3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Automatic Button Pusher
Step 8Find Your Triggering Signal
**Use caution when working on open electronics like this**
For our circuit to work we need a 5v signal that will appear when the clock radio's alarm goes off. This can be tricky because (as in my case) there may be no schematic available anywhere.
First I had to find the clock's microcontroller as that would have some output lines to turn the speaker on. This was pretty easy on my clock as it only had 2 ICs. The writing on the chip was faded so I had to guess what pin to use as the trigger.
I did this by first powering up the clock with no alarm set, and then (being careful not to short out anything) use a multimeter to measure the pins of the chip. In my case there was quite a few pins that were at 0v.
Then I set the alarm to go off and remeasured each pin. Some of the pins that measured 0v previously now read 5v. Hooray!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:travis7s
I like to build things... except for wiring.. wiring sucks.
