3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Bio-Battery - Power for the future. (So easy a 10 year old can do it.)
Follow and learn how a 10 year old girl builds her first serious science project, "The Bio-Battery."
See how this young lady, my daughter, astounds her 5th grade class with her project constructed from simple parts from a local electronics store, some instruction from her father, and some house hold edibles and powers a light with it all. Warning! You may become enlightened.
Submitted to the "Science Fair Contest" which is sponsored by AMAZON.COM You will see some AMAZON.COM promotions that I put in. This is part of the requirement for the contest and a thank you to Amazon for supporting it. Thanks for reading. Enjoy.
Step 1Consumable Materials
  • last photo ←
The follow materials were used to complete this project.
(1) Plastic Project box Purchase on Amazon.com
(1) Momentary Push Switch Purchase on Amazon.com
4 Copper Pennies
4 Lemons (or other citrus)
4 Potatoes
(4) Galvanized( Zinc) Cotter pinsPurchase on Amazon.com
A length of 18 Gauge telephone wire Purchase on Amazon.com
(1) 3 volt 5mm Blue L.E.D. light (Light Emitting Diode) Purchase on Amazon.com
(1) 5mm L.E.D. light mount/holder Purchase it here (Sorry Amazon)
(2) 2 Inch x 4 inch PVC pipe coupling or PVC pipe -----(Purchase at local hardware store)
(1) Acid brush Purchase on Amazon.com
(1) Project board (plywood or even cardboard)
Small amount of Bernzomatic Rosin Core Solder Purchase on Amazon.com
Small amount of "Elmer's Blue Bull Polly Glue" Purchase on Amazon.com
See all of the pictures below.
103 comments
1-40 of 103next »
Sep 9, 2008. 11:17 PMmetal-matt says:
uhh call me unsafe, but i dont realy think that you NEED safety glasses when soldering, i dont...when you useing drills,dremels,sanders,routers,jigsaw ECT ECT yes you should use them then but gawd, soldering??? anyway good instructible very well writen, only thing is mayby you should "make" a battery out off it, like get a pvc pipe of something and make it look like a battery, becaust i dont think that many people would carry lemons around, like not many people would carry battery acid around with them......hmm meyby i should make a lemon flavord (and that works) battery lol.....that got me think'n.....MUAHAHAHA!
Jun 26, 2009. 7:05 PMamplex says:
if you havent had solder 'spit' at you (especially when cleaning the tip on a slightly wet sponge/steelwool right before making a new solderjoint) then you havent soldered much. i worry about one hitting my eye one day and have considered starting to wear glasses when soldering, but yeah in the past year i have been hit by at least 5-10 solder 'spits' usually on the hand or forearm. but now i use steel wool not a wet sponge so the chances are drastically lessened.
Feb 10, 2010. 9:24 PMcdousley says:
i had it spit while cleaning. but safety glasses are rarely needed, places to use them
1.grinding
2.cutting metal
5.weed eating for sure
Jun 25, 2009. 7:43 AMBartboy says:
Yes, you should. Although, a respirator would make a lot more sense....
Nov 15, 2008. 6:50 PMDELETED_evilfrogie says:
(removed by author or community request)
Jun 11, 2009. 5:54 PMReCreate says:
you are more likely to get struck by lightning than that happening. And you are more likely to die of a falling coconut than getting struck by lightning
Jun 11, 2009. 8:05 PMDELETED_evilfrogie says:
Jun 11, 2009. 9:18 PMReCreate says:
Did I Ever Say that anything will kill you, Other than The less than likely coconut?
Jun 12, 2009. 3:03 AMDELETED_evilfrogie says:
Jun 12, 2009. 8:11 AMReCreate says:
Ok then
Oct 15, 2009. 9:15 AM_Scratch_ says:
don't underestimate those 10 year olds. =P
Dec 30, 2009. 6:10 AMallenmt says:
im ten
thanks :}
Jun 11, 2009. 5:55 PMReCreate says:
Maybe Building a joule thief would have been a bit better, and it would require less lemons, Well i don't know, Its probably a bit too late now XD
Mar 7, 2009. 3:49 AMcybercorfu says:
The moving force is called Current and we measured it with Amperes... Volts is the strength of that current.
Mar 13, 2009. 11:20 PMCrucio says:
My understanding is that voltage (which is AKA EMF or electro-motive force) is the "moving force". Current is the flow of electrical charge.
Mar 14, 2009. 5:11 AMcybercorfu says:
OK lets say we have 1V and 200A with this source we can melt an electrode of 5mm and in reverse we have a source of 200V and 1A what we do with that? just a spark well now, what in this two sources is the one with the more force?
Mar 14, 2009. 1:12 PMCrucio says:
The ability to melt an electrode is not the definition of force. In your example, you're helping show why voltage used to be called EMF. In a 1V/200A scenario, the voltage will not arc noticeably because there isn't enough "moving force" or "pressure" to jump gaps. Voltage is required to push through resistances.
