Introduction: The Cannibalistic Pumpkin
Picture of The Cannibalistic Pumpkin
I have always loved the idea of a pumpkin eating other pumpkins because it looks really cool and is not very common. In this instructable, I am going to show you how to make a cannibal pumpkin, so you can 1-up all of your neighbors by having the most awesome pumpkin.
Step 1: Materials
Picture of Materials
In order to create your pumpkin cannibal you will need to gather the right materials. This kind of goes without saying, but you will need a pretty big pumpkin and one or two much smaller pumpkins. Next you will need to collect the right cutting materials. You may need to purchase a pumpkin carving kit. You will only need to buy this once, and then you can use it for many of the years that follow. In the pumpkin carving kit there was a scooper for the insides of the pumpkins, two cutting utensils, one for larger cuts and the other one for more precise cuts, and finally there was a marker that acted like a dry erase marker for pumpkins. We also cut up a trash bag to work on because this does get pretty messy.
Step 2: Cleaning Out the Pumpkins
Picture of Cleaning Out the Pumpkins
In this step we are going to cut a circular hole with the bigger blade on top of the pumpkins around the stem. We then use the scooper to scoop out all of the insides of the pumpkins. Save some of the insides we will be using them later in the project. We then repeat those two steps for the two smaller pumpkins. In order to scoop out the insides of the two smaller pumpkins you may need to use a spoon instead of the scooper because the hole will not be big enough. On the pumpkin caps you can cut off the bottom layer, and that will probably be the easiest way to clean it. Look at the image shown if that confused you.
Step 3: Drawing Your Design
Picture of Drawing Your Design
I used the marker to draw on my design. You can use stencils if you would like, but we just decided to draw our own design on there. This is a very important part. MAKE THE MOUTH BIG ENOUGH FOR THE LITTLE PUMPKINS TO FIT IN IT. If you do not do this your whole idea could be ruined, so measure twice before you decide to cut. Also, you may want to make the end teeth on the bottom jaw a little bit longer than the rest. This is so the teeth will go through the little pumpkins better. You can change the design as much as you want before you cut, just use a wet paper towel or a wet rag to get rid of the unwanted lines.
Step 4: Start Carving
Picture of Start Carving
It does not matter what part of the pumpkin you start carving first. Just make sure you follow the lines as best as you can. For smaller cuts and corners, I would recommend using the smaller blade because it is a little more precise. After cutting the mouth and eyes I erased the nose with a wet rag. I just didn't think the first one looked as good. After you cut, use the wet rag or a wet paper towel to wipe away any marker that may be left on the pumpkin. After you have carved the big pumpkin it is time to start on those little ones. You'll need to draw your design on the little ones then cut again.
Step 5: Putting the Little Pumpkins in the Mouth
Picture of Putting the Little Pumpkins in the Mouth
For the little pumpkins we are going to need to put an additional hole in the bottom. This is so we can place the little pumpkin on one of the teeth of the bigger pumpkin. One problem that came up was that the big pumpkin was too thick, and the bottom hole of the little pumpkin was too small, so it could not fit. To fix this you just need to cut the end tooth horizontally. It will help to look at the pictures. You need to cut enough off so the tooth will fit inside the bottom hole of the little pumpkin. Now put the little pumpkin on the end tooth so the end tooth comes through the bottom hole of the pumpkin. Then put the cap with the stem back on and that side is good to go. Now we need to do the other side. Again, we cut the bottom tooth on the other end of the mouth, so the other little pumpkin could fit in there. However, we wanted the little pumpkin on the right side to stick out a little like the big pumpkin is taking a bite out of it. In order to this we cut another hole on the back of the little pumpkin. This hole is on the exact opposite side where we cut out the face. This hole will catch on to the top tooth to keep the little pumpkin in place as it hangs outside the cannibal pumpkin's mouth.
Step 6: Final Touches
Picture of Final Touches
For the final touches we are going to add some of the pumpkin guts to the outside to make it look like the little pumpkins are bleeding and vomiting. The pumpkin guts are what we took out of the pumpkin earlier. Put as much pumpkin guts as you want around the mouth of the big pumpkin and coming out of the smaller pumpkins. Finally, we have our pumpkin cannibal.
Hunterman359 (author)2016-10-25
lit
NickOng98 (author)2016-10-20
Great concept..but I see a few flaws..
So when the pumpkin eats the baby pumpkin, do we need to carve out the stomach of the cannibal pumpkin as well? I guess in a better way of saying this, where do the baby pumpkin go after it's eaten?!?
Also, this design makes it so that the pumpkin has eye sockets but no eye balls..how could it see what it eats??
And lastly, what was the particular reason that pumpkins started eating pumpkins in the first place? Was there some kind of apocalyptic war of pumpkins or something?
Clearing some of these things up, I think would greatly improve this work of something.
Thanks
MalloryAnn (author)NickOng982016-10-22
Someone has nothing to do with their time. It seems as if you were just trying to find things wrong. You're stupid. This really is a work of art. I would love to see Mdanna7 come out with other How Tos! Great pumpkin, two thumbs up!
Killadannabro (author)2016-10-19
Best pumpkin I have seen in ages
Johnhamil (author)2016-10-19
Wow! Awesome idea. Let me start off by saying, it is clear that the artist has a great understanding and appreciation for the art of pumpkin carving. As a fellow pumpkin carving aficionado - I can easily see the skill and talent that went into creating this.
My friends, just take a close look at the artist's hands in the picture. At the same time they are callused yet soft, aged yet youthful, dirty yet clean - they are clearly perfected by years of practice.
Although his skills greatly surpass a regular persons, this piece is easy enough for a lay person to recreate.
The instructions are so easy to follow, that if my newborn son was able to drive to the store, buy a pumpkin, able to use a knife; he could easily make one by himself and everyone would be impressed. Since he can't do any of that, I had to do it myself. It took me less than 30 min to make one!
Sisssy17 (author)2016-10-19
What an incredible display of Halloween spirit. Subtly scary, but very tasteful display. As someone who has particularly loved this season for over a quarter of a century, I feel reenergized by the youthful display of creativity and intriguing twist on such a classic "jack-o-lantern". I'd love to sit down with the artist and discuss his motivation behind creating such a deeply scary, yet meaningful and provocative piece.
Easy to recreate. Two thumbs way up, and luckily intact- these wonderful instructions made pumpkin carving easy and safe for my entire family.
Mailee97 (author)2016-10-19
Digging the idea!
MasonDouglas (author)2016-10-18
Wow. This is the most creative pumpkin in awhile. The scariest pumpkins are the ones that eat other scary pumpkins. Well done.
NancyB24 (author)2016-10-18
This is so cool.
About This Instructable
1,349views
27favorites
License:
More by MDanna7:The Cannibalistic Pumpkin Great Tasting Puppy ChowM&M Cookie Bars
Add instructable to:
