This is my first ever instructable... Feel free to let me know any thoughts on how to make the next one better!
Remove these ads by
Signing UpStep 1What you will need
1 dremmel tool with a number of attachments
1 standard corded microphone with removable audio cable
1 or two audio wire converters (depends on how long your barrel will be)
1wooden gear or other thin curved item that can be cut. This will be the trigger.
Two pieces of pine wood corner molding of your choice. Make sure one has a grove cut into it so the other can set inside of it. You'll see what I mean when you see the store's selection of corners.
Scrap leather (the softer the better)
Upholstry tacks (I chose brass)
Sheet of address stickers (the kind you put on your mailbox)
1 sheet coarse sandpaper
1 fine grained sandpaper sponge
1 pullchain hanger of your choice. These are the things people put at the end of the chains that hang from ceiling lamps and fans to keep them weighed down.
Flat wooden accent shapes, at least two of each shape you chose. The will greatly determine the overall look of the gun, so chose wisely. (can be found in the wood crafts section of Michael's)
Three halogen bulbs or glass radio tubes
Matte finish
One tube two part quick set epoxy
Plumber's epoxy
Gorilla glue
Acrylic paint, brass, copper and steel colors.
Lots and lots of patience!
Once you have your whole list of items gathered, it's time to go to work...
Well, either way, i know what ill be designing when i have the time
Two suggestions,
1, try and hide the microphone look of the rear.
2, If possible, aim for some slightly clearer pictures.
Otherwise, a great all round final piece.
