3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Best Way to Start BBQ Coals
Whenever I have trouble starting coals for my BBQ I grab a hair dryer, point it at my grill and pull the trigger. One minute later I have red hot coals and I never have to use any lighter fluid to get them started.
I have a couple of other tips for starting coals as well that I will add in here since I don't think they warrant their own instructables.
There's plenty more info in the steps, but the take home message is shown in the video below.
Step 1Use a Chimney
Use a Chimney
Using a chimney to start your coals going will really help get your fire going faster and with fewer problems.
Weber charges way too much for their chimney so I decided to make my own for free using some found hardware cloth and some metal wire I had lying around.
To make the chimney, I cut up a piece of hardware cloth and rolled it into a cylinder. I then used some metal wire to sew it shut. I only had to loop through every 5 holes or so in the hardware cloth.
The hardware cloth works pretty well as a chimney for two reasons. 1) It is full of holes so it allows air to flow freely through it, and 2) it doesn't require you to pick up the whole chimney of hot coals and flip them over onto your grill risking a possible burn or fire from a wayward hot coal. Instead, when it's time to dump the coals, you simply pick up the wire tube and the coals fall down onto the grill below.
84 comments
1-40 of 84next »
Sep 22, 2011. 9:18 AMMutantflame says:
Forget hair dryers, use a leaf blower! Much quicker (and smokier)!
Thats what we used to do anyways...
Mar 31, 2011. 8:50 PMdmlong says:
When it's hot outside, some people would ues a hand held paper fan to cool off. I have used one to give the fire some oxygen.
Jul 7, 2008. 5:15 PMarmourkris says:
i just built a blower into my BBQ. now i can cook steaks or forge weld steel.
Mar 12, 2011. 8:45 AMsethcim says:
Awesome!
Aug 13, 2008. 3:15 PMcatwood says:
Forging a steak would be interesting...
Aug 2, 2008. 9:14 AMcarpespasm says:
Take care when doing both simultaneously though.
Jul 30, 2010. 6:17 AMBillBiker says:
Now I like the air mattress pump idea VERY much! Battery operated, many people are in the open outdoors and have no electric so that is really cool. Another Idea is to use one of those air storage tanks fitted with a air blower nozzle for a more controlled blast of air. The food is like grrrr now you made me want to cookout today, lol. Thanks for the instructable was just what I was looking for.
Jun 10, 2009. 11:08 AMThe Ideanator says:
for getting fires going, i prefer an 8" circulation fan, those things get the coals white hot in seconds, they are like 10 or 15 bucks at walmart
Jun 11, 2009. 4:40 PMThe Ideanator says:
better yet, get a leaf blower, its like an oversized hair dryer
Jun 10, 2009. 12:35 PMredstarsrbija says:
forget the hair dryer, use an air compressor lol!
May 31, 2009. 8:41 PMYerboogieman says:
My dad's girlfriends kids think it's a good idea to just blow one fast but small burst of air, and they wonder why i get the fire started faster.
Oct 23, 2007. 11:52 AMejk00 says:
A couple of thoughts about the store-bought chimney: (1) the solid sides and holes at the bottom allow convection to be created, which typically accelerates the ignition of the charcoal, and (2) the size, shape, and handle of the chimney allows you to start coals off-line to be added to an existing fire - this is the method I use when I slow-cook barbecue and have to add coals every hour or so (I start them in the chimney on some rocks and dump the hot coals into the fire). Otherwise, your ideas are great. I'll be digging out an old hair dryer soon!
May 22, 2009. 7:32 AMdldeskins says:
These were my thoughts exactly. A "chimney" without the airflow coming from the bottom isn't a "chimney".
Aug 17, 2009. 2:05 AMthegrimace1234 says:
I know this comment is old, but you could turn your tower into a chimney with the addition of aluminum foil to the sides.
Oct 24, 2007. 9:25 PMRectifier says:
Looks like a great way to get the grill going at home! BTW, I own a store-bought chimney. $10 from Canadian Tire. I mainly bbq at the beach, where there is no power to run a blower - and for this, the convection of the chimney does the job of creating a draft to start the coals. It also contains the sparks to going upwards and not starting fires :P Takes about 15min to get them all going, though, so the hairdryer method definitely wins on speed! Maybe I can make up a hand-cranked blower to get them going faster at the beach, that would look super-sweet.
Jul 4, 2008. 2:44 PMBoost says:
Hot air gun let me start the BBQ without any paper or fluids. With a tight enough airstream it just takes a minute or two and the first coal starts to glow and then another minute or two I have a perfect ash-grey coal bed.
