Step 4Sanding, Sealing & Painting
After we had a nicely sanded boat, we went a bit wild with the Silicone Sealant. This is not a bad thing as this is basically what keeps the water outside your boat and you dry. I gave the Silicone a good 24 hours to dry before I applied any paint.
After the Silicone has dried, you are ready to paint the boat. I used a Valspar Latex Enamel paint. We applied three coats to the outside surfaces of the boat (green in pictures) and two coats to the inside surfaces (tan in pictures). between each coat I waited the recommended time for drying and sanded lightly.
Now that I have had it in the water, I will put another coat on at the water level for some added protection.
One thing to note is that paint does not adhere well to Silicone so where ever your sealant is, your paint will not look very good. This is more cosmetic than a problem.
Seal exterior of seams first and foremost - sealer is to keep water out. Sealing interior joints can't hurt, of course.
If you add sealer (esp DuPont 5200) to joints before assembling (use as a "glue" as well as a sealer, you will seal exterior and interior simultaneously.
Silicone is for doors and windows, Not boats. It's a sealer, not an adhesive.
Wooden Boat magazine used to sponsor an annual family boat building event where the contestants (A parent/ child team) had to take a bunch of precut pieces and build a boat then put it in the water and hopefully not sink.
They were not allowed any fasteners. Only PL Premium.
It's available at the Big Orange Place for less than 5 bucks a tube. But read the labels and test for your self since there are different formulations. I'm pretty sure this is the one I used to glue the skin to the frame of my Hollow Wooden Surfboard (Instructable coming soon.)
http://tinyurl.com/7rqgzbh
Ok. It's less than 6 bucks a tube.
Good job on the boat.
Thanks
