3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Automatic Button Pusher
Step 13Cut The Steel Mounting Plates
The magnetic base has a switch that will activate a powerful magnet that will hold the base tightly to any ferrous surface. I figured the easiest way to attach it to the clock was to add some steel plate to the top of the clock, and then just stick the base on.
I dug around my scrap bin until I found an appropriately sized strip of steel. It was not big enough to cover the magnet so I cut it into 2 strips instead.
I used a hacksaw again to cut the steel, the only difference was I used cutting fluid (Rapid-Tap) this time, it makes cutting hard materials a breeze!
Be sure to clean up the edges with a file, not only will it make the plates look better but it will protect you from nasty cuts as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:travis7s
I like to build things... except for wiring.. wiring sucks.