Jul 5, 2008. 1:25 AMcraig3 says:
how do you make a tight enough air stream with a hot air gun?
Jul 5, 2008. 2:31 AMBoost says:
There are usually some nozzles with the hot air guns to focus the air flow. The smaller the stream the more concentrated heat on the coals. After you get sparks from the first one you remove the nozzle and just heat everything up smoothly.
Jul 5, 2008. 3:29 AMcraig3 says:
ah, of course. I could only think of plastic nozzles and that they would melt, sorry i really wanna try this out but i don't know anyone that uses coals for a BBQ,the only ones i know just use gas
Jul 5, 2008. 5:42 AMBoost says:
Well that is another issue altogether. I prefer charcoal but I mostly use briquettes because it's more convenient. Regular charcoal gives of more heat but burn out in varying time. Gas grills is even more convenient, just turn the dial and it's on.
Jul 5, 2008. 6:27 AMcraig3 says:
don't correct me on this but in Australia i just don't see many charcoal Webber's all together, the only ones ive ever really seen at the gas ones
Jan 28, 2009. 10:44 PMlukeyj15 says:
(removed by author or community request)
Jan 28, 2009. 11:06 PMcraig3 says:
Thank you for that but if you dont have anything productive to say, why say it?
Jan 7, 2009. 4:49 PMllamafur says:
Oxy-acetylene For The Win.
Nov 19, 2008. 11:28 PMnibbler125 says:
i rember doin that with a leafblower :D
Aug 2, 2008. 8:45 PMMekasia says:
What is leaving your lungs is only like 16% oxygen, compared to, if I remember right, about 23% O2 in air. So, more oxygen from the external source than from your body.
Sep 5, 2008. 8:24 PMJamesRPatrick says:
If it works, it works. And it works.
Sep 5, 2008. 7:43 PMjongscx says:
yeah, but if you're saying that atmospheric "air" is 23%, and exhaled air is 16%, then we're only taking what, 7% of the available? I think that the 16% in the exhaled air is still more than whatever is in the air that's immediately around the coals as they're combusting and the rapid introduction by blowing more than makes up for that difference.
Oct 25, 2007. 6:31 PMjongscx says:
I use a leaf-blower to get the coals to the point where they're all ashy on the outside and perfect to grill on and don't flare up. Usually, people use this time to down a few beers, but I don't drink, so it's idle time to me...
May 16, 2008. 6:32 PMthoraxe says:
leaf blowers are just hella powerful, i'm amazed you dont have hot charcoal flying around and setting things on fire and making a huge mess.
May 17, 2008. 12:02 PMjongscx says:
it's an Art / learned skill. the angle that you blow air into the fire has a lot to do with this...
May 17, 2008. 12:44 PMthoraxe says:
do you blow it from the side or straight down on it?
Sep 5, 2008. 7:34 PMjongscx says:
It's more of an across the top kind of direction, so you get the kind of motion as you would when you blow on a jug and it makes a noise. What ends up happening is that you have most of the exhaust air of the leaf blower not actually going into the coals, but creating a vortex inside the grill that pulls air in. Since there's a lot of air moving over it, there's a lot of air being sucked in... but it's not a focused stream coming from the blower.
Jul 5, 2008. 12:21 PMNyanman says:
sorta like starting a pulsejet engine...
Sep 5, 2008. 6:16 PMtechnodude92 says:
Hmm... cooking on a pulsejet. I'd like to try that
Aug 5, 2008. 4:17 PMrediculosis says:
I'm just fascinated by the picture haha.
Jul 7, 2008. 8:50 AMGeoffrito says:
I did something similar with a big fan once. We were having a barbecue ouside in a park, and the grill was being stubborn. it was a huge tray type affair, so i precariously balanced a convenient floor fan on the edge and put it on high. it worked brilliantly. yay science!
Jul 7, 2008. 6:11 AMEvilblaze says:
The idea to catalyze the coals burning with plus oxygen is good, but I think it would be better to light it with a high temperature burning mixture, example: gypsum and aluminium:
The recipe can be found at:
http://evilblaze.extra.hu/
http://www.instructables.com/id/How-to-light-BBQ-coal-in-1-minute/
Oct 23, 2007. 1:22 PMcrapflinger says:
my uncle built a barbeque pit in his back yard way back when...it was sweet...really large had a smoking area...adjustable grill hights etc...etc... he got a small industrial blower and mounted it on the side with a switch...he'd light a few coals....let em get started then flip that blower on....you could almost melt glass in that grill if you turned the blower to the right speed
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
900
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
