3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Audio Crayon - Making LEDs dance to sound
Introduction -
This instructable can be accessed at the author's website - http://www.neatinformation.com/
If you link to this instructable from another website, please also include a link to the Neat Information website.
Flashing LEDs in time to music is nothing new. But this is a new twist in the packaging to make it more interesting. The best thing is the cost - under $10 for all of the parts.
A simple electronics circuit takes an audio input and modulates the brightness of a group of LEDs in time with the music. While you could just use a group of LEDs why not mount them inside a semi-transparent plastic container?
I found a large crayon-shaped plastic bank in a discount store and immediately saw the potential for putting a light source inside the bank for some kind of decoration or novelty item. The bank I found measures approximately 22 inches (56 cm) long and 2.5 inches (6 cm) in diameter. It retails for about $7 but I was lucky enough to find it for a dollar.
Parts List
1 multi-LED flashlight
1 plastic crayon bank
1 LM386 amplifier
1 .1 mf capacitor
1 10 mf capacitor
1 250 mf capacitor
1 100 ohm resistor
1 10K potentiometer
1 3.5 mm mono plug
9V battery clip
hook up wire, PC board, etc.
9V battery
I welcome constructive criticism and inputs from those with more electronics expertise. If anybody can suggest a better circuit, or better values for the components in the circuit to improve the performance it would be welcome.
Step 1Preparing the LED flashlight and crayon bank
Most LED flashlights use three batteries for a total of 4.5 volts. They have anywhere from three to a couple of dozen LEDs. Any flashlight where you can remove the battery compartment and connect to the light assembly's contacts that fit inside the crayon bank will work.
The bank has a removable plug on its bottom. If you're lucky the flashlight will fit into the opening reasonably well. My LED flashlight was slightly larger than the opening. The crayon is made from fairly thin plastic and any knife sharper than a butter knife can be used to increase the size of the opening
2 comments
Feb 29, 2012. 11:09 PMcanucksgirl says:
That looks awesome philip! ;)
Jan 24, 2011. 1:04 AMDaHandy says:
Would this work on 14,5V voltage? LM386N-1 can only handle 4-12V but can there be a resistor before it so it lowers the voltage to under 12V? Could you make schematics for that? Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:philip42(Neat Information)
Writer, engineer, techie. I've been using computers since the original Apple II in 1978 and have always been interested in technical topics. Check out my articles on neatinformation.com. They include...
more »
