3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Bare Minimum DIY Lathe
 Hi, Guys.
   I was cleaning up my work area, and found a project that I had left in a half-finished state: a super-simple lathe. Well, I finished it up, and got my lovely wife to take some photos, and video, in case anyone else needs something like this. This also doubles as a wheel grinder or wire-brush buffer!
Step 1Find an old hand drill, in good working order, and disassemble it.
 I found this solid metal-cased old drill at my local thrift store, with a damaged power cord. When i took it apart, I found several great mounting points I could use to attach the drill solidly onto mounting brackets.
I built the brackets for strength and rigidity, hence the 90-degree bends wherever possible, to stiffen the mounting. They are carefully measured to mount the drill level, pointed straight down the center of the 2x6. The height at the center of the chuck is exactly 6" from the base.
I attached the electrical cords to a good appliance cord with wire nuts designed for use in home wiring, the yellow ones with the "wings" on them, that you would get at a home improvement store. Since this project uses the 120V A/C from your wall outlets, electrocution/fire prevention are high priorities. I drilled a hole for the chuck key to be stored in, and secured the electrical cord to the 2x6 with a construction staple.
8 comments
Sep 1, 2011. 12:36 PMThe Bike Monkey says:
What are you using as a tool rest for when you re turning objects?
Jun 10, 2011. 9:51 AMtimothy demaegdt says:
use an old flat screwdriver that is modified on a grindingwheel as a chisel
Apr 27, 2010. 3:16 PMrimar2000 says:
Very good work!
Apr 26, 2010. 11:18 PMdepotdevoid says:
NIce one!  I could use a better description of how the sliding block works though.  What keeps it from moving once you're got it in place?
This looks like a great use for the old drill and old dremel I happen to have lying around, only I have no idea where I'd put it in my shop!
Apr 27, 2010. 6:38 AMdrawe21 says:
Put 2 eye hooks in the end and hang it from the wall when not in use.
Apr 27, 2010. 7:05 AMdepotdevoid says:
Love to, but the walls are full . . . I need to take some lessons from the guy who built the Tiny Workshop and use my space better.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:psymansays
Hi, I'm psymansays. I'm an engineer from California. I enjoy sunsets, and long robot test drives on the beach. More from me: http://psymansays.deviantart.com/ http://www.youtube.com/user/mobilisC...
more »
