Introduction: The Cheap IPod Dock
Picture of The Cheap IPod Dock
UPDATE
This has the title CHEAP on it to resemble that it is an ipod dock, but not a good one
Maybe one day I will make one that is not cheap, but actually costs some money and looks good
You Will Need:
1. iPod
2. USB Cable that came with your iPod
3. A small box made out of tin, metal, wood, or cardboard ( I suggest a tin box because it is stronger)
4. Scissors
5. Recycled or Scrap Paper
6. Packing Foam / Syrafoam
Step 1: Organization
Picture of Organization
I LIKE TO BE ORGANIZED:
Line up all of your materials
Yeah, I know this is a waste of a step
Step 2: Cut
Picture of Cut
First cut the edges of the foam so that they fit the tin box
Then, cut a hole as big as the Usb cable in the middle of the foam
Finnaly, you must cut a small part of the foam off of the back of the foam, as shown.
DONT RUN WITH SISSORS
Step 3: Fill
Picture of Fill
This Step Is Simple
Fill up the tin box with the scrap paper up to the top
Step 4: Almost Done...
Picture of Almost Done...
Okay
Put the foam on the box
Make sure that it looks good
Put the iPod end of the usb cable in the hole in the middle of the foam
Move the cable through the hole at the back of the foam
Plug the usb cable into the computer
Put the foam onto the box again
Step 5: Dock It!
Picture of Dock It!
The Final and Most Challenging Step, Docking Your iPod
Plug the iPod into the Usb Cable sticking out of the foam
Done
Have Fun Charging Your iPod
super moderator (author)2009-03-30
Finally an instructable that uses the 4th gen nano! Good work man keep it up btw, instead of paper scraps how bout a frame of some sort (skewers and glue perhaps?) (sorry had no time to draw it) just a suggestion 4 future ;)
cj72396 (author)2009-03-28
This was good! But I think it could use a little work. 1. Put the top on the tin, or cut it so none of the cable shows. By that, I men that it looks weird to have the little bit that connects to the iPod showing. I'm just picky about those things though. 2. Paper scraps? Maybe use something a little nicer. More expensive, yes, but it will be nicer none the less. Good instructable overall though. Very clear and easy to follow.
About This Instructable
7,357views
7favorites
License:
More by thejake551:The Cheap iPod Dock
Add instructable to:
