3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Automatic Button Pusher
Step 12Attaching The Actuator To the Magnet Base
The magnet base is designed to hold a dial gauge, a measuring tool used in machining operations. The magnet base uses a threaded rod and a knurled nut to hold the dial gauge on.
To mount the actuator, I ran a long screw through the bored out mounting hole on the actuator casing. Then I tightened the knurled nut on that screw, and the thread the entire actuator assembly onto the threaded rod of the magnetic base.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:travis7s
I like to build things... except for wiring.. wiring sucks.
