The Cash Riffle
Introduction: The Cash Riffle
Project overview
In this project you will learn how to make your self made money-shooter or how we like to call it "The Cash Riffle"!
What do you need?
  • Arduino kit
  • Motor Shield
  • HC-SR05 / HY-SRF05 Precision Ultrasonic Sensor
  • Power Supply 6V DC
  • DC motor 6V
  • Double-sided tape
  • UHU POR glue
  • MDF 3 mm
  • Rubber
  • 1.000.000 dollar (If you don't have so much money, you can print fake ones like we did)
Step 1: Lasercut the Cash Riffle Box
Take a 60cm by 30cm MDF 3mm sheet and place it in the Lasercutter. You can find a link down below to download the box template we used.
The box is easy to set up. It's designed in a way that the Arduino and breadbord are keeped seperated from the money and the motor.
Use some UHU-POR to glue the left part of the box togheter. This is the part where the money should shoot from the box.
Step 2: Lasercut the Wheel
Now download the template below and lasercut the wheels. Attach the wheels with some UHU-POR togheter and press the wheels togheter until the glue has dried. Cut some piece of the rubber and attach this to the double-sided tape. Use some UHU-POR on the wheel and attach it to the rubber.
Tip: If you want more grip, you can use a rubber band like we did.
Step 3: Assemble the Electric Circuit
Attach the motorshield on your Arduino and assemble the circuit using the supplied cables:
  • VVC connection of the sensor attached to +5
  • GND connection of the sensor attached to ground
  • TRIG connection of the sensor attached to digital pin 8
  • ECHO connection of the sensor attached to digital pin 13
DC Motor
  • Red cable of the motor attached to PWR +
  • Black cable of the motor attached to PWR -
Step 4: Arduino Code
Copy the code below into the Arduino Software and attach the USB to your Arduino UNO
const int TRIG_PIN = 8;
const int ECHO_PIN = 13;
void setup() {
// initialize serial communication:
//Setup Channel A
pinMode(12, OUTPUT);
//Initiates Motor Channel A pin
pinMode(9, OUTPUT);
void loop() {
long duration, distanceCm, distanceIn;
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(TRIG_PIN, LOW);
digitalWrite(TRIG_PIN, HIGH);
duration = pulseIn(ECHO_PIN,HIGH);
// convert the time into a distance
distanceCm = duration / 29.1 / 2 ;
distanceIn = duration / 74 / 2;
if (distanceCm <= 0){
Serial.println("Out of range");
} else if(distanceCm <= 100 && distanceCm >= 0){
Serial.println("motor AAN");
digitalWrite(12, HIGH);
//Establishes forward direction of Channel A
digitalWrite(9, HIGH);
//Disengage the Brake for Channel A
analogWrite(3, 255);
//Spins the motor on Channel A at full speed
delay(4000); }
else if(distanceCm >= 100){
Serial.println("motor UIT");
analogWrite(3, 0);
Serial.print("in, ");
Serial.println(); }
delay(1000); }
End Code
Step 5: Put Everything in Place
Put the Arduino and all the cables in the box. Assemble the sensor in a way that fits your target direction. And finish the last things to complete the design of your box.
Step 6: Let the Fun Begin!
Place the Cash Riffle at a fun place... Hide yourself... and watch people surprise themselves when they walk in range of the Riffle.
Don't forget to tell your friends about this awesome project!!!
Have fun!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    That's a fun idea :)
