The Cat Launcher - Energetic Cat's Workout Toy or Just a Lazy Owner
44,503
209
43
Posted
Introduction: The Cat Launcher - Energetic Cat's Workout Toy or Just a Lazy Owner
Battery Powered Contest
Finalist in the
Toy Contest
Second Prize in the
Toy Contest
Kit Contest
Finalist in the
Kit Contest
Here I'm glad to present to you my next invention!!! - The Cat Launcher
This toy is for your cat or dog or other lovely friend that is going absolutely CRAZY to chase a moving object!
With this crazy machine you pull the string away from it ... place the string with the SHINY object at its end in front of the cat ... back off ... and ... press the launch button!
And then what you see is an animal desperate to catch the attractive bow!
Step 1: Lazy Cat in Action
Here is a short video that shows the Cat Launcher in action!
Step 2: How to Launch the Cat?
1: Put the switch to Astronaut mode.
2: Press the launch button and enjoy the cat orbiting around.
I'm sorry for the blurry photos, but cat is too fast!
Step 3: Parts Supply
These are the basic parts needed.
LEDs may be skipped, I have them just to make it more interesting.
You need:
  • A plastic box
  • Switches
  • Small DC motor from a toy
  • Reel and string
  • Battery holder and batteries (holder for two or three 1.5V batteries)
  • Cables and heat shrink tubng
  • LEDs (optional)
  • Labels (optional)
Step 4: Tools Needed
You may need:
  • Drill and bits
  • Knife
  • Gauge
  • Soldering iron and soldering wire
  • Zip ties
  • Cable cutters and Pliers
  • Hot glue
Step 5: Layout Planning and Connections Circuit
The circuit schematic shows all the connections. For simplicity one of the speeds can be omitted as well as the LED.
Ensure that the box is large enough to fit the motor, battery holder as well as the switches.
Step 6: Battery Terminals
I used a battery holder out of a flashlight.
Because the motor spins too fast at 4.5V, I soldered a cable at the 1.5V spot to have two different speeds for the operation.
NOTE: Use the first positive terminal as shown on the schematic diagram. The negative terminal is common for the two speeds.
Step 7: Motor Connectons and Reel
Solder two cables to the motors terminals and insulate with shrinking tube.
I used hot glue to attach the reel to the motor axis.
Step 8: Motor Stand
Using a piece of soft white plastic I made a stand for the motor. I cut two slots for zip ties and tied the motor to the stand.
Step 9: Buttons Control
Drill two holes in the box to fit the buttons. Here you may need the gauge to measure what is the button diameter to determine the drilling bit.
One button changes the speed of the motor, other is the Start/Stop control.
If the box is very soft start with a small bit and progressively increase the size.
Step 10: String Entrance Hole
Just drill a hole on the side of the box where the reel rotates. Align the reel and the hole
I used a soft rubber piece to lay over the hole and protect the string from the harder plastic.
Step 11: LED
LED is soldered and its wires are insulated using the shrinking tube.
Step 12: Limit the LED Current
Voltage drop on LED = Resistance * Current
Resistance  = Voltage drop on led / Current  = 2.5 V / 15 mA  = 160 Ohms
160 Ohms resistor is enough to limit the current through the LED to 15 mA.
NOTE: The LED will have sufficient current through it to light it up only when powered at the higher voltage with the resistance in series with it.
Step 13: Mount the LED
A hole is used to keep the LED in place just where the string enters the box.
Step 14: Soldering Time
Ideal soldering iron temperature is about 380-390 degrees Celsius.
All cables are soldered and insulated with heat shrink tubing.
Finally zip ties tidy the mess and the connections look better.
It's a good idea to keep any wires away from the string and reel.
Step 15: Apply Hot Glue
I used hot glue for the motor base and the cable that supplies power to the LED.
Step 16: Foam to Restrain the Wobbly Bits Around
I used some kind of porous foam to help me keep the battery holder from wobbling around.
Could be hot-glued to the box too.
Step 17: Printing Labels
I had a printer at my disposal and printed some nice labels to show what each button is for.
One label is to change the speed from casual walk to astronaut's space travel speed.
Other for the string pull.
Step 18: Roll the String and Voila!!!
Finally the reel needs a string that has something attractive to the cat's preference.
I used about 5m of string (15 feet).
I also hang a wrist wrap at the side of the box.
Step 19: Work Hard Play Hard
All has been said, if you like my invention, please vote for me in the contests I've entered!
Comments are very welcome!
For everyone who reproduces this instructable I will give a free 3-month Pro Membership as a reward, just post a photo of your Cat Launcher in the comments below!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    43 Comments
    what if i use 2 battery pack that each contain 2 battery
    Add a way to launch the toy, like a crossbow!
    Super nice work on the electronics, my projects never look that tidy!!
    hah! i thought of this idea myself and came on here to see if anyone did the same thing. creepy how similar our projects are actually. where did you find a spindle/reel like that though? mine's too shallow.
    How the HECK did you figure out how to make that?!! Lol. Awesome job and idea tho! :)
    what an adorable kitty. I been using a lazer pointer but the batteries can get be hard to find. Think I will try this out.
    HI!! I am very sorry that this response took so long.... however I had a lot to think about and other things got in the way of this project. I have thought about what you said and the motor is a high speed motor from radio shack. they don't sell much low powered motors but i found one and it is a 1.5-3 volt dc motor that I think will suit my needs in the toy. It will run at 11,600 rpm with no load on it. It's dimensions are fairly small as around 2.25 inches in length and not even an an inch in height. I will try to find a enclosure for it, and have found some suitable enclosures. as for the batteries I am partial to the three triple A battery pack because I already have a bunch of nine volt battery clips. Finally I will need resistors to have the variable speed but which do I need? please be very specific for ones that I need for the triple A battery pack.
    I wonder if my 7 y.o. male cat or 8 y.o. female cat will love this. It looks awesome!!! You got my vote.
