Step 5Exterior Construction
- Prepare your choice of frosting (here, whipped cream).
- Again, taking a golf-ball sized dollop of frosting, carefully spread it on top of the cake with a spatula.
- Work slowly and add more as you need it, moving on to the sides after you finish the top.
- If you're using whipped cream like I am, put the cake in freezer for about 5 min after the interior is completely coated as a safeguard against meltdown.
- Don't worry about smoothing the surface, because the exterior of the cake in the game has a very rough surface. Convenient, no?
- To match the color of the cake, you can add food coloring to a batch of white frosting, or in my case, add chocolate shavings to mimic the texture and tone of the surface (they'll stick to the whipped cream and completely cover any traces of white on the surface. The recipe in the game suggests using one can of "prepared coconut pecan frosting", if you can come by that.
- I went at squares of baking chocolate with a knife, but box graters work too.
- Then I took the shavings and applied them to the coated surface of the cake with a spatula, making sure the board the cake was resting on aluminum foil to catch stray shavings. Press gently to minimize the white appearance of the cream.
4
comments
Add Comment
Add Comment
