The Best Matrix Falling Code Effect
171,184
21
19
Posted in TechnologyComputers
Introduction: The Best Matrix Falling Code Effect
About: Hey, I an average person, I have many interest including electronics, music, design and architecture. I also enjoy skateboarding in my free time when I am not working. I would really like to get into 3d prin...
Many versions of the falling code effect have been attempted. Many of them are fails, it is very hard to recreate the original, but the best one that can be redone in notepad, is this one. I have some pictures of some that are not as great as they could be, because they do not display random numbers, or even numbers at all. This script i great for the beginner in bat files, because it is very simple and very easy to understand. The code for this script is very simple and very easy to understand, it is actually surprisingly short also! You will notice this in the next step. (for experienced programmers it is very short!). Now, on to the code!
Step 1: THE CODE
Copy and paste this into a blank notepad document. (in between the hash tags)
@echo off
title AHHHHHH
color 02
echo This Matrix Affect was created by Superman
echo This program will shut down your computer!
echo The Matrix Effect begins in
ping -n 2 127.0.0.1>nul
echo 5
echo 4
echo 3
echo 2
echo 1
:superman
echo %random%%random%%random%%random%%random%%random%%random%%random%
goto superman
As I said this is a very short code,
if you don't want to know how this code works, skip to the last step.
Step 2: HOW IT WORKS.
As in my messenger instructable (https://www.instructables.com/id/How-to-make-a-Chat-Room-With-Notepad/), I will go through what every part does, if you don't want to learn how, just skip this part.
Next Step >>>>>----------------->
Step 3:
Here is how it works, pretty simple, could be made even simpler if you wanted to take out the count down.
Well, there it is.
Step 4: WORD OF CAUTION
Word of Caution, I was informed by an expert that this, left running, for to long, would have the ability to take down a computer. That was pretty obvious to me because the scroll bar goes all the way down to the bottom  instantly (Close it after watching it for a very short period). Anyway,USE AT YOUR DISCRETION, IT CAN DAMAGE A COMPUTER, DO NOT LEAVE IT RUNNING, I AM NOT RESPONSIBLE FOR ANY DAMAGE.
Step 5: SAVING AS a BATCH FILE
This is how to save your notepad as a batch file. Refer to the pictures below.
After you have saved it,CONGRATULATIONS, you have successfully created a good version of the Matrix Falling Code effect.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    19 Comments
    Mine says
    "'2884379244389' is not recognized as an internal or external command, operable program or batch file." And it just repeats that over and over again with a different number each time.
    What did I do wrong?
    Did you copy and paste it into the prompt? If you did, that's probably why. you will want to save notepad as a .bat file, then search for it in start and run.
    If you want to use my file, you can:
    @echo off
    title AHHHHHH
    color 02
    echo 5
    echo 4
    echo 3
    echo stop!
    echo 2
    echo 1
    echo I Warned You
    ping -n 2 127.0.0.4>nul
    echo err
    echo err
    echo err
    echo err
    echo err
    echo err
    echo err
    echo err
    echo err
    :superman
    goto superman
    I am afraid I have done better than all of you. Copy and paste it to notepad and save it as a (.bat) and open it from your documents. Enjoy! - Cake Kid
    @echo off
    mode 1000
    title Matrix
    color 0a
    set load=
    set/a loadnum=
    :Loading
    set load=%load%_
    cls
    echo Microsoft Windows [Version 10.0.14393] (c) 2016 Microsoft Corporation. All rights reserved.
    echo run backdoor
    echo Running Backdoor.exe
    echo %load%
    cls
    echo Backdoor [Version 9.3.03581]
    pause
    cls
    echo run Op3
    echo Running Op3.exe
    echo %load%
    cls
    echo Welcome to Shield Securities... Please Wait...
    echo Running HoundSecure ID Number...
    echo %load%
    echo HoundSecure member found!
    echo %load%
    echo Enter password __________
    echo %load%
    echo Running RC7 exploit...
    echo %load%
    echo Access granted!
    pause
    cls
    ping localhost -n 2 >nul
    set/a loadnum=%loadnum% +1
    if %loadnum%==20 goto Done
    :Done
    cls
    echo Running IP Recognition..
    echo %load%
    echo Internet Protocol Address Recognized!
    echo %load%
    echo Welcome, Mr. Reigns
    pause
    cls
    echo %load%
    echo Overriding system...
    echo %load%
    echo Injecting SSL coding..
    echo %load%
    echo Installing HXR v7.3...
    echo %load%
    echo Opening HXR v7.3...
    echo %load%
    cls
    echo This is the era of the Roman Empire...
    echo %load%
    echo %load%
    echo Adding Reclaim.exe...
    echo %load%
    echo From ashes to Empire..
    echo Extracting files..
    echo %load%
    echo Opening Spear...
    echo %load%
    echo Running Spear..
    echo %load%
    echo Enter the Empire..
    echo %load%
    echo 5
    echo %load%
    echo 4
    echo %load%
    echo 3
    echo %load%
    echo 2
    echo 1
    cls
    :romanempire
    goto romanempire
    @echo off
    mode 1000
    title MATRIX
    color 0a
    set load=
    set/a loadnum=
    :Loading
    set load=%load%?
