iImage Information
Here is a basic guide to adding numbers.
You wonder what adding it well here it is in a nut shell. It is basically adding numbers together with the + sign.
So in this Instructable you will help you learn how to add. This is just some basics to get you started with adding numbers.
(Also this is my first able so don't be harsh)
Step 1Adding Positive Numbers
iImage Information
For the first step with adding numbers you must learn the basics. The first one is adding positive numbers which are numbers that have a higher value than the number zero. An the symbol used for adding numbers are the addition symbol which looks like this "+" . To start off we will add the numbers 1 and 1 together which would look like this "1+1=?". To solve the problem you must know that if you adding one to one there will be two now because when you added the two numbers together your adding another number to that one group "1+1=2". You can also use a number line to help you add numbers together. This is the first step to adding numbers. Now on to step two to adding numbers larger than 1 and less than zero.
