The Basic Paracord Survival Snare
Introduction: The Basic Paracord Survival Snare
What is better than trapping and survival combined? Not much!!! above is a video by Blake Alma constructing the basic paracord survival snare.
The basic paracord survival snare is a noose tied to a stick that is anchored in the ground. It is designed to trap a small game animal by the neck. This snare trap is ideal for trapping chipmunks, squirrels, and rabbits. I typically use this snare to trap squirrels. I would recommend setting this snare in an area with high squirrel traffic, often by a red or white oak tree. Red and white oak trees shed acorns that squirrels love to consume. Squirrels are high in protein making it a great survival food. You will need the following items to build this snare:
  • Paracord
  • A 1-foot branch, that is also 1 inch in diameter
  • Two thin twigs that are “Y” shape
  • A knife
Step 1: Sharping Your Branch
After finding your trapping location, take your branch that is a foot long and make a point on one end using your knife. This will enable you to anchor the stick into the ground.
Step 2: Making a Groove
Make a circular groove slightly below the other end of the branch. This is where you will be tying your noose to.
Step 3: Paracord
Take 16 inches of paracord. Take out one of the seven inner strands in the paracord. This will be your noose.
Step 4: Making the Mini-Loop
Tie a small loop on one end of the paracord strand. Be sure it is very tight.
Step 5: Making the Noose
Take the other end of the paracord strand and enter it through the small loop on the other side. You now have your noose.
Step 6: Tying Your Noose
Tie the noose around the groove of the branch. Make sure it is tight.
Step 7: Anchoring the Snare
Anchor the branch into the ground, in your trapping location. Be sure it is sturdy.
Step 8: Trap Them Squirrels!
Use your two small “Y” shaped twigs to hold the noose up, so the animal can walk through the noose correctly. You have successfully set up your snare.
The animal will walk through the snare and the noose will tighten as it walks through. This will get you the food you need to survive for additional time. I would recommend have more than one snare trap in use.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    As a kid, I used to set snares for cottontail rabbits. I probably caught well over 200 in the space of 3-4 years. A much better material for snares than paracord is picture wire. Picture wire is the thin braided wire used to hang heavy pictures on a wall. it is available in most hardware stores and big box stores like lowes or home Depot and is not very expensive. The big advantage of picture wire is that it holds it shape well when not bearing a load. rabbits will either sense that they are caught and sit patiently until they hear the approach of a predator (you), or will immediately struggle and tighten the noose and strangle.
    -Esse vídeo poderia ser bem feito em 2:00 minutos!
    Essa é uma dica, pode ter certeza, eu não assisto vídeos com mais de 50 segundo.
    Forte abraço, vai dar certo.
