3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Arduino DoAnything Shield
The Arduino DoAnything Shield is a shield that really saves you NOTHING but a whole lot of cutting. After I had made my Chiptunes Project on the Arduino, I had the urge to make a shield so that there would be no loose wires and possible shorts. I tried to design a shield but then realized that the spacing between Digital 7 and 8 was NOT the standard measurement apart! Well, I then put it off...until my Loud Objects Noise Toy on Arduino. I had posted it and Meronkun brought to my attention that Collin Cunningham had ported the code over to the Arduino! However he used Pin 3 and I had used Pin 11. It was a very, very nice code. I would either need to cut my board in half to accommodate the spacing or I would need to have wires jumping over. Then I remembered I had made shields in the first place to avoid loose wires! I had to order from an online store at the time and I thought, "What if I had a shield and I soldered one long block of female headers?" That would allow me to make any shield without the ugly dangling wires! I had a decision to make: To use Arduino's Shield or AdaFruit's shield. I went with Arduino's shield because of cost. I then went ahead and built it. Here it is.
Step 1Parts.
Parts.
You will need:
1 Arduino Protoshield Kit (You SHOULD be able to use AdaFruits but just to be safe, let's stick with Arduino's...the kit just means that it comes with a few components.)
1 row of female headers (They generally have 40 pins each so it should be enough)
2 rows of male headers (You only need one if you don't plan to make the shield on top of the ProtoShield anytime soon but am  making this project to have it ready when the time comes.)
1 LONG piece of wire
4 comments
Feb 25, 2012. 9:58 PMjavaben says:
I'm not sure I'm understanding the purpose, so a little more insight would be nice. It also took me a while to understand that you were sometimes showing the front of the shield and other times showing the back side. That may have been apparent to others but never seeing one of these pro to shields before i missed it.
If I have managed to ferrit out the purpose correctly, you made this as sort of an adapter that will let you plug in your own shields that would have the arrangement of your female headers?
Feb 26, 2012. 9:07 AMjavaben says:
Ah, of course. Silly of me not to have caught that. Thanks for the clarification!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:blinkyblinky
If you want me to build something...I'm open to ideas. I like to hack with electronics, mix with chemicals and play with ideas. My motto? "If you want something to be done in this world, you must do i...
more »
