The Best DIY White Board
Published
Introduction: The Best DIY White Board
About: I specialize in wood working and 3D printing/laser cutting. I am highly skilled at solid works,inventor professional, and corelcad, so I can model whatever someone wants. I'm also the student expert on the 3...
There are a lot of tutorials for making your own dry erase board. But most of those use panel board, over time the glossy coating wears off and this can cause ghosting. The design I created uses clear acrylic, which doesn't break down from the friction of the marker. It is also a much nicer surface to write on.
Step 1: Supplies
You'll need the following
•A small sheet of clear acrylic
•A piece of paper or card stock
•Duct Tape
Step 2: Assembly
Cut a piece of paper to fit the acrylic sheet, and secure the piece by wrapping the edge with a piece of duct tape torn in half
Step 3: Write
Now you have your own dry erase board that you probably didn't even pay for. This board will last for years and will never ghost, but it can shatter so be careful. I find the board to be very useful for balancing chemical reactions and for jotting down quick measurements in my engineering drawing class.
BTW: Please vote for this in the DIY University contest!
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Creative Misuse Contest
    2 Discussions
    After a week of using it everyday in honors chem and engineering drawing there's still no ghosting!