Notice also that the same amount of power exists in both cases. (When I studied EE in college, we used the formula p = i e where p is power, i is current, and e is EMF (voltage).)
insomartin's water analogies describe it well, though it might be easier to think of current as the flow rate.
Mar 14, 2009. 6:04 AMinsomartin says:
let's assume it's water... voltage is the pressure at any given time. and Current is the amount of water in at any given time you can fill a bucket (capacitor) hour glass shaped pipe (resistor) transistor or vacuum tube or a switch (valve) fountain (antenna) a overhead tank (power supply) a sea wave could be (AC current) hydro pump/motor/tubine piston as a (solonoid)
Mar 16, 2009. 2:50 PMcybercorfu says:
Nice approach!
Feb 10, 2010. 9:27 PMcdousley says:
The water confuses me a little my way of thinking volts is how strong the charge is current is how much is there.
I love the water thing btw
Jan 11, 2009. 11:19 AMnowuknowjack says:
Reading all the comments, no one mentioned the use of the scientific method. # Ask a Question # Do Background Research # Construct a Hypothesis # Test Your Hypothesis by Doing an Experiment # Analyze Your Data and Draw a Conclusion # Communicate Your Results I couldn't quite see all your display board to see all the steps, but it look svery well done. As a home school parent and 4-H leader, Good job!
Dec 23, 2008. 12:10 PMReCreate says:
"So easy even a caveman can do it" it just comes to mind
Dec 7, 2008. 3:16 PMpindalanderz says:
very interesting. great experiment! one of the coolest experiments I have ever seen. 5/5
Aug 15, 2008. 8:22 AMtwenglish1 says:
hey great instuctible, and why is your penny silver??
Aug 15, 2008. 7:58 AMscience_geek1 says:
coll like really. good job. hope u get many more good ideas
Jul 12, 2008. 10:49 PMBig jermini says:
good work on the project. im into alternative fuels my self. did you know a can of pop can have some voltage output? quick idea for your next science fair project. Reading the voltage produced by light! i believe there is an instructable onhow to do this, but it would be fun to get creative with. Basic thought. rig an led to the leads on your multimeter. tape up the cord so you have a hand free from holding it. Set the multimeter to the lowest voltage possible. start going up to lights and seeing how much voltage you read. use your free hand to cover up the led to make comparisons. try it out sometime! although not practical for alternative fuel may be able to help recharge small batteries. this is also what a photo diode is based off of. only tweaked out a little more. keep up the good work and for the love of all that is good and great don't smoke, drink or even attempt to think about trying or getting hooked on drugs!!!!! have a nice day!
Apr 6, 2008. 9:45 PMduck-lemon says:
Jun 16, 2008. 1:44 AMGavabc123 says:
don't forget how a volcano works
Mar 23, 2008. 9:10 AMPoppa Chubby says:
Great instructable, and a good experiment. I have to ask though, doesn't smaller diameter wire have higher resistance than larger? If you think about a pipe full of water, (using the water analogy), it is easier for water to flow through a larger pipe than a narrower one. Isn't that why larger gaged wire is used for higher power applications? I think the phone wire is perfect for this experiment, but I would stop short of saying it had less resistance than thick wire. Just sayin'
Apr 15, 2008. 11:21 AMDecepticon says:
Actually, larger wire is used for higher power so the power lines don't burst into flames due to the huge amperage. larger wires (smaller guage) are needed to carry higher current.
May 9, 2008. 5:56 AMMercuryRising says:
Actually, the power company cheats this by sending the power at an extremely high voltage, then using a transformer to convert it to 115v. The extremely voltage gives you the same power as your home voltage, but 20,000v @ 1 amp will be the same as 173 amps at 115 vac. If they transported the power at 115 v on all the power lines, the wires would have to be 6 times bigger to avoid bursting into flames. Now I hope life starts throwing me lemons.
May 9, 2008. 6:26 AMPoppa Chubby says:
Exactly right. But my original comment was aimed at the assertion that smaller wire has less resistance. Not an entirely accurate statement.
Mar 23, 2008. 8:55 PMazes says:
Can we just plug-in to a bunch of lemon on a tree so we can get a 'living' battery??
Mar 24, 2008. 9:17 PMazes says:
hypothetically,if we have a grove of lemon trees ,with a computerized monitoring system (to monitor the amount nutrients in soil/sunlight/electrical output/etc),we can have our own self-sustain power supply,can we?
Mar 24, 2008. 10:21 PMbrainiac says:
mmm... finaly a way to power my lab all thoes lemon tees in th back
Mar 23, 2008. 2:37 PMA good name says:
Technology for the future isn't what I'd call it, this won't last forever, the lemon will lose it's charge eventually. It's a great project, but I think it could be better with a little tweaking.
1-40 of 103next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
48
Author:Mr. Rig It
I like to build, create, and invent new things to use in life. Sometimes I like to share them with others, that's why I joined Instructables. :-)
