Introduction: The Bischoff 720 A.T.S (Accurate Targeting System)
Check my Scorpion 360 C.D.M too!
Here it is: The Bischoff 720 A.T.S
This is my biggest and most sweet knex gun, and the shooting system is inspired on Killerk's firing system
It has a range of at least 175 ft and the accuracy is up to 110 ft!
I think it's my personal best because of the range.
Very fun when sniping on targets.
Pros:
-Kick ass design
-Can pierce a bucket from a distance of 3.5 m
-True trigger
-Two handles
-Very accurate
-Very powerful
Cons:
-The bipod isn't foldable
For short:
It's a very recommandable sniper rifle.
Step 1: Collecting Materials
Rods:
12 greys
8 reds + 1 red (bullet)
7 yellows
29 blues
114 whites
108 greens
Connectors:
110 yellows
44 greens
18 light greys
28 oranges
22 greys
32 reds
6 whites
2 dark blue
Exotics:
1 tan clip
2 metallic blue clips
3 y-shaped connectors
8 blue spacers
2 gray spacers
Also needed:
2 rubberbands
1 snapped rubberband
1 small rubberband
normal tape
duck tape
This is what you'll need to make the gun.
Step 2: Upper Stock
This part isn't necassery but it makes the stock a lot more resistance proof.
Step 3: Bullet Holder
This part is for letting go of the bullet when you pull the trigger.
Step 4: The Barrel
The most time consuming and finger torturing part of the gun, but it's necassery.
Step 5: The Trigger
This part is very necassery, assuming that it locks the bullet in place
Step 6: The Bi-Pod
This part isn't necassery but it comes in handy when sniping because you will have a stable base to aim.
build it twice.
Step 7: Rubberband Shooter
This part is to tie the rubberband in place and so that you can pull back the band.
Step 8: Stock
This part is pretty important for looks, strength and, it makes a comfortable handling when shooting.
Pic 5 needs to be built twice.
Step 9: Barrel Bars
This part is required because if you would'nt put it on, the barrel would be all shaky and that's a less accurate shot, which is annoying.
Step 10: Handle Bars
These parts are for a more comfortable handling of the gun.
and they spare you some painful fingers.
Step 11: The Bi-Pod 2
Connect the two bi-pod sides as shown.
Step 12: Putting Together the Barrel
pic 1: get the pieces
pic 2: bullet holder + barrel
pic 3: put them together
pic 4: barrel + barrel bars
pic 5: put them together
pic 6: rubberband holder + barrel
pic 7: put them together
Barrel Completed.
Step 13: Trigger + Barrel
Connect the trigger as shown on the pics.
Step 14: Trigger + Stock + Handles
pic 1: Trigger + Stock
pic 2: Put them together.
pic 3: Trigger and Barrel + Handles
pic 4: Put them together.
Basic model completed.
View next steps on how to load, which ammo you should use, how to put the trigger rubberbands and how to assemble the Bi-Pod.
Step 15: Ammo
The bullet is a red rod with a tan clip on the front and duck tape on the back for some stabilising when in the air.
Step 16: How to Put on the Trigger-rubberbands
Put the rubberbands as shown.
Step 17: How to Load
Put the firing band behind the tan clip.
pull it back.
click it on the y-shaped connector.
Step 18: Assemble the Bi-Pod
Put on the bi-pod as shown on the pictures.
Step 19: Your Done!!!
Well,
You've built yourself the Bischoff 720 A.T.S
Have freaking much fun with my knex gun!!!