    cls
    echo.
    echo Loading MATRIX... Please Wait...
    echo ----------------------------------------
    echo %load%
    goto Loading
    :Done
    echo.
    pause
    rem *your action here*
    echo This Matrix Affect was created by MR.CMD
    @MODE CON: COLS=1000 LINES=500
    COLOR 0a
    SETLOCAL ENABLEEXTENSIONS ENABLEDELAYEDEXPANSION
    FOR /F %%# IN ('COPY /Z "%~dpf0" NUL') DO SET "CR=seconds in%%# The Matrix Effect begins in"
    FOR /L %%# IN (10,-1,1) DO (SET/P " =%%# !CR!"<NUL:
    PING -n 2 127.0.0.1 >NUL:)
    cls
    :a
    set /a a=%random%
    if %a% geq 16384 set /a aa=1
    if %a% lss 16384 set /a aa=0
    set /a b=%random%
    if %b% geq 16384 set /a bb=1
    if %b% lss 16384 set /a bb=0
    set /a c=%random%
    if %c% geq 16384 set /a cc=1
    if %c% lss 16384 set /a cc=0
    set /a d=%random%
    if %d% geq 16384 set /a dd=1
    if %d% lss 16384 set /a dd=0
    set /a e=%random%
    if %e% geq 16384 set /a ee=1
    if %e% lss 16384 set /a ee=0
    set /a f=%random%
    if %f% geq 16384 set /a ff=1
    if %f% lss 16384 set /a ff=0
    set /a g=%random%
    if %g% geq 16384 set /a gg=1
    if %g% lss 16384 set /a gg=0
    set /a h=%random%
    if %h% geq 16384 set /a hh=1
    if %h% lss 16384 set /a hh=0
    set /a i=%random%
    if %i% geq 16384 set /a ii=1
    if %i% lss 16384 set /a ii=0
    set /a j=%random%
    if %j% geq 16384 set /a jj=1
    if %j% lss 16384 set /a jj=0
    set /a k=%random%
    if %k% geq 16384 set /a kk=1
    if %k% lss 16384 set /a kk=0
    set /a l=%random%
    if %l% geq 16384 set /a ll=1
    if %l% lss 16384 set /a ll=0
    set /a m=%random%
    if %m% geq 16384 set /a mm=1
    if %m% lss 16384 set /a mm=0
    set /a n=%random%
    if %n% geq 16384 set /a nn=1
    if %n% lss 16384 set /a nn=0
    set /a o=%random%
    if %o% geq 16384 set /a oo=1
    if %o% lss 16384 set /a oo=0
    set /a p=%random%
    if %p% geq 16384 set /a pp=1
    if %p% lss 16384 set /a pp=0
    set /a q=%random%
    if %q% geq 16384 set /a qq=1
    if %q% lss 16384 set /a qq=0
    set /a r=%random%
    if %r% geq 16384 set /a rr=1
    if %r% lss 16384 set /a rr=0
    set /a s=%random%
    if %s% geq 16384 set /a ss=1
    if %s% lss 16384 set /a ss=0
    set /a t=%random%
    if %t% geq 16384 set /a tt=1
    if %t% lss 16384 set /a tt=0
    set /a u=%random%
    if %u% geq 16384 set /a uu=1
    if %u% lss 16384 set /a uu=0
    set /a v=%random%
    if %v% geq 16384 set /a vv=1
    if %v% lss 16384 set /a vv=0
    set /a w=%random%
    if %w% geq 16384 set /a ww=1
    if %w% lss 16384 set /a ww=0
    set /a x=%random%
    if %x% geq 16384 set /a xx=1
    if %x% lss 16384 set /a xx=0
    set /a y=%random%
    if %y% geq 16384 set /a yy=1
    if %y% lss 16384 set /a yy=0
    set /a z=%random%
    if %z% geq 16384 set /a zz=1
    if %z% lss 16384 set /a zz=0
    echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
    goto a
    Do you know how to make it in python? Because I already knew the Batch one.
    And there is a way to make it display binary numbers...
    why do it with numbers? Letters make it look way cooler. Plus, if you have a custom font, you can use randomised letters and matrix font to make it look awesome.
    In Python you can import the random module and use random.randint() to create the numbers (or letters if you use chr). To use binary numbers, shove a bin() in front of the number to convert it, so:
    import sys, os, random
    #make it green
    os.system("COLOR 0a")
    while True:
    #if you want it all in one line that goes onto the next line after it fills, which is alot easier than putting random.randints everywhere
    sys.stdout.write(random.randint(bin(0,1000))) #or just use print()
    this is a really simplified version, but it should work. Use it as you want, I have a much better version (with scrolling lines of matrix code letters :D ).
    I added a shutdown command to the end of this.
    Many a computer class confusion, many thanks xD
    good job at the coding
    to slow down the scrolling just a bit add
    ping -n 2 127.0.0.1 >nul
    in between the second to last and last lines so it looks like this
    ping -n 127.0.0.1>nul
    goto superman
    you can add it as many times as you want until it is slow enough for you
    good, it is pretty cool trick that you can play on your friends.
    Unless your computer has about 100kb of ram, it won't take it down :P
