3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Bio-Battery - Power for the future. (So easy a 10 year old can do it.)
Step 7Installing the switch and holder and LED.
1. Now that the holes are drilled Holly installs the LED into the holder. The LED holder has two little holes one for each of the wires of the LED to route through.
Once in position the light will not move because the inside of the holder has a rubber type of grommet that keeps the wires from moving, it is a snug fit.
**Info Note** Not all LED's have wires attached much less plastic connectors. If yours has the connectors, cut them off and strip the wire to install the LED into the holder (that is if you are using the same setup as Holly has). Holly's LED did not have wires connected, but we will get to that in the next step.
2. At this point Holly installs the switch and holder in to the panel of the project box and tightens the nuts down on each one, this secures it to the box.
See all of the pictures below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
48
Author:Mr. Rig It
I like to build, create, and invent new things to use in life. Sometimes I like to share them with others, that's why I joined Instructables. :-)
