still do this in a doorway.
machoturtle (author)  noahw3 years ago
great post a pic if you get it made! i did realize the more vertical the ropes the better it helps the jumper go higher, just make sure the weighted buckets are far enough away from your head.
I believe that our system at work (I work for an inflatables company that has one of these) has a single cable that attaches through pulleys to create a triangle that the rider is hanging at the bottom of. this might be better because if something breaks you'd fall straight down instead of to the side.
I just noticed the use of weights. (I need to read more carefully instead of just looking at pictures!) regardless, I think it could be implemented so that if one part breaks the whole thing goes instead of yanking the rider somewhere. perhaps have the triangle with another pulley pulling the top bit? I don't know anymore, I'm confusing myself.
Kayoken3 years ago
Better yet, buy the trampoline and dont add every spring to it allowing it to have a bit more give. Safer and less likely to throw you into a death spiral
Exocetid3 years ago
I hate to be the old fart who throws cold water, but...
...use helmets.
...think of a better, possibly commercial harness. The kid in the picture probably has nothing to worry about at his age, but later that same harness may give a nasty pinch in a place that you do not want pinched.
...consider strengthening the bucket bail or adding a safety rope just in case it seperates.
machoturtle (author)  Exocetid3 years ago
yep good point
hammer98763 years ago
Makes me want to go get a trampoline. I'd have to use lead weights in the buckets, though. Congratulations on be Featured!
machoturtle (author)  hammer98763 years ago
yeah lead weight is a good idea
I love the the anti-gravity jumper!! bigger the better I think. Surely the point is to have fun and excitement, if you enter a death spiral or the handle drops off, it would be even more exciting!!!!!!
keep up the good work!!
codongolev3 years ago
this looks fantastic. I work for an inflatables company, and we have one of the commercial versions of this and it's a huge hit all the time. (granted, it's awful to run, because for safety reasons we have to adjust the bungee cord strength according to every individual's weight, which takes tons of time.)
BtheBike3 years ago
i might add a helmet jic . very cool
Love it! We did something like this when we were kids, but to do it with the trampoline is inspired!
The simple version we did as kids is like a see-saw. One pulley, two kids of roughly the same size, each holds an end. Jump to catch the rope and send the other kid up. Watch your fingers near the pulley!
sitearm3 years ago
@Machoturtle; Hi! Wanna wanna wanna see a video! Cheers : ) Site
TSC3 years ago
This is cool!
diyer83 years ago
I'd love to try that :-)
3ddementor3 years ago
wow, how high can you jump?
machoturtle (author)  3ddementor3 years ago
you can jump about 3' but you feel weightless...with the one pulley/one bucket system you can jump about 5' to 6' high (i'm gonna post how to make that one later one, so if your interested you can follow me)
tinker2343 years ago
wow i love the idea of zero gravity
