Most people have discovered that using credit cards can be a good way around this – if one is careful then floating your finances with credit can be a very good plan. However what many people do not realise is the benefit of 0% interest on balance transfers through using transfer credit cards.
What are balance transfer credit cards?
A lot of credit cards are basic things that simply give you the ability to use credit for a while to help with larger purchases. However what you can do if the interest on the credit on the main card you use is getting a little high, is to transfer your money onto another credit card, a balance transfer. But in order to find the best balance transfer credit cards , look out for cards that offer extremely low rates or even ones which offer you, mostly for a limited time only, 0 interest on balance transfers.
What are the benefits of this?
At times we can find it difficult to keep track of our finances, especially if we do have multiple credit cards. However you can save a lot of money and stress if you can master the ways to use some of the best balance transfer credit cards.
The ways in which you can use these is, as said, if a registration bonus is coming to its end, or if your card provider is simply putting up its fees, or even if you just think you can find one cheaper, you can use the offers advertised by companies that give zero balance transfer credit cards.
Simply put, there will most likely be a short to medium length time period where money that you have transferred to a credit card account will incur no interest, meaning you can use this window to save money.
With 0 interest on balance transfers you can save money, but only if you are careful. A lot of the time there may be extra terms and conditions, but if you use common sense and have read the fine print carefully, you can quite easily juggle multiple cards at the same time, meaning you will save a lot of money.
Look for other benefits too
In order to attract new customers, credit companies will often advertise with an added bonus, such as 0 interest on balance transfers , in order to try and reel people in. It is then your job to try and use this to your advantage, and if possible not to stay with that company afterwards – again read the small print before committing.
However sometimes you can find other added bonuses too. Quite often a credit card company or bank may offer money off other things, or after the 0 balance time period, a period of time offering relatively low interest on any credit used.
Make sure you are careful
As said, you should always read the fine print. This is simply because there are businesses out there that try to keep you through inaction on your part – however if you simply make sure you stay no longer with a certain company than you have to, you can have the advantage.
However as long as you use common sense, generally you can find the best balance transfer credit cards for you, and in so doing save an awful lot of money.
Add Comment
