Step 5Glue the Angle Guide Together
Check both the inside and outside edges to make sure the angle is correct.
Let this one dry.
After the first pair are glued together glue another pair. Slide the previous section up against the oustside to check the angel. It should fit perfectly.
Now glue the third and last section together.
All three sections should fit perfectly in each other if you hold them back to back.
Once they are dry glue all three together at one time. The angles should match pefectly.
Add Comment
