Step 4But What if I Don't Have a Hair Dryer?
The fire is fueled by oxygen, so if it's having trouble burning, you probably want to try and get it as much air as possible. Blowing on the fire is fine, but you'll find that you will be out of breath pretty quickly and you won't have helped revive your fire too much. You can get a much more powerful jet of air by directing it through your fingers.
Take your pointer fingers and your thumbs and squeeze them all together so that you create a small diamond shaped gap in between your fingers. Take a deep breath at this point. Then, take your fingers in this position and raise them to your mouth making a tight seal around your lips. Finally, blow all of the air out of your lungs forcing it through that little hole.
You'll notice that when you could only blow for a few seconds before, you will now be able to blow air on the fire for much longer and with greater control and force. The coals should flare red and respond quickly to your oxygen infusion. Keep blowing until the coals are revived remembering to take breaks so that you don't pass out. (This works best if you can get a friend to help blow on the fire as well).
4
comments
Add Comment
noahw (author)
says:
Add Comment
