The Blob
6,006
92
8
Published
Introduction: The Blob
It's summer time and the kids are stuck inside playing when they should be outside enjoying the wonderful outdoors. What's the best way to beat the heat? An expensive water slide park? Maybe, but for my family, its The Blob! You can run, jump, stomp and just lay on it. Watch the waves that you create as they roll from side to side,
The original idea for this project came from Pinterest by the Clumsy Crafter. I thought that it was an amazing idea and that it would be so much fun...and it is!!
It's so simple, you only need a few supplies beat the summer heat.
Step 1: Materials
-4 MIL Plastic Sheeting (3 MIL will also work too)
-heavy duty duct tape
-blue food coloring
-hose and water
Step 2: Plastic Sheeting
First you are going to lay out the plastic sheeting flat on the grass, then just fold it in half. Once the plastic sheeting is folded on itself, tape the open edges. For the best results, make sure to fold over the plastic sheeting before taping. *make sure to leave a small opening for the hose to fit through
Step 3: Watering
Now you're going to utilize the hole that you left open in the plastic sheeting. Just add the water to that spot and as it's filling the blop up, add drops of food coloring. This color will fade throughout the time you're blobing.
As you are filling, you will probably notice a few leaks, this is normal. Just tape them up and it should be good as new.
It took me about an hour to fill the blob.
Caution: make sure you setup your water blob on a flat surface because it will start to roll as it fills up
Step 4: Finish
When you are satisfied with the amount of water in the blob, take the hose out and tape off that section.
Now all that's left to do, is to laugh and enjoy.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Just did this with the xtended family over easter. With the temp about 60 and sunny, pretty much everyone layed on it and felt how warm and squishy it was. Yes 3M heavy duty duct tape. It leaked but really slowly and wasn't a big deal.
    Any photos of people enjoying this? It's tough to visualize all the ways in which the blob could be enjoyed. Video perhaps? Recruit your cousins again or something?
    This has the potential to be an every year type project that people do because the supplies are easy to find and the assembly instructions are clear. (Plus, it's a bit like a Dexter shopping trip with an innocent result.)
    A great lead photo with kids bouncing on one of these bad boys could drive traffic your way like crazy. Throw in some Amazon affiliate links for the plastic and the 3M tape, and you could maybe get a little something out of it besides happy cousins.
    I can't believe it doesn't all leak out right away. Interesting idea
    Little leaks were common in the beginning but we swiftly fix them and it lasted a long time
    Interresting idea, I need to try this next summer. But I would think that it would not stand up to kids stomping around on it... How well does it?
    We did this with my little cousins who are 2, 8, and 10 and The Blob lasted for about 3 hours.
    does the upper surface have ripples when it's windy? That would look cool!
    Yes, the wind does generate ripples when the blob is not completely filled
