Introduction: The Arduino Weather Station / Thermostat
About: Professionally, I'm an IT Engineer (Executive Level) and Electronics Tech. I'm a Amateur Radio Operator (KK4HFJ). I lived off grid, with Solar (PV), Wind, and veggie oil fueled diesel generator power for 6 yea…
UPDATE: https://www.instructables.com/id/Temperature-and-Humidity-on-a-Graphical-LCD/
UPDATE: Add dew point calculations
UPDATE: Wind Speed Monitoring
I've always been interested in monitoring my local weather, and noticed the difference between what weather.com and accuweather.com think my local weather is, and what I see out the window. I also wanted better control over my heating and A/C system. As a computer and electronics nut, I've been playing with the Arduino Microcontroller, and decided to to meld my interests. So here goes the documentation on my home built solar powered weather station (always being modified, and expanded) with HVAC Control.
Step 1: The Arduino
The first step was obtaining a Arduino board. We purchased ours from hacktronics.com. After working through the tutorials on their site, I felt confident that I understood the simple scripting and connection concepts, and moved forward.
Arduino is an open-source electronics prototyping platform based on flexible, easy-to-use hardware and software. It's intended for artists, designers, hobbyists, and anyone interested in creating interactive objects or environments. - http://arduino.cc/
The Arduino requires 5v to run, and we supply this with our Pico Solar PV / Lithium battery pack.
Step 2: The LCD Display
I needed the ability to display temperature, humidity, barometric pressure, and time/date, so I picked a 4 line white on blue LCD display from Hacktronics. I used their LCD tutorial to get it connected and display some sample text on the screen.
// character LCD example code
// www.hacktronics.com
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13; // pin 13 will control the backlight
void setup()
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
lcd.begin(16,2); // columns, rows. use 16,2 for a 16x2 LCD, etc.
lcd.clear(); // start with a blank screen
lcd.setCursor(0,0); // set cursor to column 0, row 0 (the first row)
lcd.print("Hello, World"); // change this text to whatever you like. keep it clean.
lcd.setCursor(0,1); // set cursor to column 0, row 1
lcd.print("hacktronics.com");
// if you have a 4 row LCD, uncomment these lines to write to the bottom rows
// and change the lcd.begin() statement above.
//lcd.setCursor(0,2); // set cursor to column 0, row 2
//lcd.print("Row 3");
//lcd.setCursor(0,3); // set cursor to column 0, row 3
//lcd.print("Row 4");
void loop()
See http://www.hacktronics.com/Tutorials/arduino-character-lcd-tutorial.html for actual code as instructables breaks our include statements.
Step 3: Temperature & Humidity
I purchased a SHT21 Temperature Humidity sensor from MisensO.com. This chip uses the I2C protocol for communicating. I found some sample code on the net that makes it talk to the Arduino, but it outputs to the serial port back to the pc. I modified the code to output to my LCD. I now have the Temperature and Humidity showing on the LCD display.
//Tested with SHT21 Breakout from Misenso
//SHT21 pin SDA to Arduino Analog pin 4
//SHT21 pin SCL to Arduino Analog pin 5
//SHT21 pin GND to Arduino GND
//SHT21 pin VCC to Arduion 3v (not 5v)
lcd.begin(20,4); // columns, rows. use 16,2 for a 16x2 LCD, etc.
lcd.print("Humidity: "); // change this text to whatever you like. keep it clean.
lcd.print(humidity.GetHumidity());
lcd.print("Temp in C: ");
lcd.print(humidity.GetTemperatureC());
lcd.print("Temp in F: ");
lcd.print(humidity.GetTemperatureF());
See http://arduinotronics.blogspot.com/2010/09/our-temperature-humidity-monitor-is.html for actual code as instructables breaks our include statements. You will need the LibHumidity.h library from Modern Devices for this project.
Step 4: HVAC Control
Now that I know what the temperature is, I need to control my A/C and heat based on what I want the temp to be. I installed a RGB LED as a placeholder for the relays I will be installing. If the system calls for heat, it turns the LED red. If it calls for cooling, it turns the LED Blue. If it's in our comfort range, it turns green.
if (humidity.GetTemperatureF() < 60)
digitalWrite(RedLEDPin, LOW); // sets the Red LED on
digitalWrite(BlueLEDPin, HIGH); // sets the Blue LED off
digitalWrite(GreenLEDPin, LOW); // sets the Green LED off
else if (humidity.GetTemperatureF() >= 75)
digitalWrite(BlueLEDPin, LOW); // sets the Blue LED on
digitalWrite(RedLEDPin, HIGH); // sets the Red LED off
digitalWrite(GreenLEDPin, HIGH); // sets the Green LED off
else
digitalWrite(GreenLEDPin, LOW); // sets the Green LED on
Step 5: Current Code With Wiring Instructions
The following is the code as it exists today. I am adding a second SHT21 for indoor/outdoor measuring (means hacking a second I2C channel, as the SHT21's all have the same address, and can't exist on one channel), and I'm still waiting for my real time clock chip and barometric pressure sensor to arrive from Sparkfun.com (they arrived yesterday, and I will work on this on the weekend - 9-29-10). I migrated the project over to my new Arduino Mega 2560 (58 I/O lines), and installed the new 0021 IDE. I will edit this instructable as the project evolves.
// Connections:
// LCD pin 1 to Arduino GND
// LCD pin 2 to Arduino 5v
// LCD pin 3 (Contrast) to GND
// LCD pin 16 to Arduino GND
//SHT21 pin VCC to Arduino 3v (not 5v)
//RGB LED
//Red Cathode to Arduino pin 9
//Blue Cathode to Arduino pin 8
//Green Cathode to Arduino pin 7
//Anode to 270 ohm resistor to 5V
#include #include
#include
LibHumidity humidity = LibHumidity(0);
int RedLEDPin = 9; // LED connected to digital pin 9
int BlueLEDPin = 8; // LED connected to digital pin 8
int GreenLEDPin = 7; // LED connected to digital pin 7
void setup()
//I2C
pinMode(16, OUTPUT);
digitalWrite(16, LOW); //GND pin
pinMode(17, OUTPUT);
digitalWrite(17, HIGH); //VCC pin
//Furnace / AC Indicator
pinMode(RedLEDPin, OUTPUT); // sets the digital pin as output
pinMode(BlueLEDPin, OUTPUT); // sets the digital pin as output
pinMode(GreenLEDPin, OUTPUT); // sets the digital pin as output
void loop()
else
delay (20000);
Step 6: Arduino Clock Module
We finished the Arduino Time & Date functions using the Sparkfun DS1307 I2C RTC module, a 2 line LCD, and the Arduino Duemilanove. There are four connections from the DS1307 to the Arduino:
//pin SDA to Arduino Analog pin 4
//pin SCL to Arduino Analog pin 5
//pin GND to Arduino GND
//pin VCC to Arduino 5v
To set the time, edit the following section in the code with the correct time and date,
// Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call.
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1; //Sunday
dayOfMonth = 3;
month = 10; //October
year = 10;
and temporarily remove the // from the following line:
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
Upload your code to the Arduino, then put the // back in the above line, and upload again.
The complete code and wiring are posted at http://arduinotronics.blogspot.com/2010/10/ds1307-real-time-clock-working.html
